Question about HP LaserJet 1200se Printer
HP printer 1200
After cleaning the printer roller it performs perfect printing documents then after a while say 2 hours, the print out document goes dirty....with black spots on the documents.. Can someone help...
  • michel liliord Jan 28, 2007
    the roller that you can see when you removed the catdrige....(i think the one that is pulling the paper..) but I also tried to clean the other roller but it is difficult to reach...
  • 624 Answers
Question: Which roller did you clean?
Posted on Jan 26, 2007
SOURCE:
My HP laserjet 1200 prints black instead of greyscale images from a PDF
If you are printing online then you cannot print this document. Because this document is in flash. If you wana print this document then you can use print screen option from pc then you can print exact thing that you want.
Mar 23, 2014 | HP LaserJet 1200 Printer
D7160 error messages showing put the papers facing down , its correct selection from our side but keeps showing the messges
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
  • If the self-test report prints , try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.
  • If the self-test report prints, but the original document does not , continue to the next solution in this document.
  • If the self-test report does not print , try printing the report again. Listen for the rubber paper-pick rollers; you should be able to hear them rotating. Then, try slowly pushing the paper farther in until the roller engages to pick up the paper. Be careful not to push the paper in too far, which can cause paper jams.
    • If the self-test report does not print when slowly pushing the paper farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
    • If the self-test report prints when slowly pushing the paper farther in , try printing the original document again. The paper might not have been loaded far enough into the product. If the issue is resolved, there is no need to continue troubleshooting.
    • If the paper only feeds through the product when you slowly push it farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
Nov 18, 2010 | HP Photosmart D7160 InkJet Printer
Printing stops halfway through document
This is a memory problem, it clears when you switch it off because it clears the RAM. You need to add more memory, or better still buy a new Canon. :>)
Jun 18, 2017 | HP LaserJet 1200 Printer
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
My d145 officejet prints document page crooked
your adf assy is out-of-alignmnt or feed'g rollers/sep-pad are filthy/bad. +possible that rollers in ppr-feed(lower unit) need cleaning also. good luck... auburncord@aol.com
Jun 14, 2009 | HP OfficeJet d145 InkJet Printer
HP Laserjet 1200 prints pdf documents slow
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
Feb 18, 2009 | HP LaserJet 1220 Printer
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
Dec 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1200 color problems with website prints
It strabge... Anyway u just clean your print heads and nozzles... it shuld make it fine... or just replace ur catridge...
Sep 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP LaserJet 1200se Printer Logo
157 people viewed this question
Clive
Clive
Thomas F. Schneider
