Question about RTO Aviva Crazy Twister Noodle Water Pool Lake Float Raft
How can I craft my own DIY Raft? - RTO Aviva Crazy Twister Noodle Water Pool Lake Float Raft
    President:
  • 2,336 Answers
Being the simple water vessel that it is, building a raft out of equally simple materials is no complicated tasks given that one knows the precise steps of constructing one. The raft has always been one of man's trustiest vessels in carrying him across bodies of water. Distinguished by its lack of a hull, which is something that most of other boats have, it is perhaps the most basic among all of the water vessels that man has ever made. Even though, the raft has always been one of the most used boat-type for travel over water as its simplicity makes it one of the easiest floating structure to craft since one only needs everyday materials and the essential know-how to construct the raft. To build one's own DIY raft, one needs the following materials: a decking, some screws and bolts, a ratchet, some marine foam, some pressure treated lumber with some sawed into sizes of 2 x 10", and some paper and pencil. For the tools, one needs a circular saw (though table saw will suffice), a drill with a full bit set, a hammer, and a knife. To start building the raft, one first needs to determine what size and weight one's raft will be. Building a heavy and large raft will be obviously more durable as far as traversing the waters is concerned but constructing a lightweight and small one will enable one to easily transport the raft from one body of water to another. It is entirely up to one's preferences as the building procedure will be the same no matter what one opts to construct. Start the actual construction by cutting some of the 2 x 10" boards into half and then attaching them to full-length 2 x 10" boards with a blocking of 2 x 4". Screw the pieces together with marine or galvanized iron screws coupled with the use of countersinks. After this, attach the side boards to the 2 x 4" blocking at the raft's middle and the third positions. With some screws and blocking, fasten four side walls together. Locate the floor joists in the raft and cut them to 7' in length. 2 x 10" board sections are then attached from center point to center point all across the box. One can now fasten the floor joists as needed. The marine foam now can be cut and attached to the spaces present between the joists. Apart from filling in the spaces, foams also add to the buoyancy of the raft, an aspect that is crucial in all floating devices. As with all foaming materials, a hotwire or a knife is the perfect cutting tool. After the essential parts of the raft have been built, one can now turn to the decking. Like the weight and height of the raft, constructing the decking rests mainly upon one's preferences in the weight, durability, and practicability aspects of one's raft. Building one's own raft is an easy project to accomplish as long as one has sufficient supply of the necessary materials and the requisite expertise for building simple structures such as the raft.
Posted on Dec 01, 2008
Re cliner foot rest wont open need digram to fix
How to Fix a Reclining Lounge Chair - DIY Recliner Repair ...
? 2:28
https://www.youtube.com/watch?v=0P4cHbjiJmc
May 29, 2012 - Uploaded by How to... Science, Craft Plus Other DIY Fixes
Is your footstool not working / not rising up? ... How to Fix aReclining Lounge Chair - DIY Recliner Repair - Fix a Broken Plastic Foot Stool Lever ... Hi there any ideas on how to fix the back of the recliner its stuck in open position? I have removed it and the steal bars that the back attaches to wont align ...
Recliner Mechanism - YouTube
Dec 19, 2015 | Health & Beauty
I've just gotten into leather crafts and I need some ideas for some DIY projects. Recommendations please!
Here is a list of some ideas for leather crafts. Have fun!
http://papernstitchblog.com/2012/05/04/friday-diy-9-things-you-should-make-with-leather/
Feb 20, 2013 | Crafts & Hobbies
I have 2 punctures in my raft. Can I use a regular rubber repair kit?
Coghlan's Plastic or Rubber Repair Kit works on air mattresses and raincoats so it could work on your raft. It is available at Canadian tire for about $4. In a pinch you could also use duct tape. It provides a temporary, but waterproof seal.
Jun 06, 2010 | Coleman Boating
How do I sail to the second island?
What I usually do is to go around the entire island gathering supplies first.
Then I return to First Beach and build/craft the 1X3 Roof (this unlocks new
shelter plans, bed plans, and the Comfort Motive). I then build an open
shack,
Improvised Cot, and Bamboo Spear. Between all of that and the Emergency Fire
Pit, Stone Axe, and Original Crafting Bench built earlier, this is usually
enough to get my Mechanical Level beyond 2.
Once that is done, gather all you can from Pier Beach. Then rest up, build
your
Raft, and select "Explore."
** The first time you sleep in a bed your Fun Motive will unlock, as will
plans for Music Shaker and Sand Buddy. **
You will notice a few goals you were not able to complete on this island. Not
to worry as some of them will have to wait for the 2nd and 3rd islands!
Jul 15, 2009 | EA Sports EA Games The Sims 2 Castaway...
Janome Memory Craft 5700 LCD Screen
The LCD Backlight is prone to going dark eventually and fails progressively, but you can buy a replacement and even instal it yourself.....
We can now supply the LCD Backlight Screen for the Janome Memory Craft MC 8000 and Memory Craft MC 5700.
Keep your old Janome, save money and reduce unnecessary landfill.
It also comes with comprehensive installation instructions from the Original Janome Service Manual which are sent in advance so you can look at the "How to do it" before you decide whether you wish to DIY or enlist the services of a trusted friend or take the LCD Screen and installation instructions to your friendly local technician and have them do it for you.
Here is the LCD Backlight Link
May 31, 2009 | Sewing Machines
I need my inflatable raft repaired i live in new york city where can i go to get it fixed.
You can actually save a BUNCH of money and do it your self its really easy go to a sporting good store or online and look for a raft repair kit takes a couple hours including dry time and costs less than 20 bucks
Apr 15, 2009 | York Yankees Full Size Pool Raft Float!...
Save your life?
Absolutely. All sailing and sea-going craft should carry rafts - inflatable vessels which can maintain the lives of stricken mariners until rescue is available.
Dec 01, 2008 | RTO Aviva Crazy Twister Noodle Water Pool...
RTO Aviva Crazy Twister Noodle Water Pool Lake Float Raft Logo
1,218 people viewed this question
Top RTO Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
