Question about E-Machines T1742 PC Desktop
Emachine computer no sound at all
Do all computers have built in speakers if so how do i active it so i can have sound? Received computer from brother when he passed with speakers but they no longer work and i disconncted them from the computer but i cannot figure out how to get the built in speakers on the computer to work, if there are any. Thanks in advance, pat
Sounds like the pc has turned on the mute function go to the task bar go to sound right click the mouse and turn the volume back on i had the same problem worked for me good luck
Posted on Dec 01, 2008
Built in pc speakers are just for error beeps etc. You most likely have on-board sound. I would try getting a sound card (with drivers) Put it in a free pci slot & connect your speakers to it. :)
Low speaker sound
there is usually a volume control on the lcd console on screen read the lcd manual
Feb 24, 2012 | E-Machines eMachines Desktop PC
Trying to connect BA735 speakers to a MacBook? No sound? Are they compatible?
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
It's a matter of the output from the computer's sound card (built-in) being incompatible with the speaker input. The card is sending out analog sound wile the speakers are expecting digital input. Downloading a driver won't help because that doesn't fix the root problem. You need to get speakers designed for analog input, or a sound card with digital output. As it stands now, your computer just can't use those speakers.
Since your using a MacBook there is no option for this Pci Digital Sound Card.
Feb 03, 2011 | Boston Acoustics BA735 Computer Speakers
I am not getting any signal or music when I sign on as I usually have received. What's wrong?
Assuming you have other sounds (as in games or playing MP3's) Check the volume on your speakers and the volume control down near the clock. Make sure nothing is muted and that the speakers powered on and plugged into teh computer (usually the little round light green hole)
If that's not it, click on start, then settings and Control Panel, doubleclick sounds and check the 'sounds' tab to see if it's set to 'no sounds', if it is, use the pulldown to pick windows default.
If you still have no sound, you may have a soundcard/driver problem.
Apr 26, 2010 | E-Machines eMachines Desktop PC
Says no active mixer divices installed,,speakers not working
Your computer came with sound hardware built in. You might have to reload the drivers for your audio hardware, off of the disk provided with your computer. If you misplaced the disks you can go to the eMachines website and request replacement disks, http://www.emachines.com
Nov 03, 2009 | E-Machines eMachines Desktop PC
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
My speakers will not play on my computer
Mar 08, 2009 | Boston Acoustics BA735 Computer Speakers
No sound or mixer devices
a. your sound device may be built right in to your motherboard (make sure it's enabled in your bios)
b. you probably don't have installed any drivers for your sound device- install drivers by going into the motherboard manufacturer or your computer manufacturer.. post details and will help you look for them
Nov 07, 2008 | Computers & Internet
Speakers - monitor E15T4
Every monitor doesn't have a place to plug speakers, does the monitor have speakers built in? You may have to plug your speakers up directly to the computer, imagine that!
Oct 25, 2008 | E-Machines eMachines Monitor E15T4
Flat sceen monitors, no sound
We discovered the model we received did not have speakers. We are exchanging it for the same model that does. Thank you for your quick response! **** Winey
Apr 29, 2008 | Mag Innovision InnoVision LT865s 18" Flat...
E-Machines T1742 PC Desktop Logo
154 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
