Question about ACCO Brands Apollo Bio-Filter Moisture System
Do I need a scuba regulator and if so, how do I know which one to buy?
    President:
  • 2,712 Answers
"Because the scuba regulator is such a vital piece of gear many scuba divers choose to buy their own scuba regulator instead of renting one from the dive shop. When a scuba diver has used a few different scuba regulators, on numerous dives, he will notice that they all have slightly different ""action"" - some feel looser or tighter, some will deliver air more forcefully, others will have a slight ""suck"" to them. The goal of all regulators is the same: to deliver air on demand at ambient pressure. Comfort with a scuba regulator depends on how the diver breathes; which is different for everyone. Though a helpful clerk at the dive gear shop can recommend ""the best"" regulators, from the most respected manufacturers, in truth no one can tell you which regulator ""feels right"", except you. Sponsor Links [what's this?] As a novice scuba diver renting or borrowing equipment from a dive shop always take note of what scuba regulator you are using and whether you like how it feels. When you find the one which makes your breathing feel effortless remember its make and model. When you decide to buy your own scuba regulator you will know which one to get. When shopping for a scuba regulator here are some things to consider: See our choices for scuba regulators * Ergonomic design and easy to hold * A purge button which is easily pressed even when wearing 6mm neoprene gloves * External controls which let you make fine adjustments to air flow * Non-corroding metals like titanium or chromed brass * Diaphragm vs. piston mechanics. Many divers prefer diaphragm regulators for its smooth movement and its moving parts are less * Balanced vs. unbalanced regulators. Almost all regulators are balanced. Do not buy an unbalanced regulator. * Always buy new. Do not pick up a cheap second-hand regulator; it may be faulty or reconditioned * Look for a warranty * Swivel joints on the second stage offer improved ease of movement * Hose should be soft and flexible "
Posted on Dec 01, 2008
I need a service manual for my mk11 first stage
To rebuilt a first stage regulator requires special tools a quailfied service technician should rebuilt it put in a o-ring in the wrong spot can be fatal at deep depths you can call scuba pro direct and they can assist you in finding a repair facility close to you are they can repair it .
Oct 01, 2013 | Scubapro MK11 Din First Stage Scuba...
I need the schematic for a Dacor 460 First stage. Anyone have one?
You should find what you're looking for below.
If not, let me know. I have the manual you need. It's Manual #2 which covers all the earlier 1st stages. dba4e3d1-8cc2-47a9-b4bd-6a027f82d10f.jpg
Sep 04, 2013 | Dacor Scuba Regulator Service Manual Pacer...
The cover plate on the second stage of my sea-air tri metal is cracked. Where can I get a replacement?
Did you regulator come to you like this or is this a regulator that you have had for awhile and dropped or something and it broke if you received it like that it is covered by warranty since the sea air has a lifetime warranty. XS scuba does not have replacement parts readily available that I know of thats how they get you its the same as mares you just have to send them back to be serviced or to and authorized dealer. As long as you did not break it intentionally you should be fine. I have broke reg covers on 4 of my Mares regulators and had them all repaired no problems hope this helps and safe diving
Dec 29, 2010 | Xs Scuba Sea Air Tri Metal Regulator Great...
My reg simply free flows when connected to the tank. Its the first time it has ever done this. Is this an easy fix, or should I start to worry? the thing is this reg is at least 10 years old so I don't...
Turn the regulator mouthpiece down
Blow air back into regulator
Make sure the sensitivity slide is toward the edge of the regulator
Turn the gas on quickly when the rig is mounted. Turning on slowly results in free flow
Jul 12, 2010 | Poseidon Odin/Jetstream Regulator
Hey guys, im confused... i want to buy my new diving gear and i have come to a conclusion between two packages... these are : Scubapro : 1st stage din/int Mk17/395 reg + Oct R295 + seac sub BCD (First) +...
Denx7d could have not said it any better i have about 1300 dives on my gear and still in good shape and have annual service on my gear now i am a certified repair technician for scuba pro these regulators they sell are the best on the market hands down
Jan 21, 2010 | Scubapro MK11/R395 Regulator SCUBA...
