Question about Body Solid Cam Series Ab/Back Machine
Saftey rules What are the general saftey rules while using Arm and Back Machines?
    President:
  • 2,712 Answers
There is a risk assumed by all individuals who use this type of equipment. To minimize risk, you must follow these rules:1. Inspect equipment before each workout. Check that all nuts, bolts, screws and pop pins are in place and fully tightened. Also, before use, check cables for signs of wear. Replace all worn parts immediately. Never use machine if any parts are damaged or missing. FAILURE TO FOLLOW THESE RULES MAY RESULT IN SERIOUS INJURY. 2. Keep clear of cables and all moving parts when the machine is in use. 3.Always make sure all Snap Links are closed when doing any cable/pulley/strap exercises. 4. Exercise with care. Perform your exercises at a smooth moderate pace; never perform jerky or uncoordinated movements that may cause injury. 5. It is recommended that you should workout with a training partner. 6. Do not allow children or minors to play on or around this equipment. If unsure of proper use of equipment, call your local Body-Solid distributor or the Body-Solid customer service department at 1-800-556-3113. 8. ARNING: Consult your physician before starting your exercise program. For your own safety, do not begin any exercise program without proper instruction. Including maintaining the equipment the owner’s responsibility is also to: 1. Be sure to always provide adequate supervision to all end-users. 2. Be sure to instruct all end-users of proper usage. 3. Be sure all supervisors and personal trainers who instruct end-users on equipment use are properly trained and know the function and importance of every adjustment and setting. Also, be sure these trainers provide proper instruction to end-users on the fundamentals of strength training.
Posted on Dec 01, 2008
My troy bilt tb130 lawn mower won't start even after I changed the spark plug what could be wrong with it ?
Here is the general rule of thumb...if it has spark, compression and gas it should run. So, I would roughly check compression..does it pull normally with some resistance? If it does it probably has enough compression. Does it have spark? take the plug out but leave hooked up to wire and pull to see if there is a spark inbetween the little "hook" and the center of the plug. MAKE SURE YOU HOLD THE SAFTEY BALE IN ON THE MOWER HANDLE (SAFTEY SWITCH). It will pull like it has no compression because the plug is out. Does it have gas? take off air filter and see if you can see any wetness (gas). If it is completely dry it probably isn't getting any gas. Either the screen is plugged in the tank or the carb is varnished up from sitting too long. If you smell the gas and it smells different that means the gas is probably old and the carb will need cleaned out (not always tho). That is another story but not that difficult...
Aug 11, 2014 | Garden
The dryer runs, but there is no heat.
gas or electric dryer theres a white and black saftey on the back just replace that saftey
Sep 07, 2011 | Dryers
Where is the neutral saftey switch on a 1998 Pontiac grand am se? the motor is a 2.4 ltr
Most vehicles with a manual it's a little button your clutch pedal arm contacts to allow solenoid to power starter. Look at pedal and find the button it contacts. Often the piece breaks off. I've used electrical tape and 2 nickels on many vehicles. Just tape it on to the pedal arm where it contacts button.
Sep 03, 2010 | 1998 Pontiac Grand Am
What is a code E2
kds e2 means lid switch is not being engaged .remove rear top cover .2 phillips screws .3 snap clips use flat blade screw driver to pop cover .look at rear of lid (door) right side plastic arm part of lid snaped off replace lid part xqb5526f.1.3-3 check saftey switch manually over ride switch as a test .if machine spins change lid if switch broken as well change both .switch # xqb550.1.6
Aug 10, 2010 | Avanti Top Load Washer W797
Lowering back seats in BMW 320 coupe
that is not done for saftey reasons. the cars design meets the requirements for all saftey regulations around the world. nobody can help you legally here
Feb 21, 2010 | 2004 BMW 3 Series
Cannot remove key
saftey switch at gear shifter may be at fault. should be a plastic plug below key in column. remove plug and insert small screw driver to override saftey switch and turn key back to remove.
Nov 27, 2009 | 2005 Pontiac Aztek
My tractor only stays running if i hold the key on if i put it in gear it shuts off i replaced the neutral saftey switch but it did not help
sounds like a faulty blade saftey switch or the operator presence switch has failed, possible saftey interlock relay. hope this helps
Nov 23, 2009 | Garden
It level and still jumps around we had a repair man come last week to put a clutch or something in and it's done this ever since I can't even use it
THERE IS NO CLUTCH IN A WASHING MACHINE GET HIM BACK OUT AND ASK HIM TO UNDO WHAT HE HAS DONE , GET A SPRIT LEVEL AND CHECK THE LEVEL OF YOUR MACHINE IF IT IS LEVEL AND STILL JUMPS AROUND CHECK THE SAFTEY BOLTS HAVE BEEN ALL REMOVED THEASE ARE FOR SAFTEY TRANSPORT OF THE MACHINE AND ANY LEFT IN COULD CAUSE THIS .
Oct 25, 2009 | Washing Machines
Change the front wheel bearings on a 2005 taurus
Remove wheel
Remove axle nut
Remove outer tie rod nut
Leave outer tie rod nut on 3-4 threads
Hit spindle area where tie rod is mounted very hard with a large hammer (wear Saftey glasses)
The tie rod should loosen up and you remove it off spindle.
Remove lower ball joint nut
Leave nut on 3-4 threads
Hit spindle area where ball joint mounts (wear saftey glasses)
Carfully pry down the lower control arm too remove ball joint from arm.
Press in the axle towards the trans. out of the wheel bearing.
Place a piece of wood between the shock and inner fender to give yourself room to work.
Remove the three 15mm bolts that hold the wheel bearing on.
Hit wheel bearing out with hammer (wearing saftey glasses)
You may need to break a sweat on this part. Somtimes they are rusted in.
Be carfull not to damage the ABS sensor.
Reverse procedures to install
Sep 08, 2009 | 2005 Ford Taurus
Netural saftey switch is bad
there is no neutral saftey switch... it is incorporated into the trans range sensor, which is on the side of the trans, hooked to the gear selector cable...hope this helps and good luck
Jul 07, 2009 | 2000 Ford Expedition
Body Solid Cam Series Ab/Back Machine Logo
238 people viewed this question
Top Body Solid Exercise & Fitness Experts
Howard
Howard
John
Tom Chichester
Are you a Body Solid Exercise and Fitnes Expert? Answer questions, earn points and help others
