Question about Samsung HLP4663W 46" Rear Projection HDTV
Fan In TV
My televion sounds like a bicycle that has a playing card in the spokes whenever I turn the set on.
    Problem Solver:
  • 10 Answers
The bearings in the fan are on there way out replace the fan depending on the size go to a computer hardware store to replace
Posted on Jul 05, 2009
Lenovo Ideapad z500 produces annoying clicking sound every 1 second, sometimes this happens and stops, then starts again, i have no clue what's causing it.The sound comes from the far left side of the...
Sounds like debris in your cooling fan. Try vacuuming the open grills and see if the click goes away. This is usually caused by something sucked into the fan and clicking, like clothespinning playing cards to your bicycle spokes to make a motor sound as a kid. Since the fan is the only moving part in a laptop this is with 99% certainty the problem and the only way to fix it is to remove the offending debris.
Nov 15, 2013 | Lenovo IdeaPad Z500 Laptop Computer -...
How do you level this refrigerator? Also has
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Jun 15, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My engine makes a sound like a playing card stuck in the spokes of a bicycle.
Fro mthe sound described you could have an exhaust leak or valve clatter. Check your oil also, this could cause noisy valves.
Mar 12, 2011 | 2000 Ford Focus
The heater fan in my 2005 colorado sounds like a kids bicycle with a card in the spokes. How do i remove the fan to remove or clear whatever is making the noise?
Remove the blower motor mounting screws.
  • Remove the blower motor cooling tube (2).
  • Disconnect the blower motor electrical connector (4).
  • Remove the blower motor (3).
    Nov 21, 2010 | 2005 Chevrolet Colorado
    Gateway 7510GX CPU Fan noise
    If this is a brand new laptop it would be still under warranty.
    I suggest returning it to the supplier for repair under warranty because if you attempt to repair it you could void your warranty.
    You should only attempt repairs after the warranty has expired.
    Apr 06, 2009 | Gateway 7510GX Notebook
    AC/Heat Blower makes noise when fan is on
    almost sounds like something is in it and it is located on passenger side under dash.
    Jan 17, 2009 | 1998 Dodge Ram
    Acura MDX '01. When A/C turned on, fan has buzzing sound and when turned up higher, sounds like baseball card in bicycle spokes. I'm sure it's debris (leafs, etc.) sucked in from outside. How do I get...
    Disconnect the wires to the fan.  There is three screws that holds the fan.  remove and it will come down.  The filter is behind the glove box.  remove the three screws for the glove box and then cut the plastic on the dotted lines if it has not been done.  Replace the filter and put new bolts where the trim that goes sideways on.
    Aug 07, 2008 | 2008 Acura Mdx
    Loud whirring. Not the fan.
    The fan noise is normal on this set. The lamps are cooled via this method. Your users manual explains this issue..and it is the fan as you can see it slows down after the tv is switched off..
    Oct 20, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
    Whirring noise. No other problems.
    Sounds like you have a noisy color wheel. Very common on all Samsung DLP`s. The part # is BP96-00250A for model HLN5065W.
    Oct 16, 2007 | Samsung HLN5065W 50" Rear Projection...
    Turn on- Its clicks- HELP!!
    Hello 4uwendy, there is a problem with lens, actually with zoom and focus initalization. Please contact your nearest Sony Service. Best regards, Arpi
    Aug 21, 2006 | Sony Cyber-shot DSC-S600 Digital Camera
    Samsung HLP4663W 46" Rear Projection HDTV Logo
    51 people viewed this question
    Henry  Thomas
    Henry Thomas
