Question about NetGear FS605 (FS605SE) Networking Switch
Netgear switch fsgo5v3
I run one vista home pro and 2 xp pro computers thru this switch along with a network setup to share files between the 3 computers. When I put my vista into standby , and then bring it back out . It wont see the two xp computers any more , unless I shut down the switch and turn it back on .After about a minute , it will see the xp's again. This also happens now and then with the xp computers seeing the other computers . Can you tell me what to do to fix this problem
  • 3 Answers
Well, apparently your switch is taking off your PC from his arp table due to his inactivity.
try to release and renew the ip address in your machine instead of reset the switch.
Normally reset the switch will be you last resource.
go to START -->> RUN type cmd <hit ENTER>
a black windows should populate, its calles command prompt.
type:
ipconfig /release
then ipconfig /renew
this will force the switch to see your network Interface Card.
Posted on Dec 03, 2008
Problem connecting to WNR2000 on laptop running vista
Perform the task below on the wireless VISTA computer:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 26, 2009 | NetGear WNR2000 Wireless Router
Tip
How To Enable File And Printer Sharing In XP, Vista, and 7
Verify File and Printer Sharing for Microsoft Networks is Installed by following these instructions for your particular OS:
Windows XP
1. Log in as the administrator or as an account that has administrator capabilities.
2. Open the Control Panel and click Network And Internet Connections.
3. Below "Pick A Control Panel" Icon, click "Network Setup Wizard."
4. On the Welcome screen that displays, click Next and then click Next again. The wizard displays the Select A Connection Method dialog box.
5. If your host computer connects to the Internet through a residential gateway like a router, access point, or base station, select the second option and click Next.
6. The following prompt is for your computer’s description and name. Accept the default answers and click Next. Do the same for the Workgroup Name prompt.
7. On the File And Printer Sharing screen, select the Turn On File And Printer Sharing radio button and click Next.
8. When the process is complete, the You’re Almost Done dialog box displays.
9. Select Just Finish The Wizard; I Don’t Need To Run The Wizard On Other Computers and click Next.
Windows Vista
1. Click Start, right-click Network, and then click Properties.
2. In the Network and Sharing Center window, under Sharing and Discovery, click the down arrow next to File sharing.
3. Within the File sharing settings, click Turn on file sharing, and then click Apply.
4. Next, click the down arrow next to Printer sharing.
5. Within the Printer sharing settings, click Turn on printer sharing, and then click Apply.
Windows 7
1. Click Start, open up Control Panel, then click on Network and Internet, then click on Network and Sharing Center.
2. In the Network and Sharing Center window, click on Change advanced sharing settings.
3. In the Advanced Sharing Settings window, you will need to change the settings for the Home or Work, and Public profiles.
4. Turn on File and Printer Sharing for both Home or Work, and Public profiles.
5. Click Save Changes and close this window.
on Jul 14, 2010 | Computers & Internet
I can't connect to other computers on the Network.
Make sure you have file sharing turned on if you want the computers to be able to find each other through My Network Places.
Mar 21, 2009 | NetGear RangeMax WPN824 Router
Vista Laptop cannot connect to XP users
go to control panel>>add and remove prgrams>>click on add/reomve windows components on the left panel.
make sure you have the system CD.
put a check mark in "networking services" and "other network files and print services" install the addtional services.
check the share volume, make sure you have given the user rights to access the drive.
Jan 30, 2009 | Microsoft Windows Vista Ultimate Edition
Just purchased laptop with windows vista home premium
If your PC has a wireless card, you can setup an AD-HOC network :
If your PC is XP: http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
If your PC is Vista: http://windowshelp.microsoft.com/windows/en-us/help/293c504f-b944-4d5d-835c-f080129bd5dc1033.mspx
If your PC only has a wired Ethernet connection, you may still connect the two using a Wireless Access Point/Router.
Once you have the two computers connected, you may do whatever networked operations you would like:
File & Printer Sharing is the most common:
XP: http://www.wellesley.edu/Computing/FileSharing/Windows/win2kxp.html
Vista: http://www.windowsnetworking.com/articles_tutorials/File-Print-Sharing-Windows-Vista.html
Aug 01, 2008 | Apple iPhone 3G
Home network with 2700hg-b and netgear wireless issues
You didn't say what operating system you have but check your Network and Sharing Center in Control panel and turn on the file and printer sharing feature in Windows.
