Question about Vision Mares Pure Mask
How to choose a scuba mask
Hey guys, went to the store to buy a mask. But a big verity of masks has me confused. How do I choose the right mask for me?
    President:
  • 2,712 Answers
"The shape of the scuba mask and the silicone skirt on the mask must conform to the shape of your face to provide you with a comfortable fit. Ensuring the silicone skirt is a high-grade, flexible silicone can help to ensure the scuba mask conforms to the shape of your face and the long life of your scuba mask. Some people are allergic to different types of rubber, if you have an allergy to rubber, be sure to choose a silicone scuba mask because silicone is hypoallergenic. Always talk to your scuba diving gear retailer about the alternatives available to you. When trying on scuba masks you will notice the different shapes of the nose pockets. The nose pocket protects and cushions your nose, helps to keep your scuba mask from fogging during a dive and helps you to maintain equalization. Ensure the size and shape of your nose pocket is comfortable; not too tight and not too large. This will improve not only the comfort of your scuba mask, but your ability to purge your mask efficiently. There are increasingly different styles of scuba mask straps on the market. You may like the factory issue strap on your scuba mask or you may want to purchase a separate strap. Scuba mask straps are available in a single strap or a double strap design. The single strap should wrap around the centre of the back of your head. The benefit of the double strap is that you can position the top strap on the upper part of your head and the bottom strap on the lower part of your head to offer extra stability and comfort. Most scuba mask straps are rubber or silicone and fasten with a post-hole belt enclosure. Newer scuba masks offer a slide-lock type enclosure, which allows you to adjust the scuba mask quickly and easily when wearing the mask. Scuba masks are constantly improving. If you wear prescription glasses or contact lenses on a daily basis you can purchase a scuba mask without having to wear your glasses or contact lenses under your mask. Many manufacturers will create custom scuba masks which include your prescription in the front lens. A good sign you have chosen the right scuba mask for your face is when the mask stays on your face comfortably without using the straps to hold it in place. You should try this simple test with each scuba mask you try on for the first time: See our choices for scuba masks 1. Place the scuba mask over your eyes and mouth ensuring the mask is in the correct position. 2. Take a quick, light breath in through your nose and immediately start to breathe through your mouth as if you are scuba diving. This will create a slight suction between the scuba mask and your face. The scuba mask should stay on your face. If you must push the scuba mask against your face, or inhale repeatedly to help the mask stay on your face, the mask is not a good fit. 3. Keep the scuba mask on your face for approximately one minute. This will help you to determine how tight the seal is and how comfortable the mask is on your face. 4. Exhale gently through your nose to release the seal on your scuba mask and remove the mask from your face. There should be no mark on your face from the scuba mask. If there is a red line around your face from the seal of the mask, the seal was too tight or the mask is not the proper size for your face. Try the test a second time. If you still have a red mark on your face after you remove the mask, you need to continue your search for a scuba mask. Remember, a good scuba mask is one that's comfortable, doesn't leak and is easy to use."
Posted on Dec 01, 2008
    Problem Solver:
  • 11 Answers
Whether you are scuba diving or snorkeling, a good quality, well-fitting mask will make the difference between an okay time in the water, and a really great time in the water. After all, if you spend half your time having to clear your mask, that's half your time that you're not spending looking at all there is to see. No two faces are the same, so you may have to try on a lot of different masks before you find one the works for you.
1.Decide what style of mask you want. There are a few different shapes on the market. There is the older oval shaped style that used to be popular with divers years ago. Then there are the more modern styles that have a wider field of vision. Other styles that are popular are ones with side panels, giving you better peripheral vision in the water, and ones with tear-drop shaped lenses so that you can look down more.
2.Look for features suitable for scuba diving. Diving requires masks made from tempered glass for safety, in case it breaks. It should have a skirt with a close, comfortable seal against your face. It should come with nose/finger pockets--essential for equalization purposes. It should have a low profile which allows for a wider field of vision. It should also have an adjustable strap that can be locked in place.
3.Notice the materials it is made of. Most masks you see today are made from silicone rubber which lasts a long time. They typically come with a translucent skirt or a black one. Black skirts can reduce glare and are particularly popular with underwater photographers.
4.Check for comfort and fit. To try on a mask, pull the mask strap up and out of the way, gently place the mask to your face, and inhale. Remove you hand. Does it stay? If you had to push the mask on, then it's probably not a good fit. If it stays, does it feel like it will leak? You may want to bring your snorkel in with you when you get fitted for your mask. This way, you can tell if there might be any leaks when you have a snorkel (or regulator) in your mouth.
5.Wash your mask before your first use with a little toothpaste to get off the protective coating that face mask manufacturers coat new masks in. If you don't, that coating is sure to fog up your mask. Rinse your mask with tap water after every use, and store in a cool dry place, away from sunlight.how to choose a scuba mask   - 8_22_2012_9_30_37_am.jpg
Posted on Aug 22, 2012
2 Suggested Answers
  • 2712 Answers
SOURCE: how to choose a scuba mask
Where can I find a replacement strap for my scuba face mask?
Most straps are universal. But if you want an exact replacement just seach www.usdivers.com for your local US Divers retail store.
