Question about Kenmore 74842 Gas Dryer
Gas smell from dryer
I have a stacked washer/dryer. When in use the dryer emits a gas smell which is particularly strong by the outside vent. The clothes have been taking longer to dry recently and the last load did not heat at all. The machine is approx. 9 years old.
  • 2 more comments
  • bluelight286 Dec 20, 2007
    my frontload Kenmore dryer is only three months old and towels, especially, come out smelling like gas. The vent is cleaned after every load and the vent line is clean. It has been doing this since we hooked the dryer up and thought it was because it was new. Now, I am sure it is not.
  • oneelkarcher Jan 20, 2008
    I think I have the same problem with my Kenmore gas dryer. I checked the venting, and have great air flow to the outside vent. But when cheking this vent, with the dryer on, I noticed an odor of natural gas. I was getting some heat still in the dryer, but not much
  • Anonymous Mar 12, 2014
    I have a 2012 Maytag Brovos gas dryer that is drying fine but giving off a burning smell so strong that you can't wear the clothes. I checked the exhaust and it is clear.
  • Anonymous Mar 19, 2014
    Over time it was taking longer and longer to dry a load of clothes. Recently we noticed the heat was completely out. The clothes still tumble but that's it.
    Problem Solver:
  • 18 Answers
Your igniter needs to be replaced.
Posted on Feb 04, 2007
SOURCE:
My washer is emitting a sewer like smell. what is that from and what do I do? It is a stackable
Hi from retired Englishman in SW France @ 17:36 Friday afternoon.
Does the water vent/drain into the same plumbing as a sink? If so I definitely suspect the sink u-tube needs a flush-out!
Hope this cures it!
John C
Feb 04, 2011 | Whirlpool LTE5243D Top Load Stacked...
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
There is a strong oil smell in the dryer
If you have recently painted or varnished inside your home the fumes in the air can create a hydrocarbon type smell in your dryer. This should stop as soon as the house is aired out.
Oct 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
Neptune dryer smells like kerosene!
The smell you are referring to is being caused by aldehydes. The gas burner has incomplete combustion is smothering. Make sure the moisture vent and pipe are not restricted. Try running the dryer with the moisture vent disconnected and see if the problem continues and make sure air flow thru hose is good. Also check outside where the dryer vent exits and make sure there is plenty of air flow. This particular dryer has an inducer fan that pushes the air to the burner and a blocked/plug vent will cause this. You may have to dis-assemble the dryer and inspect the burner compartment for lint build up and restrictions to burner compartment.
Sep 08, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer won't heat after a move.
Make sure the vent is not blocked. Run the dryer and feel for a strong air flow at the vent outside. The most likely cause is flexible vent hose used on the dryer is squeezed behind the dryer, blocking air flow. Don't use flex hose. You may have a lot of built up lint in the dryer vent pipes also, which would need to be cleaned out. Also, make sure you are still using the same type of gas. (natural vs. LP) If different, dryer would need to be converted for proper opperation.
Jul 19, 2009 | Dryers
Frigidaire Gallery Dryer Needs Two Cycles to Dry Clothes
A dryer needs to exhaust properly in order to dry no matter where it's situated. Insure that the venting is not crushed at the back and that it has a good strong air flow outside
Jun 21, 2009 | Dryers
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
Maytag dryer smell of gas inside and venting
hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore 74842 Gas Dryer Logo
1,274 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
