Question about Aeris Max Depth Analog 2 Gauge Console
Scuba Gauges importance
What do i need gauges for?
    President:
  • 2,712 Answers
"A diver relies on scuba gauges to know three things: 1.-Depth 2.-Air Consumption 3.-Time Depth and Time are vital for nitrogen and air management. A scuba diver needs to know how deep he has been and for how long in order to judge the necessity a
Posted on Dec 01, 2008
I have never used a dive compass before. Is there a manual as I bought it on ebay?
There is no manuals for scuba compass, I dont know what scuba school you hold your open water cert with but all scuba organisations such as PADI, SSI etc etc will cover navigation as part of there basic and advanced scuba education.
Sep 22, 2010 | Oceanic Clip Mount Maxtilt Compass -...
Extremely short battery life. How to fix?
Battery life is completely dependant on how often you use the computer to dive with. Batteries should generally be changed every two years regardless of use. An authorised dealer will also use the best recommended battery for the unit and not use cheap imported batteries. Hope that helps
Sep 19, 2010 | Uwatec Aladin Tec 2G Wrist Computer SCUBA...
Water inside the gauge.Blow out plug is good.Can you take off the face plate?
The gage may be removed from the rubber boot, but the clear face plate is not removable.
Aug 24, 2010 | Mini Scuba Gauge Ist Scuba Pressure
I,m looking for a manual for the ''Orca Phoenix'' dive computer.
Hi, this used to be available for $5, but their web site is down. It does not seem to be available anywhere for download, but there are scuba web forums and all the members seem to be sending pdf forms of it too each other for free. I am sure if you joined one, a member would send one to you. Like this one: http://www.scuba.com/scubaforums/ubbthreads.php?ubb=showthreaded&Number=7460&site_id=1#import
Sep 17, 2009 | Scuba Diving & Snorkeling
Metric treads on my poseidon 1st stage
Try looking at Divers Direct... i think their website is diversdirect.com... you can email them or brows the website to find anything you need for diving.
Mar 23, 2009 | Poseidon . Cirrus Double Console - Gauges...
Empty air pressure gauge
mineral oil any thing else will build up residue
Mar 18, 2009 | Dive Rite Brass Pressure Gauge - Gauges -...
Scuba HP pressure gauge has air bubble inside. Can I fill with kerosine?
Pressure gauges are sealed and should not ever get bubbles in them. If there's air in the gauge, there's some possibility the Bourdon tube has a crack in it. You will spend more time dinking around with getting a bubble out and resealing the gauge than the instrument is worth. The pressure gauges on a fill station are industry standard parts and you can buy replacements off the shelf. They're not terribly expensive. Replace it.
Dec 01, 2008 | Aeris Max Depth Analog 2 Gauge Console
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
Scuba Gauges what do I need them for?
"A diver relies on scuba gauges to know three things: 1.-Depth 2.-Air Consumption 3.-Time Depth and Time are vital for nitrogen and air management. A scuba diver needs to know how deep he has been and for how long in order to judge the necessity and length of decompression stops and to calculate residual nitrogen for repetitive dives. The time of a dive is easily tracked using a scuba diving watch and the depth is tracked using a depth gauge. "
Aeris Max Depth Analog 2 Gauge Console Logo
175 people viewed this question
Top Aeris Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Aeris Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