Sep 10, 2017 | U.S. Divers Scuba Diving & Snorkeling
How many time is normal mask life ?
it depends on the quality of the mask and it depends on how you stored it (if you leaved it at sunlight, if you washed it thoroughly after using it in the sea...)
i have a mid quality mask Mares mask, i have been using about 20 times for snorkeling, then i used it to take diving certifications in pool, then i used it for about other 20 dives in the sea... i always stored it in a dark bag (the mask is now about 8 years old)
you can check if you mask is still in good shape, and the silicone has not worn out, in this simple way: just put the mask on your face without straps.. remove all the air inside the mask by inhaling with your nose.. then look at your feet (keep inhaling): if the mask remains on your face you can keep using it
Apr 05, 2017 | Scuba Diving & Snorkeling
Tabata liberator mask strap connector broke - can this be repaired it looks like it will come off
I believe this is a Tusa mask, if it is then yes they pop off, although a little stiff, a little washing up liquid can help. Try phoning your nearest scuba store that stocks Tusa masks they should be able to get a spare for you. :)
Sep 18, 2010 | Tabata Usa Scuba Diving & Snorkeling
Buckles are broken
At a Sherwood dealer? You might also go into ANY SCUBA store with your mask. Many brands have similar or even identical parts.
OR contact the company for a replacement.
Feb 19, 2010 | Sherwood Magnum Ex Panoramic Single Window...
I have an Akona Wahoo scuba mask and the strap has broken. Can I get a replacement?
Most any scuba shop will have replacement mask straps.
They are very common replacement.
Dec 01, 2009 | Akona Wahoo Junior Mask
The swivel part on the side where the strap connects to just broke. Is there a replace ment available? The plastic on the mask itself is undamaged.
Standard replacement part, sometimes generic. Go to any SCUBA store and ask for the part. In a pinch use a zip tie on the broken side as a temporary non-adjustable fix.
Aug 09, 2009 | Genesis Quadra Mask SM7400
Can you use a snorkel mask for scuba diving?
There is a reason for the difference in price, one is purely for surface observation and the other is able to stand the pressures of deeper water diving... If your going to scuba dive the investment is worth it, don't skimp on safety…
Dec 01, 2008 | Vision Mares Pure Mask
Prescription Scuba Mask
The inserts would be specifically for your eye prescription and are bonded to the lens. You can even get bifocals done for your mask and also correct for astigmatism. Your specific prescription can be fit into any dive mask that you choose so there is no need to buy a new mask. prescription scuba mask Manufacturers also offer scuba masks with lenses already premade and the same prescription in both eyes. You choose the prescription that fits your needs. Some divers find this adequate to use underwater. The premade prescription mask would obviously be cheaper than custom made scuba diving masks. Personally, I wear contact lenses when I dive and have had no problems (besides losing one after I surfaced and got hit by a wave). I wear the daily soft lenses and don't notice them when I dive. I've never dove with hard contact lenses so I do not know how they would respond to pressure. If you wear lenses, you should consult your eye doctor to see what they recommend in your case before you dive with lenses for the first time. Let them decide whether you would be better off with a prescription scuba mask or diving with contacts. One site I found which seems very professional is www.prescriptiondivemasks.com. They even have a testimonial from Cathy Church, the renowned underwater photographer, on their site so it can't be too shabby.
Scuba mask maintenance
" 1. Use a defogging solution before every dive, even when diving more than once in the same day. This will prevent your scuba mask from fogging during a dive. You can purchase a commercially prepared defogging solution from any reputable scuba diving retailer. Squeeze a drop or two onto the inside lens of your mask and gently rub the solution around to cover the inside completely. Dip your mask briefly into water, swirl the water around the inside of your mask very quickly and empty the water from your mask. A quick rinse will remove any excess defogging solution from the inside of your mask. You do not want to get defogging solution in your eyes, especially while diving, since it can cause stinging and irritation. If you don't want to use a commercially prepared defogging solution you have a defogging solution readily available and it's free, your saliva. Your saliva will prevent your scuba mask from fogging just as well as any commercial defogging solution. The enzymes in your saliva stick to the lens of your mask like a commercial defogging solution and you will never find yourself without a defogger while on a dive. 2. Never lay your scuba mask face-down on any surface. Salt, sand and grit will scratch the lens of your mask. Always place your mask face up when you are not wearing it or if it is not in its hard case. 3. Rinse your scuba mask in clean, freshwater after each dive and dry it thoroughly before storing it in its hard case. After a dive, your mask will be covered in a salty residue and/or dirt. This must be rinsed clean to prevent the silicone on your mask from degrading. Your mask must be completely dry before storing it to ensure the silicone stays clean and odor-free. 4. Always store your scuba mask in its hard case. If your mask did not come with a hard case purchase an after-market hard case. This will protect your mask from dirt and abrasives and protect it while traveling. Always store the case out of direct sunlight. Direct sunlight will break down the silicone after years of exposure. 5. Periodically repeat the toothpaste treatment to keep the lens of your scuba mask clean. A good rinse after each dive helps to keep your mask clean, but to ensure there is no residue or grit left on your scuba mask you must properly clean it on a regular basis."
Vision Mares Pure  Mask Logo
668 people viewed this question
Top Vision Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Vision Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
