Question about Sony Xplod XM-554ZR Car Audio Amplifier
Hook up Does anybody have a schematic, or know how to hook up this amplifier to some subwoofers in a 91 chevy truck
  • 113 Answers
Check the12volts.com
Posted on Aug 22, 2007
SOURCE:
The wires from Line level converter where to hook them up?
Firstly, and definitely, your "black" is subwoofer line out.
Check your AV receiver if the subwoofer option is activated. I've known some receivers that have the option to disable subwoofers and push all the bass into their front speakers.
Next, you have to check if your subwoofer is on or off? what about the volume of the sub?
If your subwoofer is passive, which means it does not require powering up using the mains, then you will have to get a seperate amplifier to power the sub up.
Jun 05, 2012 | Cerwin Vega Audio Players & Recorders
I have a jvc sp-pw50 Subwoofer and i want to know if you can buy an adapter for the input so i can hook it up to my kenwood amp? my amp does have a regular audio jack
That would require you to disassemble the subwoofer cabinet and disconnect the the supplied amplifier.
Connecting this unit to a different amplifier would provide no benefit to you unless the on-board amplifier became damaged.
Nov 16, 2011 | JVC SP-PW100 Subwoofer
Can i wire one speaker to the other speaker inside the box so that i only have one positive and one negative cable wire coming out out of the box and to the amp
Hello... I can help you with this question. Yes it is possible to do this, but you will have to use a 2 ohm stable mono block amplifier in order to do this. By connecting both positives together and both negatives together, you will be running a 2 ohm load. So if your amp is a monoblock amp, connections will be simple as tieing all the positives together and the negatives together and just hook to the amp. If you are using a 2 channel amplifier that is bridgeable, then you will need to series the subwoofers to an 8 ohm load and then bridge the amplifier to 1 channel. The way you series the subwoofers is take the positive wire in the box and hook to the positive on subwoofer #1. Take the negative wire in the box and hook to the negative on subwoofer #2. Then take a piece of wire and hook the negative from subwoofer #1 to the positive connector on subwoofer #2. Then hook the wires to the amplifier. To bridge the amplifier (if it is a 2 channel bridgeable) would be to use the left positive and the right negative, but check the amplifier for markings to confirm this. If you have any other questions, feel free to let me know and I will help you out! Hope this helps!!
20 year car audio/video installer
Bay manager
Mar 22, 2011 | Kicker 05C104 Car Subwoofer
Dont have wire schematic to hook up american pro bass machine limited edition model 1406,need to know how?
You should go to www.the12volt.com they are very helpful and pretty much have a schematic for every single car audio situation and they give you all your options. If they have nothing go to crutchfield.com and go to the learning section then subwoofer and amp wiring. It all depends on the subs that u wanna hook up to it as well as the ohm impedence and the amount of voice coils and so forth they have all of that.
Jun 13, 2009 | American Pro VS1406 Car Audio Amplifier
Car amplifier instalation
ur doin too much...you only use two amps to run a common subwoofer...if you want two subs either hook them both up to the amp you have, or get a bigger amp...hopefully this helps
Jan 27, 2009 | Car Audio & Video
How to wire a kicker 15 cvr
175W x 2 @ 2 ohms
350W x 1 @ 4 ohm
Your amplifier is not stable @ 2 ohm bridged. So you will have to wire them independantly on each channel.
+/- on sub to +/- on L channel
+/- on sub to +/- on R channel
Wiring the subwoofers in paallel will result in a 2 ohm load, which your amplifier is not rated to do. Doing so will cause heat buildup, and damage to the amplifier.
Dec 23, 2008 | Kicker CVR12 Car Subwoofer
AudioBahn A2300HCT no sound
Generally, if the amplifier smokes, the power supply FETs have failed.
Many times, the output transistors fail and that causes the power supply FETs to fail.
Audiobahn won't release schematics. The amplifiers are relatively simple and a schematic isn't generally required.
If you know how to check the transistors, check them to determine the severity of the damage. If you don't know how to check them, read through the following page following all links provided.
Basic Amplifier Repair
Let me know if you have any other questions.
Sep 04, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
70 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
