Question about Olympus EVOLT E-500 Digital Camera
The LCD display displays D: 3B13
I have a similar problem, the LCD display displays D: 3B13? Any suggestions?
when it press the shutter button, the camera focuses then it hangs. the viewfinder still displays the shutter speed, aperture settings and the green focusing icon but the lcd the just blank. this continues even if the camera is turned off. In order for the camera to reset or turned off, the battery should be removed. I really dont know the problem. I would appreciate if i would be given an idea of what may had happened before i bring it to the service center.
    President:
  • 1,223 Answers
Problem is small as software update try www.olympus.com and big as CCD Failure
there is a strong chance of CCD Failure
pls do rate me
Posted on Feb 24, 2009
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
There is too much delay when I try to take a picture.
This is a common situation with most compact point&shoot cameras. The camera has to do a lot of work when you press the shutter release button: it must focus on the subject, meter the light for proper exposure, and switch the electronics from displaying on the LCD to recording the image to memory. Larger (and more expensive) cameras have additional hardware to deal with most of this, eliminating the "shutter lag."
You can reduce the lag by pressing the shutter release button halfway to focus and meter the exposure. Keep the button halfway down until the right moment and then press it the rest of the way down.
Nov 08, 2010 | Pentax Optio S7 Digital Camera
D: 3B13
appears to be repair issue... call tech support
Dec 01, 2008 | Olympus EVOLT E-500 Digital Camera
Shutter speed
You need to let the camera auto-focus time to do its job. Press and hold the shutter button half way until the white square in the LCD display (or LED light next to the view finder) turns green, then press the button all the way down for the camera to take the picture.
Nov 24, 2007 | Olympus SP-500 UZ Digital Camera
Blurry Pictures
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 4. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
Blurry Pictures
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
Manual Focus
1) Press and Hold the FOCUS button until to you "MF" appear in the lower left corner of the LCD Display on the back of the camera. Then you can release the Focus button. 2) Press and Hold the DISP/i button to see the Manual Focus Range. 3) While holding the DISP/i button, use the Tele/Wide Zoom Key to set the desired Manual Focus. You can see the focus change as you toggle the zoom key. 4) When you are ready, release the DISP/i button and Press the Shutter Button to take your picture. *Press the Focus Button to return to Auto Focus / Macro options
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Manual focus
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Focus Problem
I have the C740, which I believe works very similarly if not identically. Unless you have the camera in full time auto focus, I don't believe it actually focuses on the subject until you've pressed the shutter button half way. Until then, the subject may look in focus in the viewfinder, but is not. When you fully depress the shutter in one motion (rather than pressing half way first), the camera will attempt to focus before it takes the shot. If you are not careful about camera movement, you may inadvertently be focusing on something other than what you intended. My camera (and it seems all digicams) has trouble focusing in low light, so you definitely want to use the half press in such situations. Even then, I don't always get the focus correct. Thank the digital Gods for instant feedback! Personally, I almost always use the half press method. To get the 740 in manual focus, you hold the "OK" button down until you see the viewfinder display a focusing scale. It takes a second or so. You should also see "MF" and "AF" designations in the lower left corner of the viewfinder when the scale displays. Use the left and right arrows to select the focus mode you want (i.e. MF or AF), then use the up and down arrows to adjust the focus distance. You'll notice that the area you are focusing on is enlarged when you use the up and down arrows.
Sep 13, 2005 | Olympus Camedia C-750 Ultra Zoom Digital...
Can't take picture with monitor off?
When the LCD display is "off" the focus mode is automatically switched to "Single AF" mode (since there is no way for the user to confirm that the proper subject is focused) and unless focus is locked the camera cannot fire. When the camera is in "Continuous AF" Focus mode the camera will take a picture whenever the shutter release button is pressed, wether or not the subject is in focus. You can take a photo with the monitor off, but the camera will have to lock focus before it can fire and will not respond as quickly as with the monitor on.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
258 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
