Question about Denon AVR-3805 Receiver
Denon 500 SD DVD player: Has a mind of its own
I have the Denon 500SD DVD player for the last 3 years. When it plays CD's,DVD's, MP3 etc - it does so beautifully. BUT !! It simply is the most finicky player I have ever used.
1. It takes atleast 5-6 attempts to run a CD/DVD. It either gets stuck in 'LOADING' forever, rattles noisily, or does not read ' NO DISC' or 'DISC ERR'. The DVD or CD does not matter. I could get a brand new DVD which it will play once and never play again.
2. The tray gets into fits of automatically ejecting. Whatever I do, it simply ejects the tray and closes by itsefl. Note it does so by itself
I was convinced it had a mind of its own, now I know it is possessed !!
Ok things I have done (a zillion times and with extreme care)
1. Used DVD head cleaner (both DVD's and liquids)
2. Cleaned the optical laser reader (blue lens)
It used to help in the past to restore the player to life for a few runs..only to get it back to the same state. I am gutted as to why I have put up with this for so long. I am stuck and pl help
Thanks
Deepak
  • 1 more comment
  • deepak_ravin Dec 02, 2008
    If I have to replace the Home cinema DVD player, what player specs should I be looking to match it with. I was going with the following (based on the current Denon speaker specs)
    - 5.1 Channel
    - 500W output with 100W per channel
    Is there anything else I need to keep in mind to ensure a perfect match.
    I do not see any clear link with the heating of the unit. All the issues/ or subset of them will be present as soon as I switch on the unit after a long period (overnight rest) as well. Infact the chances that it will play/accept more DVD's/CD's increases with time.
    Could you also help with how I can check/test if there is a defective 5V regulator ?
  • 728 Answers
This is probably an electrical problem because these are all the symptoms of it and since you say using a laser cleaner did not work with the loading problem after a while, there is probably a bad and shorty connection from the laser since you say it works a few times. Or the laser just might have "mood swings" since you say it plays new dvd's once and then you have problems with it.
Posted on Dec 02, 2008
  • 4,234 Answers
This sounds more like a voltage regulator or power supply problem that anything else. Is there any variation in behavior based upon heat? In other words, does the behavior change depending upon how long the unit is on? I would be looking for a bad 5V line inside the unit. Either the 5V regulator circuit is defective or the 5V is being loaded down by a bad filter cap or other component. Once the 5V drops below about 4.6V, the internal CPU will get confused and can cause any number of seemingly random symptoms.
Check that out and get back to me.
Dan
Denon dvd 2500 wont play movie
The Denon DVD-2500 will not play Blu Ray disks - DVD and CD only. Make sure you're using the proper disks.
The Denon DVD 2500BT however, WILL play Blu Ray disks.
Which do you have?
Jan 14, 2015 | Denon DVD2500BT Player
Denon dvd player and playing mp3
Check the user manual, is it able to play mp3 files? You've not mentioned the model number so, you could try going to the Denon Support pages:-
http://www.denon.co.uk/uk/support/pages/support.aspx
There you should be able to download a guide if needed and/or check whether there are any firmware upgrades to download for your player.
Jun 23, 2012 | Denon Televison & Video
How to repair dvd player v zon says wrong disc
Hi Vzon DVD Player,
Before you fix anything, you need to troubleshoot the problem first to know what needs fixing. Since DVD players can play different kind of media formats like Audio CD, VCD, mp3, etc, please try the following
1. Turn on the DVD player and set the program to DVD. some player needs to be setup due to multiple functionality (can play mp3 on flash drive, etc..)
2. insert different Media CD as mentioned above if your player will play them. (if they play, try to insert the DVD you want to play)
3. Try different DVD disc
4. If all the above don't work, try to clean the laser head using the standard disc cleaner.
5. retry the DVD disc
6. If the player still don't play your DVD, probable issue would be the laser head or the disc motor.
7. Please bring them to you nearest Electronic repair shop for further assessment.
Good luck and thanks!
Aug 20, 2011 | Coby TF-DVD7107 Portable DVD Player
Denon DHT-500SD system and want what is on TV to come through 500
You could try the optical route. You should be able to use the analog RCA audio outputs of the TV to the analog TV or VCR audio inputs of the receiver as well. Select the appropriate input on the receiver and you should have TV audio.
Jan 02, 2010 | Denon DHT500SD System
In car dvd player BEAT 500
Press for 3 seconds the volume button then change the settings. Go to park mode option and turn it off
Feb 25, 2008 | Avion AV-DVR100 DVD Recordable...
Denon 2910 CD player malfunctions
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Nov 06, 2007 | Denon DVD-2900 DVD Player
By this time I figure most peoples warranties are expired. So give this a try:
1 Open the case.
2 Turn the unit on and load a disk.
3 On top of the disk transport, you will see a black disk trying to spin as it reads the disk. You might notice that it is a bit quite as the display goes to 00H00M00S. It should be fast and a bit noisy.
4 Try loading a disk again, except this time, try to help that little black disk spin. It might take a couple of attempts, but I was able to get my 2910 working again.
The last year I've had to do this 2-3 times. But it works. From what little I have read, it may just be an issue with lubricating the right part with the right oil. I've narrowed my choices to PTFE 3n1 oil, Lithium oil, or silicone oil.
now I just need to find the right places to oil.
There should be quite a bit of noise and speed
Nov 04, 2007 | Denon DVD-2910 DVD Player
Denon AVR-3805 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
