Question about Endurance TF3i Folding Treadmill
When keeping speed, incline, etc equal, I find some treadmills harder to run on than others. Why?
I find, for instance, than on some machines I can easily run 5 to 7 miles at a good pace (6.7 - 7 mpg) while others I am exhausted after 2.5 miles! Same incline, same speeds, etc. What is the difference?
    President:
  • 2,336 Answers
Theres going to be several reasons that is the case. First and most obvious is the caliberation aspect. The machines are not going to be perfect, and such things as the belt stretching with age means older machines will be less acurate, and depending on the technology cost etc. all machines will read slightly differently. Second is the conditions of the room your working in. Hotter conditions will work you harded; dry air, humid air etc. All will make a difference to your percieved exertion and how quickly you are tiring. Another factor is the surface, run a mile on flat concrete, a mile on flat asphalt; and feel the difference. The concrete is much harder and less forgiving, and so will tire your leg muscles quicker as they cope with the additional shock. The same occurs on treadmills, less shock absorbtion in the surface will mean your legs tire quicker. There are other factors that can make a difference as well, such as the way the display is set up, which can mentally motivate you more or less depending on how its laid out, what it shows etc. Its not in your head though, but there are many reasons; one gym and machine will not be the same as another.
Posted on Dec 01, 2008
What are the different ways to prevent shin splints pain?
Here are the different ways to prevent shin splints pain:
1. Strengthen your hips- The best exercises for preventing shin splints are basic squats, deadlifts and lunges. But, your focus should be on using your glutes.
2. Minimize using machines- Machine based exercises are some of the least effective for treating shin splints. The reason is because most machine-based exercises are performed while sitting down and in an apparatus that provides all of the stability for you.
When you run you're standing not sitting. So, your own body has to stabilize itself as you are on one leg the majority of the time. If you aren't training the actual movements and positions similar to running then you are making yourself prone to injuries to your shins, ankles, knees, hips and lower back.
3. Stop running on the treadmill- Treadmills are a great piece of equipment to run indoors or while you watch TV at the gym. But, if you are trying to avoid shin splints then you'll want to avoid the treadmill as much as you can and run on a solid surface instead.
Treadmills operate with a belt so it's harder to get a solid push off the ground because it's moving underneath you. When you run on a solid surface like outdoors you can push off the ground which also helps activate the hips more effectively than on a moving surface.
4. If using a treadmill use incline rather than speed- If your only option is using a treadmill then keep the speed down a bit from your normal pace and substitue by increasing the incline slightly.
Running on an incline can help reduce shin splint pain because you naturally have to push off the ground harder using your hips to move uphill. When running on a flat surface your shin muscles can take over since the hips aren't forced to work very hard to move your body.
5. Use effective training combos- There are a number of exercises and sequences that can help you prevent shin splint pain if you know how to do them.
Sep 15, 2015 | The Health & Beauty
Nautilus NTR 800.6 Treadmill. I can go up on speed and incline but not back down?
please RUN the software calibration, for easy diagnose, troubleshooting, and fix it.
Test the speed sensor, for open or faulty, clean it, and tight the connector very well. see the diagram
Happy New Year. God bless you
Jan 01, 2013 | Exercise & Fitness
Ifit treadmill stuck on highest incline
RUN inmedaitely the software calibration for diagnose, troubleshooting and fix it. Now that machine is running in slow speed.
sincerly. God bless you
Apr 23, 2012 | Proform 740cs/745cs Treadmill Walking Belt...
Circuit breaker trips
Check for excessive wear on deck and running belt. Friction from the worn deck/belt causes the motor to worker harder, pulling more power.
Jan 07, 2012 | Precor 933 Premium Series Treadmill
How does the e3200treadmill fat calories work with the regular calories burnt.
Add incline. Instead of keeping the treadmill on a flat surface, maintain an incline as you walk, jog or run. This will serve to replicate the wind resistance and terrain variation that you encounter when you run outdoors. Keep an incline of at least 1.5 percent on your treadmill throughout your workout.
  • 2 Increase your speed. If you run at the same speed every time you workout, your body will not be challenged and you may reach a fitness plateau. Up your speed by a quarter-mile per hour every few weeks.