Using Vista, click on Control Panel- Click on Network and Sharing Center-configure settings.
Hope this helps.
Mar 24, 2008 | 2wire 2700HG-B Router (2700HGB)
Setting up my HOME network! HELP!!!
Sounds like something is not right with the sharing... Assuming that computer 1 (the computer with the printer) is sharing and everything is set correctly, I would change the workgroup name. Instead of using "MSHOME" use say some basic word like "example" or some other name.
Ironically for my workgroup here I call it "StarWars"
needless to say my printers and everything shares just perfect. When you use "MShome" there's restrictions on what XP professional and XP home machines see on the network. I changed the workgroup name and that solved that problem.
Be sure to put all computers on the same workgroup name that you pick. You can even choose your first name if you want.
Dec 29, 2007 | Computers & Internet
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Setting up 16 port switch
Dear This is the step You can get a complete home network up and running in 10 easy steps. Here's a summary of what's involved: Take stock of your existing hardware. If you wish to share an Internet connection using Internet Connection Sharing (ICS), choose which computer will be your ICS host. Decide what type of network technology you wish to use. Make a list of the hardware you need for each computer. Install the network adaptors and install your modem on the ICS host computer. Physically cable the computers together. Switch on all computers, printers and other peripherals. Make sure the ICS host is connected to the Internet. Run the Network Setup Wizard on the ICS host. Run the Network Setup Wizard on the other computers on the network. Let's take that step by step. 1. Take stock of your hardware Note each computer's location and its hardware, including peripherals such as printers and modems. 2. Choose your ICS host If you wish to share an Internet connection between your computers using Internet Connection Sharing (ICS), choose which computer will be your ICS host. The ICS host has a direct connection, either by dial-up modem or high-speed link, to the Internet and provides access to the Internet for other computers on the network. Ideally, the host should be a computer running Windows XP. I'll assume you have made this choice in the following steps. Apart from XP's easy handling of ICS, by using an XP computer as your ICS host you get the benefits of using the Internet Connection Firewall. 3. Choose a network technology The most common choices are Ethernet and wireless LANs. For an Ethernet LAN you will need to install a network interface card, or NIC, in each computer and run cabling between the computers. If you don't like the idea of opening your computer to install a network card, look for a USB adaptor instead. Depending on the size of your network, you may also need a network hub or router to provide interconnection between PCs on the LAN. Two PCs can get by using an RJ-45 crossover cable; three or more computers require a hub or multi-speed hub (called a switch). If you have a high-speed Internet connection, a high-speed router is a good option. The Network Setup Wizard includes links to detailed advice about configuring your network, including help on designing a network layout to suit your home. If you opt for a wireless LAN, you'll also need a NIC for each PC (there are versions which use USB adaptors as well). The big benefit for home environments is that a wireless LAN does away with the need for cabling. On the down side, though, wireless LANs tend to be slower, less robust and appreciably more expensive than traditional Ethernet LANs. In particular, wireless LANs do not always live up to their stated working range, and you may find factors such as your home's construction and design, plus interference from other devices affect your wireless LAN's performance. You may need to add an expensive Access Point to extend the range of the LAN and, even so, it may not be sufficient. The bottom line is, if you decide to go the wireless route, make sure the store will refund your money if the LAN will not provide reliable performance within the specified range. 4. Make a list of hardware needed Make a list of the hardware you need for each computer, not forgetting any cabling, and buy it. If you're a little dazzled by the choices and configurations, consider purchasing a networking kit. These kits contain all you need to set up a two- or three-PC network. If possible, look for hardware which features the Windows XP Logo, indicating it is fully compatible with XP. 5. Install the adaptors Install the network adaptors and install your modem on the ICS host computer (you can also let the computers connect to the Internet independently by installing modems on each). 6. Cable the computers Physically cable the computers (and hubs or routers) together. Of course, you won't need to do this if you've chosen to go the wireless route. If you're installing an Ethernet network and have a lot of cabling work to do, you may prefer to get a professional to come in and do this work for you. It won't be cheap, but you can be sure you get the job done correctly and hopefully with minimal damage done to walls, ceilings and floors. 7. Switch it on Switch on all computers, printers and other peripherals. 8. Connect the ICS host Go to the ICS host computer and make sure it is connected to the Internet. 