Question about Aeris A1 Octo
Scuba octopus? What is the difference between a regulator and an octaopus. What exactly is an octopus
    President:
  • 2,336 Answers
An octo IS a regulator. There are two types or regulators on a typical scuba rig. Your first stage reg that is attached to your tank valve. From this first stage, there are hoses leading to your primary breathing second stage reg and your Octo second stage. The job of the first stage is to bring that possibly 3,000 psi air in the tank, down to a more reasonable pressure of about 150 psi. From there, the air goes to the second stages and can be reduced down further by these second stage, on demand (meaning it delivers air when you inhale and stops when you finnish inhaling), regs. The Octo is a second stage back up for a buddy that is out of air or if your own primary second stage ( the one you normally breathe from) is no longer functioning. Octos are generally ( not always) a cheaper reg, that may not have all the bells and whistles that a primary air source does. It's there for an emergency, so ease of breathing under load and tuning adjustments are minor. It gives you air when you're in a pinch, thats the important thing.
Posted on Dec 01, 2008
My octopus leaks from the head (not the hose). Could it be an internal problem?
A rebuild or simple adjustment can make it stop leaking if it is coming out of mouth piece if it is leaking from anywhere but mouthpiece or hose connection it needs service.
Mar 26, 2012 | Oceanic Swivel Octopus, Scuba Diving...
My Mares Prestige S octopus is leaking air under water from the mouthpiece in as low bubble rate. Shoud it be ajustued and how
It may be that you have picked up a little bit of sand or grit, give it a good vigorous wash in the bath. Often octo's get dragged along the bottom and get rubbish in them. If it does need adjusting I strongly recommend you get a professional to do it. :)
Oct 25, 2010 | mares PRESTIGE 12 REGULATOR Scuba Gear
Who services Dacor Viper scuba regulators
Depends really where you are in the world, but most reputable scuba service centres should be able to help you.
Aug 26, 2010 | Dacor Viper Tec Scuba Regulator
Genesis "S.K.O." Octopus GS060 The above product is constantly leaking, not much but pretty much all the time, it does help depending how I position it but that should not really be the answer, It has been...
Hello, there are a few things that may have happened. Often octos pick up sand and grit when they get dragged on the bottom. Try a good vigorous shake in fresh water. After that your moving into badly seated diaphram, split diaphram or slight hole, badly adjusted spring etc etc etc. Would recommend that perhaps you get it serviced. Especially important if you have been using Nitrox. Hope that helps
Jul 17, 2010 | Genesis Scuba Regulator Octopus S.K.O....
Hey guys, im confused... i want to buy my new diving gear and i have come to a conclusion between two packages... these are : Scubapro : 1st stage din/int Mk17/395 reg + Oct R295 + seac sub BCD (First) +...
Denx7d could have not said it any better i have about 1300 dives on my gear and still in good shape and have annual service on my gear now i am a certified repair technician for scuba pro these regulators they sell are the best on the market hands down
Jan 21, 2010 | Scubapro MK11/R395 Regulator SCUBA...
Just got my mares proton reg back from servic it was fine before just been a year so got it serviced it is now free flowing is there a way to adjust this
Personally, I wouldn't touch it. This should have been tested in the service so I'd get back to them and have them rectify this as it seems to be something they did..
Oct 10, 2009 | mares Proton Scuba Octopus Regulator
H2o0008 inflator regulator will not fit on Mares BC
have u tryed changing out you regs inflator line one should have came with your bc
May 17, 2009 | Scuba Diving & Snorkeling
Scuba Tank Setup Question
Ideally, you should have someone who is certified in regulator servicing to do this for you. Otherwise, you may be endangering your life.
Dec 01, 2008 | Aeris A1 Octo
Guidelines to Scuba Regulator Purchase
The scuba regulator is employed in an open-circuit scuba set. Said scuba equipment reduces high air pressure conveyed by the diving cylinder to the first stage and feeds breathable gas to the diver through the second stage's mouthpiece. Also called pressure regulator or demand regulator, the scuba equipment is one of the essentials to diving that determines breathing quality and inhalation effort during the dive. But given the different types of regulators and the pertinent design of its first and second stage components, how should a neophyte diver - or even a seasoned diver at that, choose a scuba regulator that incorporates user adjustment and delivers a venturi-assisted air flow in its features? Consider your diving purpose and frequency. Better yet, take note of the following criteria to guide you in your purchase: 1. The Scuba Regulator's Mouthpiece. Check the specifications if the regulator is outfitted with a patented orthodontic mouthpiece. This implies that it is ergonomically-designed to accommodate an overbite or underbite by the human mouth. An ergonomic mouthpiece helps reduce fatigue in the mouth and jaw area, particularly in the cruise of lower depths and extended dives. 2. User Adjustment Settings. There are optimally-designed scuba regulators that are outfitted with adjustment levers to therefore allow divers to finetune valve settings in order to provide the least possible inhalation effort throughout the dive. One notable scuba equipment is the Aeris AT 400 Pro Regulator that is equipped with an adjustable second stage. 3. Weight of the Scuba Regulator. Visualize yourself on a dive and using just any other type of scuba regulator. Is the regulator bulky to considerably increase drag and cause jaw fatigue or is it buoyant enough for you to carry around with your mouth? Lightweight scuba regulators use polycarbonate thermoplastics for its housing to make the scuba equipment compact, sturdy and corrosion-resistant that makes them fit for extended use. 4. Nitrox Compatibility. This entails an ocular inspection of the cylinder tank (Nitrogen and Oxygen proportions) and scuba regulator (Nitrox compatibility) specifications. As a matter of convention, most regulators are suited for nitrox mixture use out of the box; containing the standard, maximum proportion of 40% Oxygen (in terms of volume) but then again, there are gas mixes supporting leaner proportions of oxygen such as the trimix. Therefore, check if the scuba regulator supports the gas mixture configured for your diving cylinder prior to purchase. 5. No-Contaminant Feature. As much as possible, choose a diving regulator that has been manufactured using Dry Valve Technology (DVT). DVT operates through an automatic valve that prevents contamination of the first stage mechanism to thus prevent regulator flooding and the entry of moisture or dust particles. This likely improves scuba regulator performance and extends its useful life. 6. Air-Sharing Feature. This feature often associated with octopus regulators (used as a spare demand valve or alternate second stage) will prove to be most helpful during diving emergencies such as a free flow or during diver rescues. High performance octopus regulators such as the Aeris Gyro Octopus Regulator are designed lightweight and with air-sharing feature, while sporting an inline swivel for convenience mounting and flexibility
Dec 01, 2008 | ACCO Brands Apollo Bio-Filter Moisture...
What side does the octopus go on? left or right?
The reason to have it on the right is because that is "standard". I dive with a long hose (7') and an octo around my neck on a 22" hose. So long as you explain it to anybody you dive with and talk about your plan for air sharing in advance, it shouldn't be an issue.
Aeris A1 Octo Logo
2,671 people viewed this question
Top Aeris Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Aeris Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
