Body Solid G4I Iso-Flex Home Gym
Problem for Body Solid G4I Iso-Flex Home Gym
Using bolt in place of J-hook?
By zizi_tripo on Dec 01, 2008
I got this exact same rack below but if you look closely at 7:35 or so, it looks like they are using the same bolt that is part of the 4 bolts, nuts and washers that belong to the assembly of the rack (the top bar connecting both pieces). It is clearly a bolt, but when I tried putting it through, it was a bit loose. I think they are using another washer. Am I off? Also it doesnt look that safe at all. it looks like the barbell is just a few mm from falling over somebody's neck.
http://www.youtube.com/watch?v=GuBO-d5th...
Solution #1
posted on Dec 01, 2008
Not Rated)
anna14
Rank: Guru
Rating: 89%, 730 votes
Kidney used to have bolts instead of J-hooks. Basically, it had a big nut and a washer on the other side. It makes it very easy to take it out of the rack.
Was this helpful?
Yes
No
Popular Solutions for Body Solid G4I Iso-Flex Home
Questions and Unsolved Problems for Body Solid G4I Iso-Flex Home
Do you recommend Body Solid G4I Iso-Flex Home Gym?
Answer
Answer
the resistance on my schwinn recumbant bike model 202 does not adjust
Answer
hi has anyone got a manual for a everlast ev1000 multi gym, if so can you please email it to... (More)
Answer
I have purchased the V-Fit Herculean Lay Flat Home Gym via ebay, and the assembly instructions... (More)
Answer
i have either the 2006 and 2007 model avanti home gym set. 200lbs stack with the leg press attached... (More)
Answer
Just buy an used dismantled product -- where can i find a user guide for installation ?
Describe your Home Gyms problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Home Gym Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
