Question about Arc'Teryx Theta Ar Bib Women's
What types of crampon attachment are there? - Arc'Teryx Theta Ar Bib Women's
    President:
  • 2,336 Answers
There are three main types of attachment systems for crampons. These include Step-in bindings, Hybrid bindings and Strap bindings.
Posted on Dec 01, 2008
On the Grivel G12s you always end up with a large piece of loose strap. Many happy hours spent trying to tidy this up, then re do it an hour later. What is the recommended way to neatly and safetly
Go to this page, click on Instructions and click on the type of product you have. You will get the full instructions sheet.
http://www.grivel.com/products/ice/crampons/5-g12
Feb 04, 2013 | GRIVEL Rock & Ice Climbing
What are crampons?
Crampons are sharp metal spikes that stick out from the bottom of your shoes and cling to the ice to help you in climbing.
Jan 14, 2013 | Rock & Ice Climbing
Are La Sportiva Typhoon boots suitable for use with crampons?
You can try to contact La Sportive directly and ask them:
http://www.sportiva.com/about/aboutus/about-us/contact
Jun 08, 2012 | Rock & Ice Climbing
Which kind of binding system is possible to have on this crampon?
The Air tech comes in the universal (or strap) binding, teh clip-on binding , and the hybrid (universal front with clip-on back)).
Hope this helps.
Feb 22, 2011 | GRIVEL Air Tech Crampon
Instructions for strapping to boots the stubai 6 point crampons
Try reading the following review:
http://www.backpackgeartest.org/reviews/Snow%20Gear/Crampons/Stubai%20Light%20Combi%20Crampons/Owner%20Review%20by%20Ray%20Estrella/
Jan 11, 2011 | Stubai 6 Point Crampon
NEED TO REPLACE BROKEN CRAMPON WHERE TO PURCHASE
I suggest that you will try their website:
http://www.redfeather.com/accessories.html
Jan 11, 2010 | Redfeather Rock & Ice Climbing
How to strap the Black Diamond Neve crampon to boots
Hi Joseph,
As per the picture above.. It's normal to have a chunk of strap hanging loose at the end.. You can just tuck it away, once it doesn't interfere with the spikes it's not a problem. They just put the extra on to accomodate extra bulky gear or boots..
Mar 23, 2009 | Black Diamond Neve Strap Crampon
What are Crampons?
Crampons are outdoor footwear that are made from spikes and are worn on boots to provide traction on snow and ice. General-purpose crampons designed for most mountaineering and glacier travel are not well suited for vertical ice climbing. For ice climbing, specialized crampons that provide better support for front pointing are advised. Most crampons require welted boots to ensure proper fitting. Crampons with 10 points were first introduced by Europeans in the early 1900s. Because they lacked forward pointing spikes, they required step cutting on steep terrain. In the 1930s, two additional forward-slanting points were added, thus creating today's 12-point crampons. While 12-point crampons are now the normal selection, a few 10 point crampons can still be found on the market. The two additional front points further reduced step-chopping and allowed the climber to "front-point" up steep snow and ice. The angles of the first two rows of points also determine the best use for a particular set of crampons. If the first row (front points) bend downward and the second row is angled towards the toe, this reduces calf strain by allowing the boot heel to be lower. In this case, these crampons are better suited for front-pointing. When straight points are used instead, the crampons are much better suited for snow & general mountaineering. While crampons are an invaluable tool for a mountaineer, they were not used as often as today until the development of plastic-shelled climbing boots, because the straps used to affix the crampons to early mountaineering boots (which were made of leather) had a tendency to restrict bloodflow to the feet of the wearer. Crampons are usually made of hardened steel, but lighter weight aluminum crampons are popular for alpine ski touring where the need for them is less frequent & counterbalanced by the need for a light pack yielding fast, efficient travel over long distances. One problem with crampons is that snow can ball up between the spikes, creating a dangerous scenario where the teeth no longer bite into the slope. To prevent this, most crampons can be fitted with "anti-bott" plates: shaped bits of flexible plastic that engage on the body of the crampon.
Dec 01, 2008 | Arc'Teryx Theta Ar Bib Women's
Crampons for winter
everal manufacturers of crampons for hiking/glacier travel. You want something w/ 6-10 Pt's, some can even be configured so they hinge in the middle. The bright side is the price of this class of crampon, they're a lot cheaper that the type you would climb a frozen waterfall. Should be any where from 39.95-100.00 and can be found at Campmor, EMS, Seirra Tradingpost. A word of caution...Do not attempt to climb vertical ice with a cheap pair of crampons, even if they have front points. I foolishly almost fell off some steep ice in the Whites when the points (both) sheared off my left crampon. If your not going to climb try to buy a pair w/out the forward facing front points. Hiking down tired your a lot more likely to hook frontpoints and trip, it'll happen every time you don't pick your foot up high enough. Also, get an ice axe, affords extra confidence when traveling up/down steep terrian. Enjoy Your Winter Hiking
Arc'Teryx Theta Ar Bib Women's Logo
464 people viewed this question
Top Arc'Teryx Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you an Arc'Teryx Winter Sport Expert? Answer questions, earn points and help others