9. Run the Network Setup Wizard on the ICS host To run the Network Setup Wizard on the ICS host, click Start -> Control Panel -> Network And Internet Connections -> Setup Or Change Your Home Or Small Office Network. Follow the instructions in each screen and press Next to continue. XP's Network Setup Wizard takes much of the pain out of setting up a home network. The Network Setup Wizard will guide you through: Configuring your network adaptors (NICs). Configuring your computers to share a single Internet connection. Naming each computer. (Each computer requires a name to identify it on the network.) Sharing the Shared Files folder. Any files in this folder will be accessible to all computers on the network. Sharing printers. Installing the Internet Connection Firewall to guard you from online attacks. 10. Run the Network Setup Wizard on all computers To do so: Insert the Windows XP CD in the first computer's drive. When the XP Welcome Menu appears, click Perform Additional Tasks. Click Setup Home Or Small Office Networking and follow the prompts. Repeat steps 1 to 3 for each computer on your network. Make sure you maintain an active Internet connection on your host computer as you proceed through this process. geekgirl.tip If you don't have a CD-ROM drive on one of the network computers, you can run the Network Setup Wizard from a floppy disk: While running the Network Setup Wizard on the ICS host computer, select the option to copy the Network Setup Wizard to a floppy disk. Once you've completed setup on the ICS host, take the floppy to the next computer and insert it in the drive. Double-click My Computer. Double-click 3½ Floppy (A:). Double-click netsetup.exe. The quickie XP network If you want a really easy networking experience and you have the hardware to support it, consider clean installing Windows XP on two or more computers. First install your network hardware (network interface cards, cabling, et cetera), then perform a new installation of Windows XP. During installation, XP will sense your hardware setup, ask for a name for each computer, and then ask which type of setup you wish to create. Select Typical Settings For A Default Network Configuration. That's it. Provided your hardware is XP-compatible, XP will create a LAN using the workgroup name MSHOME. Using your network Once you have your network up and running, you can easily access other computers on the network via My Network Places (click Start -> My Network Places). The Task Pane in My Network Places lets you access computers on your network and adjust settings. The Task Pane in My Network Places lets you view your network connections and view each of the computers in your workgroup (the workgroup consists of all computers on a network which share the same workgroup name ? by default, XP gives all computers on your home network the workgroup name MSHOME, although you can change this if you wish). When you initially open My Network Places, you'll see icons for the Shared Files folder of each of the active network computers. Sharing a printer With your home network installed, your PC suddenly gains all the advantages of the other PC's on the network. If you've been lusting after your sister's colour photo printer, you can now print directly to it from your own machine. Provided, that is, your sister decides to share her printer. (You might offer to let her share your laser printer in return as an inducement ? sharing works both ways.) To share a printer, on the computer which is directly connected to the printer: Click Start -> Control Panel -> Printers And Other Hardware -> Printers And Faxes. (Note: These steps will be a little different if you're sharing a printer on a PC running a version of Windows other than XP. For example, under Windows Me, you click Start -> Settings -> Printers.) Click the printer you wish to share. Click Share This Printer in the Task Pane. In the printer's Properties dialog, click the Sharing tab. Click Share Name and OK. Make a printer accessible to others on the network by sharing it. Once a printer has been shared you can access it from other computers on the network. To do so: Click Start -> Control Panel -> Printers And Other Hardware. Click Add A Printer. In the Add New Printer wizard, when asked whether the printer is a local or network printer, select the latter. In the next screen, select the option to Browse For A Printer and click Next. Select the appropriate printer from the list and continue with the wizard. Sharing files and folders Sharing a folder is even easier than sharing a printer: Open a folder (such as My Documents), click Make A New Folder in the Task Pane and name your new folder. With the new folder highlighted, click Share This Folder. In the Sharing tab of the Properties dialog box, select Share This Folder On The Network. Provide a descriptive name for the folder. This name should make it easy for others on the network to recognise the folder; it doesn't have to be the same as the folder name you selected in step 1. You can let other people on the network view and edit your files or view them only. If you want to protect your files from tampering, remove the tick from Allow Other Users To Change My Files. There are a variety of ways to access a shared folder. Here's one way: Click Start -> My Network Places -> View Workgroup Computers. Click the computer whose files you wish to access and then click the shared folder. You can create shortcuts to shared folders to make them easier to gdfgf
Sep 08, 2007 | Computers & Internet
NetGear FS605 (FS605SE) Networking Switch Logo
207 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
