Question about Marvin 3150 Mid-Size Heater
Heater is getting power, but will not work
I have had the heater for 16 days and it stopped working 5 days ago. The power light will come on, but it will not heat and the fan will not come on. I have attempted to reset it several times and tried it in several different outlets.
  • 1 more comment
  • markheater Dec 26, 2007
    I have rival 240v 400w T268 heater the heater heats up but fan does not come on. heater is new but old stock, what to do? the heater has been in storage for a good while but new , just pluged it up?
  • lpd180 Oct 04, 2008
    I have the same problem but I must be missing the fuse location. Is it at the bottom of the element and resembles a diode?
  • nursenicely2 Jan 28, 2009
    I HAVE THIS HEATER & HAVE THE SAME EXACT PROBLEM. WAS WORKING FINE THEN ALL OF A SUDDEN SWITCHES FOR FAN & HEAT DID NOTHING. LIGHT COMES ON TO INDICATE IT IS GETTING POWER BUT NOTHING ELSE. MY HUSAND THINKS IT'S A FUSE OR SWITCH CONTACT PROBLEM. I TRIED REACHING THE COMPANIES CUSTOMER SERVICE # ON BACK OF UNIT BUT IT IS NO LONGER IN SERVICE. CAN YOU HELP?
Sorry about the length of time, but I just found this website.
My wife bought 3 of these when it became apparent that our oil furnace needed to be replaced. One crashed, as did yours. The neon lamp lit, indicating that the unit was receiving power, but neither the heatin, nor the fan worked.
We got a new furnace. I just took a look at this near-garbage that was in my workshop. I trouble-shot it to an internal fuse that has obviously blown. I went on this website hoping that someone had the fue\se rating so that I can replace it.
The unit is a little tricky to open, but, pretty much, just open (and save) all of the tiny screws (except those in the feet - not necessary), including those that secure the side brackets. (The unit folds together, and you can't fully get it apart without, somewhat, "unfolding" it.
Good Luck
Papou1
Posted on Feb 10, 2008
I guess of heater element are open and this can cause the fan from not working because both of them are on the same wiring
Posted on Feb 16, 2007
  • Andy Handy Feb 16, 2007
    That means there are 2 set of wiring 1 for the indicator lamp and another for the heater and fan.You have to open to see it.Make sure that it is not connected to the main supply.A simple continuity test will give you the result
SOURCE:
How do I restart my airconditioning unit after a power outage?
If there is a panel you can open at the A/C. There may be a tiny reset button on the circuit board. Just press it and it should come ALIVE!
Jul 21, 2014 | Honeywell CT3200 5-2 Day Electronic...
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
What's your problem?so a few days ago on my GMC Acadia 2008 SLE the panel where i control the AC/Heater stopped working, the display is on, but the buttons are not working and dont light up, does
You might just have a wire loose somewhere. My 96 Cadi did that a couple of times lastyear, then it was fine. Hasn't done it since.` So, who knows! Sorry, not much help to you.
Feb 08, 2013 | 2011 GMC Acadia
I have model NO cz798 , it keeps runing this morning it was 82 O" F
my space heater power light come on but the fan has stop moving.i
brought this heater less than 30 days ago
Nov 12, 2012 | Comfort Zone CZ792 Electric Utility Heater
I have a Nortitz natural gas water heater, model #N-063s-1. Acouple of days ago it stopped heating the water. what can I do myself to fix this matter. Thanks, lynnatheana@hotmail.com
There are many reasons a tankless heater will stop heating water. The first thing I would look for is a flashing red light on the burner indicator. The flash break down goes as follows
continuous blinking - typically means ignition failure or the unit is overheating; look for visible water inside the unit, have your gas pressure checked, or check the flame rod/igniter for buildup of debris
three blinks - typically indicates 16 error code; typically resolved by performing a descale
4 or 5 blinks - exotic error codes; for these you should definitely contact Noritz tech support
If there is no flashing light, first check your filter for debris. If the filter is clean, your flow sensor is probably stuck. Again I'd recommend contacting Noritz tech support to help you clean the flow sensor.
Jul 31, 2010 | Noritz 6.3 Gallon Residential Tankless...
I have a atwood hot water heater GC6AA-10E its o...
Does yours have the little cut-out diode looking thing in the plastic jacket installed between power wire and thermostat? If yes, remove it from the circuit and connect female spade of wire, to male spade of thermostat,(just removing it to by-pass it) and try it now. Let me know what happens.
May 20, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have an aqualink rs and my spa heater isn't working. I checked the propane and it is full. The heater was working 2 days ago. Now I turn spa and spa heat on the filter pump comes on and the red light...
If the Aqualink is calling for heat then the problem is most likley in the heater. Without more information I can't tell you much more but if nothing has changed in the last couple of days. Before you call anyone be sure to clean your filter and baskets. The heater need a set amount of pressure to run and if things are dirty it won't get that pressure. Good luck.
Mar 12, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
The front ac is not working it just stopped
Check the blower motor resister. Hope this was helpful.
Jan 28, 2010 | 2003 Dodge Durango
No heater fan in all switch positions
are you talking about the fan that blows heat into your car or the fan that cools your engine
Jan 20, 2009 | 1990 Oldsmobile Cutlass Ciera
Marvin 3150 Mid-Size Heater Logo
430 people viewed this question
Top Marvin Heating & Cooling Experts
Bruce Showalter
john h
Marvin
Marvin
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
