Question about Advanced Elements Straitedge Canoe
Popular canoe material
Why is ABS a popular canoe material?
    President:
  • 2,712 Answers
ABS, or acrylonitrile butadiene styrene, has earned a reputation among canoeists for near indestructibility. It is one of the most damage-resistant canoe materials in use today. Badly dented hulls, even those that have literally been bent around a rock, have been restored to their original shape, without cracks or leaks, by the application of heat. Canoeists have dubbed ABS craft "rubber boats" and with good reason. Since the material tends to flex slightly, it is forgiving, tending to slide over rocks, or bounce off them, with little more than a surface scratch. Some of its limitations are marginal buoyancy - it will float when capsized but just barely, so don't expect to climb into a swamped ABS canoe to await rescue, or to hand-paddle it ashore. Also, when wet, the floor of an ABS canoe is slippery, which can prove troublesome in rapids. ABS canoes require little maintenance and can be left outdoors all year - although ones with wooden gunwales and peaks should be propped to avoid ground moisture. ABS canoes also require special epoxy resins for repairs.
Posted on Dec 01, 2008
    Novelist:
  • 269 Answers
I have heard that ABS will no longer be manufactured in sheets for canoe building. Too bad, I have two and they are tough boats.
Posted on Sep 14, 2013
In my experience, cracks in ABS boats are irreparable. Cracks bonded with a specialized epoxy open back up after some inevitable flexing during use. I have seen some successful, but ugly, repairs done by "sewing-in" a patch.
Posted on Jun 23, 2009
Abs and brake lights coming changing front brakes on 2008 Chevy silverado
Check wheel speed sensor that it was not damaged during brake job. Once the the speed sensor is right, you may not need to rest Module, it will reset upon driving.
Mar 10, 2015 | Thule 2008 Chevy Silverado - Extended cab...
Approx 2 wide by 7 inch long gash in starboard side at the waterline
That's a pretty serious size gash to repair. I'd contact Old Town Canoes to see it that material can be plastic welded and if so, where to get the materials. Good luck.
May 09, 2011 | Old Town Predator K140 Angler...
My tripper has the bow worn down by constant running on ground and hitting rocks. What materials do I need and how do I repair it?
Try bullseyetradingpost.com they were working on a skid plate for poly plastic canoes e-mail and ask for help! they were very helpful with solving a few seat problems for me.
Aug 05, 2010 | Old Town Tripper Canoe (17' Royalex(R))
How do I fix my badly faded canoe, colour is red and only faded down one side?
I would recommend painting it with a type of paint that would adhere to the material the canoe is made of whether that is aluminum, fiberglass, etc. My guess is that you have been leaving only half of the canoe in the sun, so when you store the canoe, either keep it in a shaded area or cover it with a tarp to keep the sun off.
Jun 06, 2010 | EA Sports Pelican Int'l. Colorado 15' 6"...
How to repair an open split in a royalex canoe
key the surface using sandpaper to make it rough, and apply a fibreglass matting repair. They are available in kit form from canoe outfitters, often sold a kicker plates.
The application is very simple, just follow the kit instructions.Be aware though that the boat has to be perfectly dry before you start. (leave it indoors for a couple of days first) I often use a hairdryer on the surrounding area for a few minutes beforehand to ensure no moisture is present. Be careful not to get the area too hot though, you don't want to melt your boat!
Once the kit is applied and has set you can smooth the edges down with a sander.
Aug 09, 2009 | Boating
Canoe has damage on the front bow.
Bondo would probably work.
Also, you could laminate a few pieces of something like vinyl siding/facia board over the hole. If the canoe is ABS, the vinyl siding cold be "welded" / fused to the ABS with PVC primer & solvent/cement.
May 27, 2009 | Coleman Cable Coleman Inflatable Boat...
Wenonah Sundowner ABS Canoe repair
no actually you can't.. but heres an idea. get a couple pieces of gum, and flavor you like, and chew it up till its super duper sticky, then take it out of your mouth and stick it in the hole :) and thats its done,
Apr 12, 2009 | Boating
Cracked thule box
www.recrepair.com is what Thule recommends you use to seal your crack :) -- it is an ABS patch kit and is waterproof as it is used for permanent canoe and kayak repairs. it is NASA designed.
I am using it on my Atlantis 1800.
Mar 30, 2009 | Thule Winter Sports
Small crack in hobie kayak
what is the canoe made of... it may not look pretty but fiberglass will work.... you can sand and paint it later as well
Mar 26, 2009 | Hobie Mirage Outfitter Kayak
Advanced Elements Straitedge Canoe Logo
457 people viewed this question
Top Advanced Elements Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Advanced Elements Boating Expert? Answer questions, earn points and help others
