Question about Sevylor Fish Ranger 280
What kinds of boats are used for rowing? - Sevylor Fish Ranger 280
    President:
  • 2,336 Answers
The boats (or shells) are basically of two types and reflectthe two forms of rowing---sweep rowing and sculling. In sweep rowing each rower handles a single oar (about 12.5 ft or 3.9 m long) in sculling a rower uses two oars, or sculls, (each about 9.5 ft or 3 m long). The word shell is often used in reference to the boats used because the hull is only about 1/8" to 1/4" thick to make it as light as possible. These shells are also rather long and racing shells are as narrow as possible while recreational ones can be rather wide. Most shells today are made of composite materials such as carbon fiber, fiberglass, or kevlar. A few manufacturers still build wooden boats. Each rower has his back to the direction the shell is moving and power is generated using a blended sequence of the rower's legs, back and arms. The rower sits on a sliding seat with wheels on a track called the slide. Each oar is held in a U-shaped swivel (oarlock) mounted on a metal pin at the end of a rigger. The rigger is an assembly of tubes that is tightly bolted to the body of the shell.The exception to this are some european recreational boats called "inriggers" which have the oarlock attach directly on the gunwale. The subtypes of rowing shells are classified according to the number of rowers in the shell. Sweep Boats (each rower has one oar) These shells can have a coxswain---a person who steers the shell (using a rudder) and urges the rowers on. I have included in parenthesis the symbol used for each subtype along with some dimensions and weights. Coxed Pair (2+) Two sweep rowers with a coxswain. Coxless Pair (2-) Two sweep rowers without a coxswain. Coxed Four (4+) Four sweep rowers with a coxswain. Straight (or Coxless) Four (4-) Four sweep rowers without a coxswain. Steering is usually accomplished via a rudder that is attached to a cable that is connected to one of the rower's foot stretchers (this an adjustable bracket to which the rower's feet are secured). The coxless pair has a similar type of rudder setup. Eight (8+/8o) Eight sweep rowers with a coxswain. Eights are 60+ ft (~18.5 m) long and weigh about 250 pounds (~114 kg). Sculling Boats (each rower has two oars) Only in rare cases do these boats have a coxswain. Steering is generally accomplished by applying more power or pressure to the oar(s) on one side of the shell. The hands overlap (usually left over right in the US) during part of the rowing cycle, or are always left in front of right. Single (1X) One rower or sculler. Singles are about 26 ft (8 m) long and less than a foot (0.3 m) wide. Racing singles can weigh as little as 30 pounds (~13.5 kg). There are heavier (~45 to 50 pounds), shorter and wider versions often referred to as recreational singles. Double (2X) Two scullers. Most racing doubles can be also used as a pair with a different set of riggers designed for sweep oars. When used as a pair a rudder is usually added. There are also recreational versions of sculling doubles. Quadruple (4X) Four scullers. Often referred to as a `quad' and usually has a rudder attached to one of the sculler's foot stretchers as in the straight four. Most quads can also be rigged as a straight four using a different set of riggers. Octuple (8X) Eight scullers. This is rarely seen, though is used in the UK, at least, in junior competition where sweep rowing is not allowed. Weight Classifications There are basically two weight classes for rowers---heavyweight (HWT) and lightweight (LWT). Men (M) For team LWT boats, there is a 72.5 kg (~160 lbs) individual maximum, and the boat must average no more than 70 kg (~155 lbs). Women (W) The individual maximum for team LWT boats is 59 kg (~130 lbs), and the boat must average no more than 57 kg (~125 lbs). In the US, the women have an individual max only; no average. In some regattas in the US (usually head races late in the season) these limits are increased by 5 lbs. A rowing shell is usually built with a particular weight class of rower in mind. Until just recently the Olympics effectively had only HWT classifications.
Posted on Dec 01, 2008
My family has an old row boat at our cabin in IL. It was our grandpa's and The title is lost/not avaiable. Looking to use the boat with a 25 HP outboard but can't use it with out registration. Help
Rowing boats don't need title. However, when you add a motor :>)
http://www.marinetitle.com/boat-registration/IL-Illinois.htm
You can swear an affidavit that the boat is without title and was purchased in 19?? before title, and that the boat belongs to you by inheritance.
All boats must be registered except sailboards, boats used exclusively as a ship's lifeboat, boats while competing in any race approved by the Department, non-powered boats owned and operated on water completely impounded on land belonging to the owner of the watercraft (this does not apply to waters controlled by a club or association), or a canoe or kayak which is owned by an organization which is organized and conducted on a not-for-profit basis with no personal profit inuring to anyone as a result of the operation. Registration is also required for Coast Guard documented vessels. Boat registrations are renewed every three years.
The form is here, send it in as a new registration.
http://www.dnr.illinois.gov/boating/Documents/FillWCA.pdf
  • How to Obtain a Lost Title on a Boat Trailer in Illinois ... www.ehow.com > Legal > Consumer Law > Other Consumer Law
    • BY KURT ERICKSON
    How to Obtain a Lost Title on a Boat Trailer in Illinois. When you are buying or selling a trailer in Illinois, it must have a title. The Illinois Secretary of State ...
  • Illinois Boat Registration Instructions ' DMV.org www.dmv.org > Illinois > Registration & Title > Car Registration Information regarding Illinois boat registration, ... If you need to register and title your boat in IL, ... DMV.org is a privately owned website that is not owned or ...
  • Illinois Boat Registration - MarineTitle.com www.marinetitle.com/boat-registration/IL-Illinois.htm Illinois boat registration information, ... Boat Title Requirements: All ... Mechanic's Boat Liens: Illinois has specific procedures for registering or titling boats ...
  • Jun 16, 2016 | Boating
    My question
    Here's an answer.
    Apr 24, 2015 | Boating
    I have a soft toy giraffe that sings row row row your boat,only its broken can it be fixed
    Yes you can use an adhesive Areldite or whayever avilabale and do it yourself.
    Jul 02, 2010 | Toys
    2005 Water Skeeter Pontoon..What kind of pump for the valves
    If you look up Halkey-roberts valves you will see the air filler part.
    May 24, 2010 | Water Skeeter Guide Lite Pontoon Boat
    Is rowing a boat a Isokinetic excerise?
    Rowing a boat is only an isokinetic exercise if you make it so. The perfect stroke has an acceleration and a deceleration, therefore, it is not isokinetic.
    However, resistance does increase with more effort in the middle of the stroke, therefore, this "negative feedback" mechanism has a similar feel as an isokinetic system.
    Oct 09, 2009 | Boating
    Is a minn kota 35 suitable on a 10ft rowing boat . I normally row on my local lake when fishing , each trip consist of no more than 1 hour of rowing
    I have a 30# thrust and it pushes my 14' jon boat well. I think a 35# motor should work well for your boat, unless there are very high winds, in which case, any motor will have trouble, even your outboard.
    Jun 07, 2009 | Boating
    Sevylor Fish Ranger 280 Logo
    534 people viewed this question
    Top Sevylor Boating Experts
    Fabrice Wolters
    Tom Chichester
    Are you a Sevylor Boating Expert? Answer questions, earn points and help others
