Question about Arc'Teryx Theta Ar Bib Women's
How do I take clean my Carabiners? - Arc'Teryx Theta Ar Bib Women's
    President:
  • 2,336 Answers
Typically, you'll only need to clean your carabiners by blowing any dirt or dust away from the hinge area. If any additional cleaning is necessary, then be sure to wash your carabiner in warm soapy water, and rinse it thoroughly. Once it is rinsed and dry, be sure to lubricate the gate area with a dry graphite, WD40 or other kind of lubricant. Using a dry lubricant will help to keep your carabiner clean longer, as dirty will not be readily picked up. Once the gate has been lubricated, be sure to wipe off any excess lubricant.
Posted on Dec 01, 2008
Yamaha outboard starting
New plugs and service
Sep 21, 2009 | Rock & Ice Climbing
Tip
If your offroad motorbike has a leaking fork seal,try this before you take it to...
If your offroad motorbike has a leaking fork seal,try this before you take it to get fixed.Get some old camera film(negatives)and cut off the holes on the edge.It needs to be about 4inches long.Cut the top off at 45%.Now slide and work the piece of film up into the fork seal.You then work the film up and down in a sawing motion as you go around the fork seal.If you FEEL some grit,slowly pull it out,wipe clean and start again.Do this untill the fork seal feels clean of grit.It can save you heaps of dollars and maybe it will fix your problem if you are out riding on the weekend.It very often works!
on Dec 13, 2009 | Rock & Ice Climbing
Test 17.13
Jul 07, 2009 | Dmm Rock & Ice Climbing
Test 11
Jul 07, 2009 | Mammut Rock & Ice Climbing
Need manual for revolver need parts
Go to gun store and they can help you
Feb 25, 2009 | Rock & Ice Climbing
How should I pick my carabiners?
Depending on your style of climbing, you will want different kinds of Carabiners. There are basic types: your oval and D-shapes are your most basic Carabiners. Sometimes you'll want a locking Carabiner, especially for belay, or for anchors. Most Carabiners that you have will probably not be locking Carabiners. There are different types that are easier to clip. There's bent gates, straight gates, wire gates. It depends on your style and if you're weight conscious, or how durable you'd like them to be.
Dec 01, 2008 | Arc'Teryx Theta Ar Bib Women's
Which kind of carbiners shoul I use
The best carabiner shape for any kind of static rigging is a symmetric shape - oval is the best. Most carabiners are asymmetric "D" - which is stronger but will cause the line to shift when loaded - the oval shape is better because nothing will shift to one side of the carabiner when loaded. You could use standard aluminum carabiners or even locking ovals (Petzl and Omega make very nice locking ovals), but I would also suggest using steel carabiners - they are cheaper and stronger and since weight isn't an issue they are better.
Dec 01, 2008 | Black Diamond Equipment Primrose Climbing...
Arc'Teryx Theta Ar Bib Women's Logo
195 people viewed this question
Top Arc'Teryx Winter Sports Experts
vtrktrmn
Todd Arndt
Todd Arndt
Are you an Arc'Teryx Winter Sport Expert? Answer questions, earn points and help others
