Question about Vulcan 36L Gas Kitchen Range
Installation question I own a new Vulcan 36L which I would like to install in my home and am looking for info on how to insulate its surroundings (wall, cabinets, etc.). I was told by my gas man that, if installed / insulated improperly, the range would burn down my home! Help!
  • 4,806 Answers
Some people use stainless steel to insulate the surrounding areas of the ranges
Posted on Dec 01, 2008
Why is our inverter very noisy?
have it inspected by a service person for correct operation
check that rubber insulators were installed under the mounts of the machine
check that the installation is in line with the manufacturers recommendations so to prevent vibrations in walls and surrounds
Nov 04, 2017 | Inverter Heating & Cooling
Where is the thermocouple on the vulcan stove
https://my.vulcanfeg.com/resourcecenter/vulcanwolfberkel/ProductDocumentation/F31056.pdf
I think the above link may assist you with your question. Some ovens have difficult access to the thermocouple which is pretty much always right next to the pilot burner. Hope this helps.
Feb 05, 2014 | Vulcan 36L Gas Kitchen Range
How do I know what type of insulation to use when building my home?
It seems to me that a reliable source would be this site from the Department of Energy. You just enter your zip code along with some other info and it provides recommendations for your building:
http://web.ornl.gov/~roofs/Zip/ZipHome.html
Jan 15, 2014 | Insulation
Finding the correct thermostat
try e spares on the internet for the part you need
Jan 08, 2014 | Vulcan 36L Gas Kitchen Range
How do you put the spring back on the oven door on a 36SL?
hoe do i put back a spring in the hinge of my stove
Nov 26, 2011 | Vulcan 36L Gas Kitchen Range
How do i light the pilot on the top of the stove
some are fitted with pilot control knobs on front of machine and some you turn the burner tap to low flame position then press it in and light pilot
Apr 24, 2010 | Vulcan 36L Gas Kitchen Range
Iwant to change from natural gas to propane,wehat
If you live WAY out in the sticks, all you need is a tank of propane and the reqired fittings,BUT,if you live in the good old suburbs or the city you'd better have the gas company do the job. After all they have to shut off the gas feed to your house anyway. Good luck,Dana
Aug 21, 2009 | Vulcan 36L Gas Kitchen Range
Vulcan Range that wasn't heating.
The half inch tubing should be adequate under most circumstances. However, you may run into volume issues while using the oven and a few burners at the same time. If it bothers you, replace it. The door should be flush (or close to it) on the sides and the top. If you have an air gap, check the hinges.
Nov 10, 2008 | Vulcan 36L Gas Kitchen Range
What could be causing this?
i service these ovens alot and my first guess the t-couple you already replaced.i wouldnt think its the valve.lp burns very dirty as you know,clean out the burner/pilot assmbely and see if this solves it.also take a look at it when its lit and see if the pilot is being pulled to the burner.let me know.also if the unit has a regulator on the back pull the vent plug and clean it up.
Nov 09, 2007 | Vulcan 36L Gas Kitchen Range
Vulcan 36L Gas Kitchen Range Logo
51 people viewed this question
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
Oloyede Monsuru
Dan Webster
Dan Webster
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