How clean the first Stage on my scuba regulator
Simple green an a toothbrush should work fine. For stubborn spots, soak in vinegar for 4-5 hours, if still not clean, then a mixture of water and automotive chrome cleaner (mild abrastive) and a toothbrush. Rinse well. If still not clean, consult your local Scuba repair shop.
Mar 27, 2009 | ACCO Brands Apollo Bio-Filter Moisture...
Cleaning my scuba regulator
If you are not trained in this it is best to take it to a licenced scuba shop and get them to do it. Much safer and better peace of mind. If you want to clean it yourself then go to the same shop and ask them to point you in the direction of a training organisation, often specific companys, and do the training first, get the right tools and get into it.
Dec 01, 2008 | ACCO Brands Apollo Bio-Filter Moisture...
Guidelines to Scuba Regulator Purchase
The scuba regulator is employed in an open-circuit scuba set. Said scuba equipment reduces high air pressure conveyed by the diving cylinder to the first stage and feeds breathable gas to the diver through the second stage's mouthpiece. Also called pressure regulator or demand regulator, the scuba equipment is one of the essentials to diving that determines breathing quality and inhalation effort during the dive. But given the different types of regulators and the pertinent design of its first and second stage components, how should a neophyte diver - or even a seasoned diver at that, choose a scuba regulator that incorporates user adjustment and delivers a venturi-assisted air flow in its features? Consider your diving purpose and frequency. Better yet, take note of the following criteria to guide you in your purchase: 1. The Scuba Regulator's Mouthpiece. Check the specifications if the regulator is outfitted with a patented orthodontic mouthpiece. This implies that it is ergonomically-designed to accommodate an overbite or underbite by the human mouth. An ergonomic mouthpiece helps reduce fatigue in the mouth and jaw area, particularly in the cruise of lower depths and extended dives. 2. User Adjustment Settings. There are optimally-designed scuba regulators that are outfitted with adjustment levers to therefore allow divers to finetune valve settings in order to provide the least possible inhalation effort throughout the dive. One notable scuba equipment is the Aeris AT 400 Pro Regulator that is equipped with an adjustable second stage. 3. Weight of the Scuba Regulator. Visualize yourself on a dive and using just any other type of scuba regulator. Is the regulator bulky to considerably increase drag and cause jaw fatigue or is it buoyant enough for you to carry around with your mouth? Lightweight scuba regulators use polycarbonate thermoplastics for its housing to make the scuba equipment compact, sturdy and corrosion-resistant that makes them fit for extended use. 4. Nitrox Compatibility. This entails an ocular inspection of the cylinder tank (Nitrogen and Oxygen proportions) and scuba regulator (Nitrox compatibility) specifications. As a matter of convention, most regulators are suited for nitrox mixture use out of the box; containing the standard, maximum proportion of 40% Oxygen (in terms of volume) but then again, there are gas mixes supporting leaner proportions of oxygen such as the trimix. Therefore, check if the scuba regulator supports the gas mixture configured for your diving cylinder prior to purchase. 5. No-Contaminant Feature. As much as possible, choose a diving regulator that has been manufactured using Dry Valve Technology (DVT). DVT operates through an automatic valve that prevents contamination of the first stage mechanism to thus prevent regulator flooding and the entry of moisture or dust particles. This likely improves scuba regulator performance and extends its useful life. 6. Air-Sharing Feature. This feature often associated with octopus regulators (used as a spare demand valve or alternate second stage) will prove to be most helpful during diving emergencies such as a free flow or during diver rescues. High performance octopus regulators such as the Aeris Gyro Octopus Regulator are designed lightweight and with air-sharing feature, while sporting an inline swivel for convenience mounting and flexibility
First and second scuba regulator
The scuba regulator has two parts: a 1st stage and a second stage connected by a hose. The 1st stage connects right to the tank; the 2nd stage is the contraption behind your mouthpiece. Both have an important function in regulating air flow throughout your scuba system.
ACCO Brands Apollo Bio-Filter Moisture System Logo
214 people viewed this question
Top ACCO Brands Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an ACCO Brands Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
