Try this steps:
1. turn off your phone, remove the battery and also remove the sim card and memory card from the phone.
2.put the the battery back on
3.press and hold * , call , 3
4.while pressing those 3 buttons, press on/off button until u see the format wizard on the screen.
gug luck
Testimonial: "thankzzz"
dude........................nothing happened........by the way what's call button......????
i just got back ol... the call button is the button u press when u receive a call... indicates with the green phone icon... the steps i told you is soft reset. if you still having trouble with the soft reset, try hard reset by pressing *#7370# and then press the call (green phone icon) button. when it asked for your security number, just insert 12345. you might want to charge your phone before u try the hard reset because if the phone had interupted while performing the hard reset, it will be more difficult to fix your phone... good luck, hope this will help you.
glad i could help....
*#7780# try this
Hi the easiest way to format your E5 ,just type *#7370# and enter the security code 12345 or what you have made.This is the fastest solution.
SOURCE: how to format the nokia 5300 phone memory
just remove your MMC n just type *#7370# n will ask u the security code.type it out (default code is 12345 )
NOTE: battery must b full, else if format is disrupted by low batt, consequences will b disastrous
I heard the code *#7780# works too, pretty much the same i think.
but back up everything before doing this onto ur computer or MMC.. dont forget to rate me.. thank you sir
SOURCE: I want to formate my phone memory. give me the formating code
A magic word : PLEASE.
In the setting menu scroll down to security then factory settings and choose restore. Or try *#7370#send.
SOURCE: how to format phone memory of nokia 3110c
Actually I want to format my phone memory of Nokia 3110c as whenever i try to enter confriguation setting for GPRS it gives me errot target memory is full, Inspite there is nothing there in memory.
