Question about Vision Mares Pure Mask
How do I keep my snorkeling mask from getting fogged up?
Any inexpensive products I can buy, or prefferablly anything I might already have in my home that would work.
    President:
  • 2,336 Answers
There are two easy reasons the mask is fogging. First can be the initial film wasn't properly cleaned off. When you get a new mask there is residue on the tempered glass. The easiest way to get it off is using the toothpaste as mentioned above. You dip the mask in the water and then put about a pea sized blob of tooth paste on each lense. (some masks have one large one some are two split.) Rub the toothpaste all around for a few minutes. Rinse and repeat. (it's worth the extra few seconds to do it again. It is the slight abrasiveness in the tooth paste that gets the film off. Second before you dive (or snorkel) apply a pro grade anti fog. or dip. I live in FL and use 500 PSI brand. It works great for me in the warmer water temps. A small bottle is like 6 bucks, but considering what we spend to go dive, or the small amount of time we get to spend on the bottom it is well worth it. Plus you use very much. A local dive shop can give you a good rec on what will work in your area. but 3 - 7 bucks can get you more than enough for 25+ dives.
Posted on Dec 01, 2008
How many time is normal mask life ?
it depends on the quality of the mask and it depends on how you stored it (if you leaved it at sunlight, if you washed it thoroughly after using it in the sea...)
i have a mid quality mask Mares mask, i have been using about 20 times for snorkeling, then i used it to take diving certifications in pool, then i used it for about other 20 dives in the sea... i always stored it in a dark bag (the mask is now about 8 years old)
you can check if you mask is still in good shape, and the silicone has not worn out, in this simple way: just put the mask on your face without straps.. remove all the air inside the mask by inhaling with your nose.. then look at your feet (keep inhaling): if the mask remains on your face you can keep using it
Apr 05, 2017 | Scuba Diving & Snorkeling
Tip
How to make homemade antifog solution
Here's a simple recipe to make your own anti fog solution instead of buying expensive anti fog spray. Mix equal parts of a mild dish soap and hair conditioner. Put it in a an eye dropper or squirt bottle and apply a thin layer to your dive mask as usual, wipe it around, and briefly rinse out.
on Jan 07, 2010 | Scuba Diving & Snorkeling
How to loosen straps on snorkeling mask
http://www.youtube.com/watch?v=ZaktqZSPmts
Here is a quick 2-minute video that will explain how to loosen the straps on your snorkeling mask, and tell you many other useful facts about snorkel masks. If your mask is a different model, you can look at the related videos on YouTube and find one that has straps similar to yours.
Jul 05, 2012 | Vision Mares Pure Mask
Leaking at glass connections at top of mask
I hope you don't think I'm being rude, but the best and most reliable fix is to chuck away the appalling bit of rubbish which U.S. Divers conned you into buying and replace the mask with one which is designed for divers by divers (snorkellers included!). This would mean almost anything by Seac Sub, Mares, ScubaPro, Suunto, Oceanic, TechniSub and others.
I'm sure that the "U.S." in the company name means "UnServiceable".
Light-heartedness aside, I am being serious. There are the overpriced but cheaply made and badly engineered items sold by U.S. Divers and then there are items which actually work reliably. Despite the immensely better quality of the better brands they usually have models which start at low prices.
Despite my obvious dislike of the brand you have, it's fair to say that your problem could just be due to age or misuse: the silicone rubber skirts on all masks shrink and harden with age and the harder plastics in the construction distort and may also shrink. The processes are accelerated if you tend to leave your mask out in the sun and if you just stuff your mask unboxed into a dive bag with loads of other gear or towels packed on top.
You can try popping off the frame which holds the glass in place and then reseating everything correctly before reassembling, but I'm confident that this will be as effective as trying to pick your nose whilst wearing boxing gloves.
Jan 20, 2010 | U.S. Divers Manta Ray LX Snorkeling Mask
Fogs up on every dive
this works. spit on the inside of the lens and rub it around and it will stop fogging up
Sep 03, 2009 | Dive Rite ES125 Mask
Can you use a snorkel mask for scuba diving?
There is a reason for the difference in price, one is purely for surface observation and the other is able to stand the pressures of deeper water diving... If your going to scuba dive the investment is worth it, don't skimp on safety…
Dec 01, 2008 | Vision Mares Pure Mask
What is the best way to clean your mask and snorkel after a trip in saltwater?
No need to use soap or fancy cleaners for snorkel or dive gear. The important thing is just to get the salt off, and plain old fresh water will do the trick. The best way to clean your gear, is to fill a bucket or a tub with warm water, and then dunk your gear several times to rinse it out thoroughly. In some cases I like to swish it around underwater, and maybe rub the rubber parts to ensure a thorough rinsing. After that, let it drip dry and store it in a cool, dry, *dark* place. Salt and sunlight are the two things that'll kill your gear in no time at all, keep it safe from that and it should provide good use for a long time.
Dec 01, 2008 | Aeris Snorkeling Bag
The right snorkel for me
"A snorkel must fit comfortably in your mouth, allow you to purge water out of the mouthpiece and hose quickly and help you to swim efficiently. But, the most important characteristics to remember when choosing a snorkel are its length and the diameter of its barrel. Snorkels must not be too long or too short. If a snorkel is too long it will be difficult to breathe because the barrel will fill up with carbon dioxide. Every time you breathe out carbon dioxide through your snorkel your breath must travel up and out of the barrel of your snorkel to allow you to draw oxygen back down the barrel and into your lungs. If your snorkel is too long you will only push a percentage of the carbon dioxide up and out of the barrel during your exhale. You will need to inhale oxygen before all the carbon dioxide has been pushed out; leaving the percentage of carbon dioxide entering your bloodstream higher each time you take a breath. This cycle could lead to suffocation. If a snorkel is too short it will constantly fill with water, requiring you to constantly force the water out of your snorkel which can be very exhausting. The inside diameter of your snorkel must be approximately three quarters of an inch or 1.9 cm. If the snorkel is thinner than .75 inches it will be difficult to breathe because there will not be enough room in the barrel for you to draw enough air into your lungs. This will cause you to breathe harder and rapidly, which could cause hyperventilation. If the barrel is thicker than .75 inches it will be too large and will be uncomfortable to use and attach to your mask. Learning to attach your snorkel to your scuba mask to make sure it is easy to grab and use is an important part of safe scuba diving practices. Snorkels are attached to the left side of your mask with a snorkel keeper. Snorkel keepers are either plastic or rubber and most use a post-hole closure. Each snorkel keeper is different and attaching your snorkel to your mask with a snorkel keeper requires practice. If you will detach your snorkel from your mask after each dive you should practice attaching your snorkel, as it can be a little tricky. Alternately, you can leave your snorkel attached to your mask if you are diving more than once in a day. "
Vision Mares Pure  Mask Logo
705 people viewed this question
Top Vision Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Vision Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
