I have problem of powe on password with my laptop compaq armada m700. how i can by pass my password power on password?
Ik heb een probleem met mijn notebook Compaq (HP) 610.
Er stond ineens Power on Password op het scherm terwijl ik aan het werk was? De garantie was net over. Volgens HP moet ik hem via HP opsturen naar Polen. Raar verhaal vind ik. Kan iemand mij helpen?
roelfa@kabelfoon.nl
Posted on May 10, 2011
  • 3 Answers
Three solutions are available that are not different but subscribe with different ways
No.1. no other way i know of. but you can get to the cmos battery via the removable panel on the bottom right front of the case (other side from the battery). first remove the main battery. next remove the panel, under it you will see a modem card, remove the modem card and you should see the cmos battery to the right side its loke a big watch battery. there will be a connector on the wires going to the battery. remove this to disconnect it. now just push the start button with the machine un plugged, just to discharge any residual power. wait a couple of minutes then reconnect the cmos battery then the modem card, then the main battery. plug it in and start it up. the screen will come up with something like "cmos bad checksum, defaults loaded" do not worry this is normal. if it doesn't start normally, switch it off by holding the on button down until it goes off then restart. it should be fine after that, password gone. you can then get into your bios and set it up to your liking.
No.2. 2.2 Clearing Passwords
1. Turn off the computer.
2. Disconnect the AC Adapter (refer to Section 5.3).
3. Remove the battery pack (Section 5.6).
4. Disconnect and remove the Real Time Clock (RTC) battery (Section 5.11).
5. Wait five minutes.
6. Reconnect the RTC battery.
7. Install the keyboard deck and keyboard assembly.
8. Reconnect the AC Adapter. Do not reinstall the battery pack yet.
9. Turn on the computer.
NOTE: Remember to set the date and time the next time the computer is turned on.
No.3. There is no exra security-chip. And the power-on password is removed as follows
1. Remove all auxiliary power sources, including the Real-time Clock (RTC) battery.
2. Disconnect the AC Power.
3. Wait five minutes.
[Time has to be lonnger, at least half an hour]
4. Reconnect the AC power.
5. Restart the computer. Note: During the Power-On Self Test (POST), the message "162 System Options not set" will appear.
6. Shut down the computer and disconnect AC power again.
7. Replace the real-time clock battery.
8. Install the battery pack(s).
9. Restart the computer.
*Every* step has to be doen correctly.
On can easliy mis on or two - happend to me 3 times the other week ;-)
Posted on Dec 02, 2008
  • 3 Answers
  • 3 Answers
Dear
hello, how are you?
i am surfing internet and it solved my problem for free
i have act as it tell me in its instructions step by step
now my computer is working for free cause i can not surf money i have not enough on your demand i can provide you this link that have help me
Thank you
Need to delete username and password so that I can use O.S. Compaq Armada M700 laptop.
U can go to the control panel then user accounts to change name and create password.
Aug 14, 2010 | Compaq Armada M700 Notebook
How do you pass a power-on password compaq m700 laptop
you have to go inside the bios and stop it, this is for security reason, but if you cannot go inside the bios, this need to call the compaq so they give you a new password to open it, otherwise you will end with opening the laptop and try to hack the Bios which i donot advice you.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jun 17, 2009 | Compaq Armada M700 Notebook
Installing wifi in Compaq Armada m700??
yes, aslong you have USB port or PCMCIA card slot
if your compaq armada m700 is the p III series it's alot better
Jan 25, 2009 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
The screem has broken and it can not power on
well you need to get a new LCD panel for your Armada M700. You could get something like this from eBay:
http://cgi.ebay.com/Compaq-Armada-M700-Laptop-For-Parts-or-Rebuild_W0QQitemZ360053106104QQihZ023QQcategoryZ177QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
(hurry....less than 8 hours left)
You could do this yourself if you are technically inclined.
May 23, 2008 | Compaq Armada M700 Notebook
Compaq armada m 700 was not show battery no go with battery
In ur laptop,U click on Control Panel - Power options.Click on Power meter.There u select the battery show option.
I go for this web address.www.hpfashinontronics.com
U can Laptop skin order through online also.
Oct 31, 2007 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Computers & Internet Logo
237 people viewed this question
Alun Cox
David Payne
David Payne
