Question about Arc'Teryx Theta Ar Bib Women's
How should I pick my carabiners? - Arc'Teryx Theta Ar Bib Women's
    President:
  • 2,336 Answers
Depending on your style of climbing, you will want different kinds of Carabiners. There are basic types: your oval and D-shapes are your most basic Carabiners. Sometimes you'll want a locking Carabiner, especially for belay, or for anchors. Most Carabiners that you have will probably not be locking Carabiners. There are different types that are easier to clip. There's bent gates, straight gates, wire gates. It depends on your style and if you're weight conscious, or how durable you'd like them to be.
Posted on Dec 01, 2008
How do I get instruction manual for Hasbro bopit carabiner edition
Use google search and you can download the PDF from the results. This was previously answered for you.
May 20, 2015 | Hasbro Bop It Mini Carabiner Edition
How to take red key lock off as I cant get DVD to play
I don't think this is the right section but umm...
you should push the button and wiggle it around. if that doesn't work remove power and go inside and look at that button. I'm assuming this is for a remote...
May 16, 2010 | Mammut Element Key Lock Carabiner Color...
I don't want to drop my Grigri
I assume you're using the grigri to belay and are looking to extend the position of the Grigri from your harness to produce a sharper angle with your braking hand.  I suggest using one locking carabiner attached to your harness and another one attached to your harness, then connect the two with a sewn piece of webbing (or a short length of cord).  I would pick a webbing loop no longer than shoulder length, to keep the Grigri from being too far away from you. I would avoid making any changes to the grigri for the purpose you mention.
Apr 05, 2009 | Rock & Ice Climbing
Need manual for revolver need parts
Go to gun store and they can help you
Feb 25, 2009 | Rock & Ice Climbing
Is it safe to use a 1700 weight limit carabiner as a anchor for r
I wouldn't do this without checking with a professional climbing place. That's almost a ton! Don't listen to just anyone at a hardware place or you might get injured or killed!
Dec 02, 2008 | Omega Pacific "Doval" Carabiner
Rock Climbing Harness with Auto Belay, where to hook on?
Easiest is to hook the swivel carabiner to the belay loop.  This is a sewn loop of webbing that connects the leg loops to your waist belt.
Dec 02, 2008 | Black Diamond ATC Belay/Rappel Device Fall...
How do I take clean my Carabiners?
Typically, you'll only need to clean your carabiners by blowing any dirt or dust away from the hinge area. If any additional cleaning is necessary, then be sure to wash your carabiner in warm soapy water, and rinse it thoroughly. Once it is rinsed and dry, be sure to lubricate the gate area with a dry graphite, WD40 or other kind of lubricant. Using a dry lubricant will help to keep your carabiner clean longer, as dirty will not be readily picked up. Once the gate has been lubricated, be sure to wipe off any excess lubricant.
Dec 01, 2008 | Arc'Teryx Theta Ar Bib Women's
Which kind of carbiners shoul I use
The best carabiner shape for any kind of static rigging is a symmetric shape - oval is the best. Most carabiners are asymmetric "D" - which is stronger but will cause the line to shift when loaded - the oval shape is better because nothing will shift to one side of the carabiner when loaded. You could use standard aluminum carabiners or even locking ovals (Petzl and Omega make very nice locking ovals), but I would also suggest using steel carabiners - they are cheaper and stronger and since weight isn't an issue they are better.
Dec 01, 2008 | Black Diamond Equipment Primrose Climbing...
Arc'Teryx Theta Ar Bib Women's Logo
90 people viewed this question
Top Arc'Teryx Winter Sports Experts
Arnie Burke
Arnie Burke
Marvin
Marvin
vtrktrmn
Are you an Arc'Teryx Winter Sport Expert? Answer questions, earn points and help others
