Question about Gaiam Walking Fit Kit Pedometer Intermediate
Bad counting Why are my heart monitor and my pedometer giving different calorie count readings?
    President:
  • 2,712 Answers
No, you're not doing anything wrong. I would trust the heart monitor, which gives you a better idea of what YOUR body is doing and not what the AVERAGE body is doing. Most pedometers also cannot distinguish running and walking, which have durastically different calorie requirements. It is most likely calculating the calories burnt if you were walking, not running.
Posted on Dec 01, 2008
When I took my blood pressure SOMETIMES there's a heartbeat symbol next to my pulse reading, but SOMETIMES NOT! What does that mean and what the difference?
If you give me the make and model I can try and find your instruction manual. Reply as a COMMENT.
Blood pressure monitors can also give you your pulse rate. When the heart symbol is there, it has found it and is counting and when the heart symbol is missing it hasn't. This would normally be caused by the cuff not being placed on the upper arm in quite the right location.
Apr 27, 2016 | Health & Beauty
Lost instruction manual for pedometer I want to reset it
Instructions 1. Press the "Mode" button until you advance to the "Step Count" feature. 2. Hold the "Reset" button for three seconds. A screen will appear asking you if you wish to reset. 3. Press the "Start/Stop" button to select "Yes." 4. Press the "Mode" button to continue and return to the pedometer mode. You have now reset a New Balance sport pedometer.
Oct 06, 2014 | Exercise & Fitness
Need instructions for voice zone he9965
How do you turn the volume down on the radio? Is there a built in volume control.
Mar 04, 2013 | Voicezone Talking Calorie Counting...
My polar heart rate monitor counts the heart beets for quite a while before it gives me the heart rate as a number it may be up to one hour before it gives me a mumber.
I would go to Polar for a definitive answer but your monitor may not be making a good contact with your body. Therefore the reception of your heart beat is constantly starting over and can't give a reading fast enough. Try adjusting how you wear the monitor and see if it makes a difference. There is a battery in the chest strap also. The new ones have to go to Polar to get replaced unfortunately. That is another possibility.
Nov 02, 2011 | Polar T31 Transmitter and Belt Set
Lost instruction and can't work how to get calorie count to start
In my tips and tricks page is a link to get a new manual.
If you have all of your settings correct for you (ht, wt, etc.) then all you should need to get a calorie count is heart rate and starting an exercise set. It has to be on and measuring to provide calories.
Mar 25, 2011 | Polar F6 Heart Rate Monitor for Women
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
The heart rate function has turned off. So the calorie count won't work. Everything else is working fine. It happened about four days ago. I have lost my owners manual.
Press and hold the reset button, for 5 seconds, while in Time mode. this will reset the heart monitor and the symbol will reappear on the screen.
Nov 26, 2010 | Sportline 915 Solo Heart Rate Watch
Polar F6, stopped counting calories and stopped showing heart rate. Buttons will not work and it reads Calorie? at the top
You will have to go to Polar for this problem. Sorry.<br /> <a href="http://www.polarusa.com/us-en/">http://www.polarusa.com/us-en/</a>
Aug 26, 2010 | Polar F6 Wrist Watch
My Garmin 305 wont record calories when I'm in the Gym. I select the "Other" sport mode, the little guy skiing, and It doesn't recored or even register calories? It records during my Jog sessions while...
The 305 uses distance to calculate calories. They sell a "foot pod" that you can use indoors, and that will count your calories by calculating the distance you have traveled. The problem however, is that using distance to calculate calories is so inaccurate! The calorie count that the 305 provides is almost always WAY too high. Other heart rate monitors use heart rate to calculate calories burned, and it is a much more accurate measure. My garmin thinks i burned 700 calories an hour today while i was snowboarding, and, while that would be nice, there is NO way it's true!!
Dec 17, 2007 | Garmin Forerunner 305 GPS Receiver
Gaiam Walking Fit Kit Pedometer Intermediate Logo
208 people viewed this question
Top Gaiam Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Gaiam Exercise and Fitnes Expert? Answer questions, earn points and help others
