Question about Toshiba DR4 DVD Recorder
Recording problem After programming a show system fails to record and reviewing still shows the program to be recorded though in the past.
  • Anonymous Mar 23, 2008
    records a show then when it is finished it says "blank disk loaded" but you can see the recording on the disk itself
  • Anonymous Mar 21, 2014
    why is my recorder showing no event information for itv ch 4 ch 5 etc on my programme guide is this a fault with my recorder or a technical problem. we cannot record any of these programs which is very frustrating
I have the same problem. What I found was the recorder will not recognize a disc that was inserted into the machine and then the machine is turned off. If I load a disc, either a -R or -RW, program the timer recording and DO NOT turn the recorder off, then the unit does make the recording. I called the Toshiba techs and the only thing they recomended was to return the machine to them for repair at a flat rate of $140. The unit only cast $180. A friend of mine has the same recorder and he is going to check if it will recognise a previously loaded disc after the unit is turned off and back on. Perhaps everyone with this problem should call Toshiba so they can make a firmware update for the DR4s. I hope this helps. MW
Posted on Mar 09, 2007
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Can i attach backup device to my lg HT356SD?
I would say yes, from what the manual says, the LG HT356SD has some Unique Features:
#1 Portable In : Listens to music from your portable device.
(MP3, Notebook, etc)
#2 USB Direct Recording : Records music from CD to your USB device.
Read the manual, on page 26 it will show you how to do it, I found it at www.theatresystem-manual.com under lg, or go directly to the link I provided.
http://www.theatresystem-manual.com/manuals/lg/LG_HT356SD.pdf
Recording to USB
1. Connect the USB device to the unit.
2. Select a DVD/ CD function by pressing
FUNCTION.
One track recording - You can record to USB after
playing the file you want.
All tracks recording - You can record to USB after
stop.
Program list recording - After showing the
programmed list, you can record it to USB.
3. Start the recording by pressing X REC.
4. To stop recording, press Z STOP.
Mar 18, 2014 | LG LHT854 Theater System
I have a magnavox ZV427MG9A DVD/VHS recorder. Recently I deleted all the titles/programs that I no longer needed so that I could reuse the disc for recording. I was able to record two programs fine, but...
Sorry to bother you sirs, but it seems that you know much about DVD Camcord playback problem. I have a question about my camcord video output format may i ask. I have a vro file that can'tbe recognized by my VLC player, so I use this VRO mp4 converter([url]http://www.videoconverterfactory.com/tips/vro-converter.html[/url] to convert the vro file to mp4. After that conversion process the .VRO file can be played again, but I do not know why the output has no audio output, no sound. Do you ever met such a kind of problem? VLC can play .VOB very well because I have checked. It should be similar to .VOB, but why VRO cannot be recognized by VLC Media Player, it doesn't make any sense. Is there any free and simple method to directly run .VRO file on my PC without using any third-party video conver
have magnavox ZV427MG9A DVD VHS recorder Recently deleted all the titles...
Mar 15, 2017 | Magnavox ZV427MG9 DVD Recorder VCR
After a timed recording the DVD is showing blank
Try to scan the DVD data into your PC using the trial version of TMPGEnc v4.0 Xpress if this can't find structure data then the recorder must have set the leadin data to show blank.
Nov 13, 2009 | Philips DVDR3380/05 DVD Recorder
Doesn't stop recording
Make sure there is no time overlap on any of the programs you have on the recorder.
That is the most likely problem
Aug 19, 2009 | DISH Network DVR-625 DTV Receiver /...
Dish Network DVR 625 Problem with playback of recorded shows
It sounds as though the hard drive is about to go south on you soon and the receiver is going to need to be replaced however, in the interim you can change the options of the recordings and make it a default so that the recording continues past the end of the show. It is possible that extending this time will allow you to view the portion you want before it skips to the end. In order to do this press the guide button and select a program in the future. On the create timer screen select the option icon. You will now be at the timer options screen you can extend the time the recording will last after the end of the show and when it will begin recording prior to the show. I would also set this as your systems default so that it performs the same way regardless of what you are recording. According to the latest known receiver issues this is not identified as it is a common indication that the hard drive has an error internally. If this works I suggest that you have a replacement sent to you so that you do not lose the use of your DVR un-expectantly.Remember to watch all recorded events prior to replacement as you will lose that info when the receiver is swapped. Thanks for using Fix Ya.
Mar 09, 2009 | DISH Network DVR-625 DTV Receiver /...
DVR recording problems
i am not terribly familiar with these systems but there are probably two sattelite in ports on the back of the receiver, one is a line for watching one program or recording, the other strictly for recording, one of these inputs is probably no longer receiving signal
Jul 08, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Short Recording Time
TiVO also plans for other upcoming shows in total recording time. So if you 12 hours recorded, and another 20 or so hours scheduled in upcoming all as don't delete, then it won't allow additonal shows manually
Nov 21, 2006 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Toshiba DR4 DVD Recorder Logo
134 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
