Question about Dell Latitude D600 Notebook
Dell Latitude D 600 battery is not being charged
I am user of Dell Latitude D 600 lap top. My computer is not charging battery. Some time it starts charging without any action taken and mostly it not charging. I have replaced battery and charger but problem is same.
  • zafar_emi Dec 01, 2008
    In repairing center, they replaced chrarger port. Now charger is being connected but battery is not going to chrge
  • studnubian2 Dec 13, 2008
    I purchased a refurbished DELL LATITUDE 600 and it will not keep a charge. When I'm at home I keep it plugged up, but when i unplug it the screen gets dim and loses charge. I dont know what thats all about.
    President:
  • 2,110 Answers
Some problemwith ur motherboard circuit..so check up in service center...
Posted on Dec 01, 2008
The screen on my lap top is broken, I would like to hook it up to a monitor but can't get it to display on it ... any suggestions?
If the laptop its self is not damaged, try holding the Fn key and press the F8 key multiple times till you get it to display on the monitor.
The following was copied from the Dell User Manual
"<Fn><F8>" "Switches the video image to the next display option. The options include the integrated display, an external monitor, and both displays simultaneously."
FYI:
"<Fn><F7>" " Scales between wide-screen and standard aspect ratio video resolutions." page 50 from PDF
Here's the link to the Dell User Manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d630_User%27s%20Guide2_en-us.pdf
If you get it working on the external monitor, I would update the video driver and the bios. You can get the files from support.dell.com. If you are going to update the bios make sure the battery is over 50% charged and the power supply is plugged in to the laptop.
You can check the bios version on a windows computer by typing MSCONFIG32 on the "run" or "search programs and files"
Aug 26, 2014 | Dell Latitude D630 PC Notebook
Dell 620 lap top does not stay on. when i turn on then it stay for second then turn off itself
theres a start up driver missing you will need your back up disc on this one.or theres a problem with your battery it not takeing charge.
Mar 30, 2011 | Dell Latitude D620 Notebook
Windowxp dell 600 lap top will not charge battery or turn on wih ac power do i need a new battery or black sreen does not deytemine ac adapter will not preform best operatings
check first the battery pack... use another batter pack to check the batter if its okay or not... if okay..then use another charger also to check the charger. if the problem is the same you need to open you laptop and check or repair the charger connection or some chips of your unit.
its needed the expert hardware. bring to the nearest computer service center if you can't do it..
Jun 23, 2010 | Dell Latitude D600 Notebook
Cant able to charge the battery in dell 600
first check your charger cable that everything are ok. if not then tell me is your computer run only from your battery back up. if not then i think your battery become weak. so it is unable to keep charge. then the way is change your battery and buy original battery from Dell show room. but if battery ok then change your charger.
thanks
Mar 06, 2010 | Dell Latitude D600 Notebook
I have a dell lap top, and the battery does not charge, it always says idle. the battery works fine when not plugged in, and i have replaced the charger. i have tried taking the battery out and cleaning...
Go to the Dell website (www.dell.com) and click on the Downloads tab. There may be a firmware update you need to download. Another possibility is the power source, does it start up with a message that it's starting in battery optimized mode?
Jan 11, 2010 | Dell Latitude D600 Notebook
Why does the battery light keep flashing?
The battery is failing to recharge itself.
Contact Dell -- a battery should last longer than that.
Dec 08, 2009 | Dell Latitude D600 Notebook
Booting problem dell d 600 lap top
One Thing that is known with Dell Laptops, is if your Battery has been dead for awhile even though you continue to use your power adaptor. it will go into a lockdown/shutdown mode. You can try by removing your Memory RAM (be carefull of static charge ,touch and keep hands on metal of laptop case)then remove battery,and unplug power cord let sit with no power at ALL for several hours.Usually I will let sit 24-48 hours if time permits. Works every time when battery has been used to its full life.If it doesn't, Then it can be a more serious issue.another possible solution is to find screws on bottom to Harddrive,CDdrive,and Floppydrive (if available) remove and reseat to see if connection issue.otherwise contact Dell or Your Technician.
Jan 07, 2009 | Dell Latitude D600 Notebook
Dell 610 - battery will not charge and adapter goes "blink"
http://support.dell.com/support/edocs/systems/ins6400/en/index.htm
aneesnv@msn.com
Dec 18, 2008 | Dell Latitude D600 Notebook
Lap top will not power on
There are a few things that can cause this. Start by removing the battery and starting on AC only. Then remove the memory and try each chip separately. If these aren't the problem, then I'm afraid the power management system or another component on the motherboard may have failed. You will need to take it in for a professional diagnostics.
Jul 27, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
170 people viewed this question
Alun Cox
