Used fishing equipment? I am in the process of buying my first sea going boat, a 27 ft sportfish on a limited budget and was wondering if anyone here has any suggestions on where to find good used fishing gear on the net. I have tried eBay, but have found that a lot of the stuff goes for close to retail. I am looking to buy about 6 rod and reels of varying sizes. Also, the aft deck of this boat has a sumbrella cover that goes from the stern to the rear of the fly bridge. Since the boat only sleeps two in the cabin, I am curious whether the AC would cool that aft area to some degree if I leave the cabin door open with the rear cover on so that I could put a air mattress in the back for two more sleepers. I live in NC and the evening can be rather warm. I am just curious if anyone has tried this with any success.
Dont go buy a bunch of junk till you really know what you need,then go buy the best,good tackle will last you the rest of your life,unless you fish commercial,as far as your sleep problem ,go to CVS and buy two O2 COOL fans,they run on ac/dc as well as 72 hrs on D batteries,place them in the doorway on the deck ,then cover opening from the header to top of the fans,seeing how all the cold air is on the deck your xtra guests will need a blanket,this method is tried and true.Bart A Riley
When I started fishing in the early years I had no money. I went to pawn shops and negotiated on their asking price for fishing equipment. They often have good quality reels and rods that have not been maintained very well.
When I got the goods home I would take the reels apart, install new drag washers and grease the gears.
You can put new guides on the rods, if necessary, easily.
I still use some of this equipment today some of it is over 15 years old and works like a champ.
I hope this helps and congrats on your new boat. What kind are you getting?
- I actually bid on some old reels on eBay last night so I may be learning the art of reel repair very soon. Unfortunately, I am not exactly sure what I need. I have fished in fresh water my whole life, but I am really starting from scratch with deep sea fishing. One of the reasons I am buyung the boat is for the challenge of learning a new kind of fishing. I am in the process of making an offer on a 1987 27.5 ft Sea Ray Sport fish (w/ flybridge)with dual stations. It has twin 350s - totally rebuilt in 99, Gen, AC and seems like it will do nicely as a weekend stay abord fishing boat. Unfortunately, it only sleeps two which is a drawback. As I am on a limited budget, any advise on how much a boat like this will cost me in maintenance will help out. I am figuring on 175 per month dockage, 100 dollars misc repairs per month. Is that reasonable? Are there things I should take into account that I have not thought about? Do you think it will possible for me to clean the bottom on this boat or would you recommend getting a monthly service?
I have a Nitro 929 dual console bass boat 20 ft. I keeps killing the main cranking battery. I check...
(More)
I have a Nitro 929 dual console bass boat 20 ft. I keeps killing the main cranking battery. I check and nothing is on all switches in off position no lights on etc. I checked the circuit that has the bilge pump on it with a ohm meter. went positive post to black load lead end of the circuit- left the positive circuit end attached. It read 12 ohms - don't know if this is good or bad --need advice. What is best way to check for a circuit that is draining the battery not showing a short.
Continiously shows depth of 0.07 ft. How do I reset and calibrate my 535, 320 pixels. Bought boat...
(More)
Continiously shows depth of 0.07 ft. How do I reset and calibrate my 535, 320 pixels. Bought boat but seller did not hav emanual. Thanks Jesse
I have a 1999 40 HP Mercury outboard which having problems lowering usind the switch on the side of...
(More)
I have a 1999 40 HP Mercury outboard which having problems lowering usind the switch on the side of the motor or the controls up front. raising seems to be no problem. I checked for loose connections nothing could it be low on cylinder fluid??
yamaha 115 v4 motor alarm sounding arrows point to all three e.g oil temp green and red gauges was...
(More)
YAMAHA 115 V4 MOTOR ALARM SOUNDING ARROWS POINT TO ALL THREE E.G OIL TEMP GREEN AND RED GAUGES WAS DOING APPROX 10 NOTTS WHEN ALARM SOUNDED MOTOR STARTED TO SHUDDER ,WHEN FLUSHED MOTOR OUT ALARM SOUNDED WHEN KEY TURNED BEFORE STARTING AND ALARM CONTINUED,FUEL IS FULL,OIL IS FULL ?.
bravo 3 twins on maxum 3200se. Speedometer not working - never worked since new - any thoughts...
(More)
bravo 3 twins on maxum 3200se. Speedometer not working - never worked since new - any thoughts please.
