1996 GMC Sierra Logo
Posted on Dec 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced 305 engine with 350, runs poorly at steady speeds
I rerplaced a 305 engine in my 1996 GMC 4x4 with a 1998 350 engine. It idles great, it accelerates great, but feels like it has the "hiccups" at a steady speed. The distributor and plugs and wires are relatively new. The engine runs very smoothly at idle, whether in park or in gear. Could this be related to the computer? I've been told it is not necessary to replace it, but I wonder if there is some difference between the computer on a 305 as opposed to a 350. I would appreciate some help as to what to do next.
Anonymous
Level 2:
  • Expert 398 Answers
  • Posted on Mar 07, 2009
Anonymous
Expert
Level 2:
Answers
398
Questions
0
Helped
221331
Points
974
Try replaceing/testing knock sensor, unless you already did
I have a 1996 GMC Sierra what engine wiring harness is interchangeable with this truck
I believe a 96-98 harness from any chevy or gmc would work. V8 to V8 not V6 to V8 the 305 and 350 would be the same harness
95 GMC K1500 350... replaced distributor...timed it at 0 with computer unplugged... plugged it back in and timing changed by few degrees, engine surges and runs poorly. Checked plugwire route for...
ok ran great before changes. right. you say unpluged computor to set timing.. yes.. do you mean the plug on the firewall passenger side that looks like a fuse holder kindof..?? (set timing connector ) (tan /blk wire)
did it run good during timing proceedure??? wont be MAP that is engine vacume has nothing to do with what you have replaced.
proceedure is to set timing . shut off engine , plug in.. then restart.
yes timing moves as per ECM specs. check that timing did no get out one tooth when you replaced distributor. retime . restart
What year motors, can I use to replace my blown 1996 305 vortec t.b.i.? I own a 1996 GMC 1500, sl, ext. cab. Does it have to be a vortec for my current computer to work properly? Will engine mounts, bell...
CHEVROLET PICKUP 1996 1997 1998 1999 8-305 5.0L VIN 8th Digit M
GMC 1500 PICKUP 1996 1997 1998 1999 8-305 5.0L VIN 8th Digit M
CHEVROLET EXPRESS VAN 1996 1997 1998 1999 2000 2001 2002 5.0L VIN 8th Digit M 8-305
GMC SAVANA VAN 1996 1997 1998 1999 2000 2001 2002 5.0L VIN 8th Digit M 8-305
1990 GMC 350 engine stops while idling at light. Replaced distributor cap,rotor, spark plugs and cables, new battery. and air filter. Engine is running without missing and no hessitation. Starts strong...
The Idle Air Control runs idle speed, it may be stuck or just bad. its located at the left rear corner of the throttle body, make sure its plugged in.
Chevy 305 small-block engine runs good has a bad idle and dies when idling. I used a 350 intake and ignition system and put onto the 305 and need to know what to look for to make idle
if this is a fuel injected engine youll most likely have to replace the idle speed control sensor this should solve that problem.youll have to get one for the intake that you put in the car(one for the year and engine size of the replacement parts)
2answers
Chevy 350 express van 2000 runs great idles rough
If it does not do it in park or neutral, it could be a number of things. One being a sticking Torque Converter Clutch solenoid (TCC). It could be that it needs a simple tune-up. How often does this problem happen?
3answers
1996 Yukon misfire when driving at steady speed
either your fuel filter by be plugged, could be injector shorting out could be throttle position sensor
1helpful
Rough idle and engine stumbles at highway speed
I have run across this problem and discovered that it was the mass air flow sensor.
2answers
1996 GMC K1500 engine replacement
everything will bolt up the same the only difference between the two is the bore the 350 is the better engine of the two
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
