Yesterday I launched a new cable provider having digital chanels, some of them HD. With the regular digital chanels everything is fine but with HD there is only sound, the picture doesn't appear. What should I do in order to fix this?
First if HD via component or HDMI the hookup or more likely the box if used is your issue---some sets will require a firmware update for certain boxes to work--I am guessing but guess you may be using HDMI.
SOURCE: Sony BRAVIA KDL46S2010 Sound and Pix not in sync - in HDTV channels only
This is a software issue with both the TV manufacture and the cable box provider. This will only be fixed when the cable company and TV manufacture sit down and work out their problem. Some cable company has taken the first step by updating cable boxes with different software.
Best regards
CircuitCity
SOURCE: Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
SOURCE: Sony 52" Bravia LCD will drop picture and sound for 1-2 seconds
the only thing that i can think of is that the cables and connections are bad but if that is not the case it may be the internal components of the tv. my guess is that the tv was dropped or jumbled around while transported and what happened was internal components were broken or just mixed up so go to the retailer and get a refund or a new tv. hope this helps
SOURCE: Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
