Question about Flow M9 Snowboard Binding
Snowbard bindings adjustment
Hey guys. Need to adjust my new bindings, how do I do it?
  • sdfasfd545 Dec 02, 2008
    i too
  • Anonymous Jan 01, 2009
    how do you adjust the bindings?
    President:
  • 2,712 Answers
"With everyday use, the screws, nuts and bolts that hold the highest stress areas together tend to loosen up. Consequently, they need to be tightened regularly to ensure that a strap doesn't fall off and get lost. However, not every Mountain Resort provides tool stations, so it's important to have a Snowboard Tool within reach (preferably in your pocket) at all times. Remember, a snowboard tool is a small investment that will definitely pay off over years of riding. Also, with the standardized insert pattern of snowboards, and with the built-in adjustment capacity in most Bindings, Mounting and Adjusting Bindings has become simple quite a simple task. To be able to do this, make sure you have a screwdriver and a wrench or two. Also, it would be a plus if you have some basic knowledge about the stance width, stance location and stance angle. The distance between your front and rear foot is the Stance Width. The basic stance width is roughly the length of your shoulder-width apart (about 30 per cent of your height). The location of the center point between your Bindings relative to the center of the snowboard is the Stance Location. Conversely, the angle of the Bindings across the snowboard's longitudinal axis, wherein zero degrees represents a line that is perpendicular to the snowboard's length, is the Stance Angle. * Forward Lean For starters, check your board's Forward Lean. The forward lean is the amount of forward angle on the highback support. For more leverage and more responsive heelside turning, add more forward lean. By adding forward lean, you also force your knees to bend, consequently ensuring a good riding stance. Still, too much forward lean makes your knee bend too much. Over bending your knees put pressure on your quadriceps muscles and reduces your ability to turn easily. So don't overdo it. You can usually adjust the forward lean in soft-boot Bindings by changing the position of a plastic stay behind the highback. * Rotating the Highbacks You can easily rotate your Bindings' Highbacks if your bindings have slots on the hinges where the highbacks are fastened to the binding's baseplate. To make your heelside turning more responsive than when it is angled along with the baseplate, adjust your Bindings in parallel with the Snowboard's Heel Side Edge. You can do this by loosening the bolts and rotating the highbacks. * Adjusting Strap Position Generally, this involves unscrewing the straps from the baseplate and moving them forward or backward on the Bindings. To improve control, move the straps higher up on the foot. Conversely, move them down lower to increase flexibility. Make sure that the toe strap is resting around the base of your toes and is securely holding down the tip of the boot. Shorten your straps if you find yourself pulling on them for a snug fit. You can do this by fastening the straps to the baseplate further along the length of the strap. Most straps already have extra holes for this adjustment."
Posted on Dec 01, 2008
How do I adjust parking brake
If Disc brakes jack up wheels , make sure the cable is not binding or frozen , pull hand leaver on three clicks, adjust cable till brakes just start to bind, release hand brake and check the wheels are free to turn. Drum brake check cables are free, back off cable till slack, check lining to drum adjusters are free and adjust if need be, pull hand brake on three clicks, adjust cable so brakes just start to bind release hand brake and make sure the wheels are free to turn ,
May 27, 2015 | Cars & Trucks
Binding adjustment
There is (should be) a screw visible on each of the toe and heel pieces when looking down from directly above. That screw will adjust the height of the piece that clamps down on the top of the tabs on the heel and toe of your ski boots. For proper height measurement, use a credit card (or similar thickness card) and make sure you can somewhat freely slide the card side-to-side under your boot when it is in the binding and clamped down as when you are skiing. Too much play, and you will feel a sloppyness while skiing. Too little and you risk the binding not releasing properly caused by stiction. You can find demonstrations on YouTube also.
Apr 04, 2014 | Fischer Skis Fischer RC4 Z 17 Freeflex...
Clutch snapped
adjust cable at both ends
Feb 28, 2014 | 2007 BMW F 800 ST
Hey guys i have a fzr 250 its a 3ln year 1994 i
If your clutch is automatic, then you need to ajust the freeplay.
On your clutch cover you have the small bolt with a screwdriver head, and a locknut.
You loosen the locknut, and then turn the adjuster bolt with a screwdriver clockwise until you feel it stop, now back it of 1/8th of a turn(counterclockwise).
While holding that adjuster bolt in position, tighten the locknut and your freeplay is adjusted.
You should notice a nice smooth shift while riding.
If your clutch is manual, then adjust your clutch cable length at the handlebar.
If the hand lever feels tight after you adjust the cable, thats because you have new clutches & springs. New ones are stiff at first.
If your clutch adjustment is fine from the start, then you have transmission problems and that would have to be inspected to be able to correctly diagnois which part is bad.
It could be just a broke shift arm.
Dec 07, 2010 | Yamaha FZR 250 R Motorcycles
Atomic 4tix 310 binding toe adjustment.
Did you ever figure out how to adjust the toe piece? I am having the same problem
Mar 08, 2010 | Sport & Outdoor - Others
Why does my aprilia rs 125 clutch pressure plate keep breaking?
if your not tensioning them properly and evenly they will do that
have you also replaced the springs?
you really need the manual to do this if you are not familliar with the procedure.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 13, 2009 | 1999 Aprilia RS 125 Extrema
HEY GUYS WHERE CAN I BUY THAT WATCH BAND ADJUSTMENT TOOL
You can buy it on eBay. Choose JEWELLERY AND WATCHES, then click on TOOLS. There are plenty of watch band adjustment tools.
Rate me, please.
Aug 06, 2009 | Fossil CH2331 Wrist Watch
Binding brake
hand brake cable adjuster lives under centre console at rear 10mm spanner required unadjust this and then remove rear drums to adjust linings so they just drag on drum then go back and adjust cable in car
Jun 03, 2009 | 1999 Daewoo Lanos
Rear brake replacement
hi to get the pads in you did screw the calipers pistons all the way back and you should have backed the hand brake cable off as well then adjusted the cable afterwards problem with self adjusting calipers is you can adjust the handbrake cable and the brakes are ok until driven then they can bind so try backing the adjustment off on the handbrake [should really change both calipers as a pair to keep the axles brake balance but this is not anything to do with the brakes binding] best of luck paul
Oct 11, 2008 | 2003 Audi A6
Jet ski
too rich, adjust thehigh idle screw
Jul 06, 2008 | 1997 Chevrolet Cavalier
Flow M9 Snowboard Binding Logo
1,465 people viewed this question
Top Flow Winter Sports Experts
Arnie Burke
Arnie Burke
Marvin
Marvin
vtrktrmn
Are you a Flow Winter Sport Expert? Answer questions, earn points and help others
