Question about Aeris Snorkeling Bag
The right snorkel for me
How do I choose the right snorkel for me?
    Problem Solver:
  • 9 Answers
Snorkel must be comfortable in your mouth. Get a snorkel with a purge valve.This clears your snorkel from water. Get a mask that will fit nice, if your clostrophobic get one with a clear skirt. Finally, flippers. Try these on before you buy. these need to have a comfortable fit. If they dont i would reccomend boots for them. you can get them at all good snorkel shops
Posted on Mar 30, 2009
    President:
  • 2,712 Answers
"A snorkel must fit comfortably in your mouth, allow you to purge water out of the mouthpiece and hose quickly and help you to swim efficiently. But, the most important characteristics to remember when choosing a snorkel are its length and the diameter of its barrel. Snorkels must not be too long or too short. If a snorkel is too long it will be difficult to breathe because the barrel will fill up with carbon dioxide. Every time you breathe out carbon dioxide through your snorkel your breath must travel up and out of the barrel of your snorkel to allow you to draw oxygen back down the barrel and into your lungs. If your snorkel is too long you will only push a percentage of the carbon dioxide up and out of the barrel during your exhale. You will need to inhale oxygen before all the carbon dioxide has been pushed out; leaving the percentage of carbon dioxide entering your bloodstream higher each time you take a breath. This cycle could lead to suffocation. If a snorkel is too short it will constantly fill with water, requiring you to constantly force the water out of your snorkel which can be very exhausting. The inside diameter of your snorkel must be approximately three quarters of an inch or 1.9 cm. If the snorkel is thinner than .75 inches it will be difficult to breathe because there will not be enough room in the barrel for you to draw enough air into your lungs. This will cause you to breathe harder and rapidly, which could cause hyperventilation. If the barrel is thicker than .75 inches it will be too large and will be uncomfortable to use and attach to your mask. Learning to attach your snorkel to your scuba mask to make sure it is easy to grab and use is an important part of safe scuba diving practices. Snorkels are attached to the left side of your mask with a snorkel keeper. Snorkel keepers are either plastic or rubber and most use a post-hole closure. Each snorkel keeper is different and attaching your snorkel to your mask with a snorkel keeper requires practice. If you will detach your snorkel from your mask after each dive you should practice attaching your snorkel, as it can be a little tricky. Alternately, you can leave your snorkel attached to your mask if you are diving more than once in a day. "
Posted on Dec 01, 2008
Snorkel came apart in two pieces. Can I glue it?
Realize that IF you glue it, you might be inhaling the residue of the glue vapors, this is very dangerous (glue sniffing is illegal) not to mention EXTREMELY harmful.
Most glues these days bond at the molecular level forming a new bond to join the to parts.
I recommend getting a new snorkel. If you do decide to glue it, I would allow at least 48 hours to dry and keep it out in the open. Then after that time has elapsed, smell the snorkel, if there is any residue that down not smell like the original material, discard the snorkel.
Good luck.
Oct 12, 2010 | Aqua Lung Aqualung Impulse 3 Snorkel...
How do I keep my snorkel set clean?
Rinsing in clean water is all that's ever been required for mine. Store covered in a conditioned space between 50 and80 degrees F.
Jun 08, 2010 | Body Glove Snorkel Mask Fin Snorkeling Set...
We purchased an adult snorkel set at Sams club and my snorkel leaks at the joint at the end of the mouth piece. How do we fix this?
is it the rubber mouthpiece bit that connects to the snorkel tube itself??
if so, mine has a plastice tie wrap holding it firmly in place,
Feb 28, 2010 | Body Glove Snorkel Mask Fin Snorkeling Set...
I dont see why I should toss a $20 snorkel becaus it needs a $2 diaphragm. somebody makes these so they must be sold somewhere. I could use 8 right now.
I presume you're referring the the purge valve diaphragm. If so then on some brands they are available as a spare part, but they tend to be the expensive brands.
As you haven't stated the make and model which you have I can't offer any further guidance regarding spares, but with a little bit of ingenuity and an old bicycle inner tube it's usually possible to custom fabricate your own spares. Be very careful with how you fasten the centre of home-brew valves though as a poorly-engineered design can result in fastenings breaking loose and being inhaled.
Feb 16, 2010 | Tabata Usa Tusa Snorkeling Two Window...
Replacement part for snorkel attachment
its a plastic clip if i am correct. i have in the past used a rubber band, but you could go to a local dive shop, they normally have the rubber replacements for snorkels.
Nov 26, 2009 | Aqua Leisure Dolfino Tri-view Dive Mask...
I bought this snorkel used and put it in my bathtub last night and it filled with water. The lower chamber is filling to the point I can't even blow it out. Is there something I don't know?
From what you've described, you have a self-draining snorkel (at least it would be if working correctly). There will be a simple diaphragm valve at the lowest point of the snorkel, it's usually made of a silicone rubber disc and in use is held closed by external water pressure. It can also be held open if there is any grit or sand in it, if it is damaged or if it's simply hardened with age.
All you can do is clean it and make sure it seats correctly. If it has failed in any way or if the diaphragm is simply missing then buy a new snorkel as they don't need to be expensive.
There's a good reason that many divers still prefer a simple j-tube snorkel and it's because there is nothing to go wrong. I personally do use a self-draining snorkel but I'm careful to inspect and clean the valve before and after every use and always have a spare snorkel in my dive bag.
On an unrelated matter, if the snorkel has any kind of device on the open end to prevent water from entering then I strongly recommend that you remove it. They're restrictive to airflow and are potentially dangerous. There is no substitute for simplicity and for learning to use a snorkel correctly.
Jul 09, 2009 | Tabata Usa Tusa Snorkeling Two Window...
Dirty snorkel tube
If the mold is much you can leave the snorkel soaked in lemon juice or 50% isopropyl alcohol solution.
See also the suggestions below:
Caring for Your Mask, Snorkel, and Fins
What's the best way to clean new snorkel
Feb 14, 2009 | Integra Dacor Ii Dry Snorkel Lowest Price...
Clearing the Snorkel of Water
Step1 Make sure you are gripping the mouthpiece of the snorkel securely with your teeth. Step2 Exhale forcefully through your mouth. The majority of the water should be expelled from the tube. This method is commonly called "blasting" or "popping." Step3 Inhale gently at first in case there is any residual water. Blast a second time if needed. Step4 Continue blasting whenever water enters the snorkel.
Dec 01, 2008 | Aeris Snorkeling Bag
Snorkel need issue
Every scuba diver spends time on the surface while preparing to descend for a dive. A snorkel allows you to conserve energy by letting you keep your head in the water while swimming and enjoying the pre-dive sights without ever having to remove your head from the water.
Dacor goes up then right back down
one of the snorkel switches is bad if that not the problem i would then change the board but i would start with the switches on the snorkel motor
Sep 30, 2007 | Dacor Prefrence PRV36 Stainless Steel...
Aeris Snorkeling Bag Logo
813 people viewed this question
Top Aeris Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Aeris Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
