Question about Dishwashers
My ariston lsv 66 uk dishwasher is not starting the washing cycle. It is making the pumping noise as it normally does at the start of the cycle but will not go any further. I have tried all the washing cycles but it does the same thing for all of them. Any ideas??
  • swmsears Apr 11, 2009
    similar problem, the inside fills with water........but the programmer goes so far into the cycle, then the power trips out.
    Any ideas please
  • 1,462 Answers
Take bottom front panel off to expose the bottom tray. you will find it full of water. mop water out and machine will run. if fault reoccurs then you have a leak
Posted on Dec 01, 2008
Can anyone tell me about the washing cycle symbols on my Ariston LS12.EV03. It came with the apartment with no manuals...
Best I could do for instructions in English:
Here is a site with a lot of manuals for Ariston products, with other brand names:
Mar 05, 2015 | Dishwashers
My ariston LSV 67 built in will not start. When i turn it on the red and yellow light turns on after i put it on a setting but when i close the door nothing happens. Everything seems to be fine other than...
This could be door switch or anti flood.
Both require someone electrical competence to check.
Go to the Ariston web site and look up the schematic or parts diagram for you machine so you can locate the door switch and anti flood switch if fitted.
Check door switch works i.e. when depressed circuit is made .
Check for water in in anti flood switch if present identify leak and fix before using again.
Other things to check are that the pump is moving freely.
With unit switched off and un plugged only if you feel competent remove the food filter at the bottom of the machine after the filter has been removed you should be able to access the pump underneath.
Check it can be moved freely. There may be some resistant but not much.
If it is not rotating this need to be investigated rubber bands from food can seize it up.
Did the machine stop mid cycle or just not start after last wash?
any other useful information may help others diagnose your problem
good luck hope that gets you started
Dec 06, 2013 | Ariston Technologies Dishwashers
Ariston L63S dishwasher does not rinse
Check the screen and the inlet to the pump in the bottom of the washer if it does not empty the water from the wash cycle completely it may not go to the rinse cycle.
Sep 06, 2017 | Ariston Technologies Dishwashers
Hi, I have an Ariston LL64 model dishwasher that doesn't complete a wash cycle. It gets so far and stops with the "crystal care" light flashing. Any ideas? thanks Barry
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If not the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Aug 03, 2011 | Ariston Technologies LL64WNA Built-in...
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
Our hotpoint bf168 has stopped working. The rinse
Did you have ny luck solving your problem as my dishwasher has the same error
Jan 11, 2010 | Ariston Technologies Dishwashers
My ariston lsv 66 dishwasher will not start washing cycle. It makes the pumping noise as it normally does at the start of the cycle and some water enters the bottom of the machine but then it stops. I have...
Jul 11, 2009 | Dishwashers
Jenn air dishwasher- making loud noise in operating cycle
Hi I am Vortash by the sound of what you are descibing your pump bearings seem to be shot , although it is making this sound is it still washing properly if so it confirms it is the bearing and not the impeller catching and making the noise the pump gets to quite a high pressure to wash the dishes .. sort of an enclosed hot jet wash the force of which drives the spray arms .. so I am afraid it looks like you will soon need a replacement pump.. sorry to bare bad news .. Regards Vortash
May 22, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Ariston lsv 66 uk
tray is normally exposed when bottom front panel is taken off but may be obscured by sound insulation.
another way to get water out assuming it is present, is to tilt the whole appliance back at 45deg but disconnect from mains first
Dec 02, 2008 | Dishwashers
Dishwashers Logo
208 people viewed this question
Top Dishwashers Experts
