i got a 10" sub with a total of four post on the back of it...two pos. and two neg. i took it in to get it a new box and the people moved the posts around..and i cant remember where they go...i noticed a wierd sound from it after i got it back. when i looked at the back i noticed the post were moved...i havent used it since...can you help me put them in the right place?
If it isnt this way try this, Take the + Lead from the amp to the + on the Sub, Cross from the - on the first side to the + on the other set of posts, then take the - from the second set of posts to the - one your amp. I assuem this is a Dual 4 Ohm and will bring that down to a 2ohm which induces more power from your amp and should be louder it could be 2X2 1
Comment by EJB0220, posted on Feb 17, 2007
I Meant that to come out 2X2 which would come down to 1 but you have to make sure your amp is one ohm stable, Some arent. Hope this helps
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on were the negative and positive post....:
Solution #3
posted on Jun 24, 2007
Guest
Rank: Apprentice Rating: 0%, 0 votes
thats not the correct way to bring a dual 4ohm speaker down to 2ohm bridged..
the correct way is to hook both negatives together, n then both positives together. run 1 wire from negatives to negative terminal on amp. run 1 wire from positives to positive terminal on amp. done
