Question about Advanced Elements Straitedge Canoe
Aluminum canoes What about aluminum canoes?
    President:
  • 2,712 Answers
Well-made aluminum canoes are rugged and most dents can be punched out. They are the ultimate no-maintenance canoe. Even when left outdoors all year, neither rain nor snow affects them and they will not take on weight with age. They are rigged with flotation air tanks or foam compartments to render them unsinkable. On the downside, aluminum canoes are noisy, tend to cling to (rather than glide over) rocks, and conduct heat and cold. Most aluminum canoes carry their beam well forward and aft so that they push rather than cut through the water. This hull design, however, makes them initially more stable and increases their carrying capacity.
Posted on Dec 01, 2008
  • 76 Answers
Aluminum canoes can be very heavy, both in the water and out.
Posted on Aug 05, 2010
How do you replace gunwales?
Depends on the type of canoe and construction. Any answer depends on that. It is basic woodworking skills (riveting on factory parts if aluminum or vinyl).
Sep 08, 2014 | Boating
Tip
How to solder Aluminium and Copper
To solder aluminum and a copper wire? You do not need any special tools or equipment - just use the standard soldering iron, traditional SnPb solder, grease (lubricant) and sandpaper.
Apply grease to the soldered aluminum surface, regrind this "greasy" surface with sandpaper so excite the surface layer of aluminum oxide (Al2O3). Grease prevent air going to the purified aluminum and its rapid re-oxidation to the Al2O3 and lets to adhere molten SnPb solder to aluminum. Once the aluminum surface is covered with a layer of SnPb solder ("tinned"), clean it with a degreasing agent out of grease and may be normal solder to another "solder-tinned" material - for example, a copper wire.
on Feb 12, 2015 | Welding Tools
I have a coleman canoe about 1978ish model 5907-719 17 ft. I can't find a replacement center thwart. Any ideas?
Post a picture of what it looks like, if you can.
If it was wood, then just make one. Else make a wooden one to fit where the Aluminum would have been. That is the usual thing to do with older boats, and cost-effective.
If you really care about the canoe, seek out an old one for sale "well used" and buy it as a replacement or for parts. An elderly Colman is not worth a lot, so don;t spend a ton on fixing the first one.
May 24, 2013 | Coleman Boating
Can I use an all aluminum cookware pot to cook pork in the oven?
Yes! you can use aluminum cookware in your oven. If you are using an aluminum pot of best brand, it would be safe for you to use it. You can also use cookwares made up of various other materials.
I also use aluminum cookware which is GSI Outdoor Hard Anodized, as it is light weighted and made of high-quality aluminum. Apart from these features, some of its other features are, great versatility, safe dishwasher, produce tasty food, etc. You can get more detail by clicking here.
Sep 11, 2010 | Microwave Ovens
How do I fix my badly faded canoe, colour is red and only faded down one side?
I would recommend painting it with a type of paint that would adhere to the material the canoe is made of whether that is aluminum, fiberglass, etc. My guess is that you have been leaving only half of the canoe in the sun, so when you store the canoe, either keep it in a shaded area or cover it with a tarp to keep the sun off.
Jun 06, 2010 | EA Sports Pelican Int'l. Colorado 15' 6"...
Radiator leaking, need to know what type of radiator?
the easiest way to tell if it is Metal or Aluminum is with a Magnet if it sticks its metal if not then its aluminum otherwise it may be both as the ribs are usually aluminum and brass for the vent-tubes
however if it is all aluminum it should be all the color silver
Dec 29, 2009 | 1998 Jeep Grand Cherokee
Colman Canoe Bracing Gone Loosing Shape
Your going to have to replace the bracing, the poly plastic your canoe is made of needs it to retain it's shape. If its an older one the bracing should be made of aluminum tubing, you can buy this then cut to size shape and fit to your canoe. If its a newer one say made by pelican {they took over for coleman} its made of plastic this will prove to be harder to do. Either way its a big job
Nov 08, 2009 | Boating
I am looking to find a cheap second hand canoe for me, my husband and 10 and 7 year old to use on the lakes of MN. I have been offered an aluminum Grumman for 400, and I do not know if it comes with...
Hi. You will enjoy the 375 dollar fiberglass canoe, especially with all the accessaries! I don't think you could find a better price that would fulfill all your requirements. Fiberglass is easy to repair if damaged. All other surfaces are not and can become unrepairable! Fiberglass is also low maintainance but I would recommend storing it out of the sunlight. When you go for the purchase ask the previous owner if he would mind if you fill it up with water? This is one way of checking the integrity of the hull. My canoe has three seats. If you canoe has no seats sit on your lifejackets and it helps keep any supplies or you bum drier. Have fun! I'm getting ready to write some stories about my latest canoe trip. Check out my blog at http://www.captcookrules-robbin.blogspot.com/ Enjoy your canoeing
Jun 27, 2009 | Boating
How do iI chose a fishing boat?
There are three styles of regular fishing boats; deep v, regular v or modified v. The v determines how well the boat cuts through the depth of the water. The deep v is better suited for large lakes because they can handle heavy waves better. Regular "v" is more appropriate for smaller lakes and a man made body of water. As the water is not as deep and the waves are not as heavy, this type of boat is able to handle the situation. The modified v is the most popular version. It is capable of handling speed best. Most fishing boats on the market today are made of fiberglass or aluminum. What is best for your fishing situation? Do you want to fish in large lakes or small lakes? The options are endless. There are several classes of fishing boats for different situations. All purpose fishing boats are great for your basic fishing needs. This type of boat has space for some bench seats, fishing gear and a simple steering station. They are made of either fiberglass or aluminum and are between 15 and 20 feet long. Another type of fishing boat is a bass boat, which comes fully equipped with space for rods and fishing gear. The boat is fully built with electronics and livewells. This boat also is made out of fiberglass and aluminum. The advantage to this type of boat is it is made especially to catch bass, fast. The third type of fishing boat is the center-console. It allows a fisherman to angle from any place on the deck. The control center is located in the center. Depending on the size of the boat they can be used offshore as well as near. Flats boats are mostly made up of fiberglass. The advantage of these boats is they allow easier angling access to saltwater flat fish. Another advantage it has is a poling platform that allows for fish spotting. Finally, a casting deck allows the angler to keep control. This makes this ype of boat convenient for fishing. The final category of fishing boats is the fun boat because it combines the motor of a yacht and the functionality of large a cockpit to work trophy fish and bring them on board. If ou are a fishing fanatic then it is important to have all the things that you need to make your fishing trip a success. Fishing boats are definitely the finishing touch to a nice fishing trip.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Advanced Elements Straitedge Canoe Logo
804 people viewed this question
Top Advanced Elements Boating Experts
Gordon Richard...
Nikki Lovins
Nikki Lovins
Level 1 Expert
Are you an Advanced Elements Boating Expert? Answer questions, earn points and help others