  • 3 Vary your workout time. In order to challenge your body in different ways, variety is key. If you run for half an hour three times a week, opt for a one-hour run for your fourth workout. This will help to condition your body for endurance training, resulting in more calories burned.
  • 4 Use intervals. Interval training can dramatically increase your calorie burn in an average workout. Instead of running at a steady pace for your entire workout, mix in sprints. Jog at a steady pace for two minutes, and then increase your speed to a full sprint for 30 seconds. Return to the steady pace to recover. Your heart rate will rise on your intense sprint intervals and stabilize on your longer recovery periods.
  • 5 Incorporate incline into your interval training. You can use incline in the same manner that you would speed to interval train. Walk or jog at a 5 percent incline for two minutes. Increase the incline to 10 percent for two minutes and then to the 15 percent maximum for one minute. Decrease the incline back to 10 percent for two minutes and finally back to 5 percent for two minutes. Repeat this same pyramid interval a few times.
  • 6 Wear a heart rate monitor. This will monitor how hard you are actually working as well as how many calories you burn in each workout. You can then adjust your speed and incline accordingly to maximize your calorie burn.
  • 7 Drink plenty of water before, during and after your treadmill workout. If you are dehydrated, you won't perform as well as you can. You'll work harder and burn more calories if you're hydrated
  • Nov 03, 2011 | Exercise & Fitness
    When starting my treadmill the incline just starts all by itself, all the way up, sounds like it would keep going if it could, then it declines, its stuck in this loop. the belt never starts and I cannot...
    This sounds like the treadmill is running an incline calibration. It will run to fully inclined, then to minimum incline.
    It should not do this every time you want to operate the machine, but they will do it automatically if the operation of the machine is stopped by the power being interrupted..
    Jan 26, 2011 | HEALTHRIDER S600 Treadmill Motor Control...
    I have a MC2100-12A motor controller in this treadmill. The LED blinks quickly like communication is ok but it doesn't control right.The speed sensor also looks ok. When 1mph is selected it runs at 2.7mph...
    The speed sensor on these machines have nothing to do with controlling the speed. The machine will run without it. The sensor is obviously working, since you are getting a speed reading.
    The calibration is a mechanical adjustment found on the motor controller, the instructions are found under the lid as well as the meaning of the LEDs flashes on the tech sheet..
    Follow the calibration procedure. If the operation is still erratic, I would suspect a defective controller.
    Calibration: Press stop and speed up. Install the safety key/magnet. release the buttons. Press stop 1 time. one window displays speed, the other the calibration number. Both should be "0".
    Press speed up, the treadmill should begin to move around 25-30. increase to 85, the machine should be a max speed. adjust the pot on the motor board to max speed. Some machines are 10mph, others 12mph. The tech sheet will tell you the max speed. When adjusted, press speed down. the machine will stop. Now press incline up. That will calibrate the incline. When completed, remove the safety key.
    If operation is still erratic, change the motor controller.. It could be the console, but the cost of replacement makes the repair in most cases uneconomical..
    Dec 15, 2010 | Exercise & Fitness
    I have a proform 785..the problem is the speed and incline decreases all of a sudden like within a minute...i raised the speed to 4 and it dropped to 2 within 1 min and same thing with the incline it...
    Unplug unit remove motor shroud then start calibration procedure.
    Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
    Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
    Press either incline key and the incline will calibrate automatically
    BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
    Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
    If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
    The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
    It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
    After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
    Press the Stop key once and remove the safety key.
    Jun 11, 2010 | Proform 785 CS Personal Trainer Treadmill
    Manual to trouble shoot/run diognostics
    These units only have a calibration mode. The High end units generally will have that. If this is a Epic Then this calibration procedure should work.
    Press the Stop and the Speed Up keys down while inserting the safety key. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a movable center and is located near the three small speed wire connections labeled H, W, & L and is on the same edge of the board and the red and black motor wires are located. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
    May 30, 2010 | Epic 425 Mx Treadmill EPTL88105 !
    Manual Treadmills vs. Motorized Treadmills
    Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
    Dec 01, 2008 | Endurance TF3i Folding Treadmill
    Endurance TF3i Folding Treadmill Logo
    335 people viewed this question
    Top Endurance Exercise & Fitness Experts
    Howard
    Howard
    Tom Chichester
    Techmotionusa.com
    Techmotionusa.com
    Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
