Question about Aeris Snorkeling Bag
How exactly do snorkels work when you are under the water???
Or more to the point: Snorkels don't work under water. They work on the surface by allowing the wearer to have his/her face in the water so that one can look at what is going on and the top of the snorkel is several inches above the surface allowing the user to breath through the tube. If, as often happens, the snorkel gets water in it, there is a trap at the bottom that catches it so you don't **** it into your lungs and on the next exhale you do so forcefully and this expels all the water from the tube and allows you to continue breathing.
Posted on Aug 09, 2009
  • 2,336 Answers
Well basically the top part we'll call the tube, stick up above the water while the tune extends to your mouth so that when you breathe in the air above goes into the tube and you can breathe but when water fills the mouthpiece you exhale hard and the water travels up the tube and to the top and litterally spits the water out.
Posted on Dec 01, 2008
Can you do metal detecting under water?
Yes, metal detecting under water is actually quite popular. There are a few types; Snorkeling with a metal detector, Scuba detecting and Shipwreck diving.
All of these types require equipment that can be expensive to hire/ buy.
Feb 21, 2013 | Retail Supplies
Do I need to wear water shoes when snorkeling?
Many beaches have soft, sandy bottoms so you don't need water shoes. Every so often though, I snorkel where the bottom is rocky or has turtelgrass or coral bits or something. I would recommend you research the beach where you will be snorkeling to see what the bottom is like. When in doubt, bring water shoes along just in case.
Feb 14, 2013 | Water Sport
How do I keep my snorkel set clean?
Rinsing in clean water is all that's ever been required for mine. Store covered in a conditioned space between 50 and80 degrees F.
Jun 08, 2010 | Body Glove Snorkel Mask Fin Snorkeling Set...
How do I clean my hydroair LX snorkel? I'm seeing
I use baking soda, warm water and bottle brushes for pretty much anything that goes near my mouth. My hydration bladder gets that treatment often especially after a long trip, as has my snorkel a couple of times. You could try find a platypus or camelbak cleaning kit at your local outdoors store.
Oct 31, 2009 | U.S. Divers Grande Vista LX Mask with...
I bought this snorkel used and put it in my bathtub last night and it filled with water. The lower chamber is filling to the point I can't even blow it out. Is there something I don't know?
From what you've described, you have a self-draining snorkel (at least it would be if working correctly). There will be a simple diaphragm valve at the lowest point of the snorkel, it's usually made of a silicone rubber disc and in use is held closed by external water pressure. It can also be held open if there is any grit or sand in it, if it is damaged or if it's simply hardened with age.
All you can do is clean it and make sure it seats correctly. If it has failed in any way or if the diaphragm is simply missing then buy a new snorkel as they don't need to be expensive.
There's a good reason that many divers still prefer a simple j-tube snorkel and it's because there is nothing to go wrong. I personally do use a self-draining snorkel but I'm careful to inspect and clean the valve before and after every use and always have a spare snorkel in my dive bag.
On an unrelated matter, if the snorkel has any kind of device on the open end to prevent water from entering then I strongly recommend that you remove it. They're restrictive to airflow and are potentially dangerous. There is no substitute for simplicity and for learning to use a snorkel correctly.
Jul 09, 2009 | Tabata Usa Tusa Snorkeling Two Window...
Why does my cj7 choke out in water
get a snorkel if intake is submerged under water
Jan 17, 2009 | 1985 Jeep CJ7
What is the best way to clean your mask and snorkel after a trip in saltwater?
No need to use soap or fancy cleaners for snorkel or dive gear. The important thing is just to get the salt off, and plain old fresh water will do the trick. The best way to clean your gear, is to fill a bucket or a tub with warm water, and then dunk your gear several times to rinse it out thoroughly. In some cases I like to swish it around underwater, and maybe rub the rubber parts to ensure a thorough rinsing. After that, let it drip dry and store it in a cool, dry, *dark* place. Salt and sunlight are the two things that'll kill your gear in no time at all, keep it safe from that and it should provide good use for a long time.
Dec 01, 2008 | Aeris Snorkeling Bag
Clearing the Snorkel of Water
Step1 Make sure you are gripping the mouthpiece of the snorkel securely with your teeth. Step2 Exhale forcefully through your mouth. The majority of the water should be expelled from the tube. This method is commonly called "blasting" or "popping." Step3 Inhale gently at first in case there is any residual water. Blast a second time if needed. Step4 Continue blasting whenever water enters the snorkel.
The right snorkel for me
"A snorkel must fit comfortably in your mouth, allow you to purge water out of the mouthpiece and hose quickly and help you to swim efficiently. But, the most important characteristics to remember when choosing a snorkel are its length and the diameter of its barrel. Snorkels must not be too long or too short. If a snorkel is too long it will be difficult to breathe because the barrel will fill up with carbon dioxide. Every time you breathe out carbon dioxide through your snorkel your breath must travel up and out of the barrel of your snorkel to allow you to draw oxygen back down the barrel and into your lungs. If your snorkel is too long you will only push a percentage of the carbon dioxide up and out of the barrel during your exhale. You will need to inhale oxygen before all the carbon dioxide has been pushed out; leaving the percentage of carbon dioxide entering your bloodstream higher each time you take a breath. This cycle could lead to suffocation. If a snorkel is too short it will constantly fill with water, requiring you to constantly force the water out of your snorkel which can be very exhausting. The inside diameter of your snorkel must be approximately three quarters of an inch or 1.9 cm. If the snorkel is thinner than .75 inches it will be difficult to breathe because there will not be enough room in the barrel for you to draw enough air into your lungs. This will cause you to breathe harder and rapidly, which could cause hyperventilation. If the barrel is thicker than .75 inches it will be too large and will be uncomfortable to use and attach to your mask. Learning to attach your snorkel to your scuba mask to make sure it is easy to grab and use is an important part of safe scuba diving practices. Snorkels are attached to the left side of your mask with a snorkel keeper. Snorkel keepers are either plastic or rubber and most use a post-hole closure. Each snorkel keeper is different and attaching your snorkel to your mask with a snorkel keeper requires practice. If you will detach your snorkel from your mask after each dive you should practice attaching your snorkel, as it can be a little tricky. Alternately, you can leave your snorkel attached to your mask if you are diving more than once in a day. "
Snorkel need issue
Every scuba diver spends time on the surface while preparing to descend for a dive. A snorkel allows you to conserve energy by letting you keep your head in the water while swimming and enjoying the pre-dive sights without ever having to remove your head from the water.
Aeris Snorkeling Bag Logo
5,071 people viewed this question
Top Aeris Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Aeris Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
