Question about Endurance TF3i Folding Treadmill
Treadmill adjustment general lines? - Endurance TF3i Folding Treadmill
  • Anonymous Dec 31, 2008
    I have the same problem (treadmill needs tightening) but i've misplaced the Allen wrench that was included. Do you know where i could possibly purchase another Allen wrench? Is this something that can be purchased at a hardware store? Thanks for any help.
    President:
  • 2,712 Answers
"The best treadmills are those that provide you easy access to belt tracking. But, even the best treadmills with the most easily accessible belt tracking are also susceptible to stretch slightly under initial use. That is why it is important that you adjust the tread belt every so often to keep it away from stretching. Most manufacturers include the Allen wrench (a tool consisting of a hexagonal head and an L-shaped bar) in the package when you buy a treadmill from them. Use it to tighten both the belt adjustment screws clockwise. If your manufacturer did not supply you with an Allen wrench, use another of the right size. A ¼ turn, clockwise should tighten treadbelt if it has loosened. The screws for belt adjustment are usually located at the rear end of the treadmill. Some belts do require looser running than others so don’t be surprised if your treadbelt is a little loose even when you haven’t actually used it. Check the user’s guide before making adjustments just to make sure that whatever you are doing is correct. Moreover, be sure to keep the belt running at a low speed of around 3 mph when adjusting the belt tracking. This is the ideal speed when making any adjustments with the screws. Maintaining your treadmill is necessary to upkeep it's performance and looks. A little bit of adjustment here and there can make your treadmill a life long companion. "
Posted on Dec 01, 2008
Belt keeps slipping on treadmill
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Apr 01, 2014 | Life Fitness 91Ti Treadmill
9.31 precor error 26 and loud noise
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if
Jan 25, 2014 | Dmm Vision Fitness T9500 Treadmill
Adjust belt side
Dec 19, 2013 | Precor 9.21 Treadmill
Precor treadmill err26
Model: All Models
Recommended Action:
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Dec 16, 2013 | Exercise & Fitness
How do you adjusting the running belt on precor 9.1 treadmill
Mar 13, 2013 | Precor Exercise & Fitness
Precor Treadmill 9.21si Error Code 26, what does it mean
Model: All Models
Recommended Action:
Sep 07, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Speed error 26
Model: All Models
Recommended Action:
May 18, 2011 | Precor 923 LowImpact Treadmill
How do i tighten the treadmill belt it is slipping
Here is a written tutorial on adjusting a treadmill belt. I would also recommend searching YouTube for some treadbelt adjustment videos. The videos will be for specific brands that may be different than yours, but the images may help give you a general idea.
Jan 20, 2011 | Proform 615 Treadmill Walking Belt
What does Err26 mean?
Model: All Models
Recommended Action:
Jan 20, 2011 | Precor C956 Treadmill with Cardio Theater...
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Endurance TF3i Folding Treadmill Logo
880 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
