Have ACT! 10.03 installed. Not working any more
I have ACT! 10.03 installed on my VISTA desktop computer. Recntly I downloaded the beta version of Windows Explorer (the latest). Now I can not get into ACT! anymore.
The message reads:
ACT! by Sage has stopped working.
A problem caused the program to stop working correctly, Windows will clsoe the program and notify you if a solution is available.
None has been offered so far.
Can somebody help?
Regards,
Olaf Trunzer I am operating on a 64-bit VISTA (Optima) with MS Office 2007 and ACT 10.03 installed.
Recently I had to download .net 2.0 for another program. As a consequence, ACT! has stopped working. the message I get reads as:
ACT! by Sage has stopped wotking.
A problem cause the program tostop working correctl. Windows will close the program and notify you if a solution is available.
It appears that this is a conflict between windows and ACT!. I desparately need to have ACT! up and running again with over 30,000 reords stored.
Any suggestions?
Olaf Trunzer
The Knowledge Tree Inc.
  • d0211 Jan 05, 2009
    I have installed Act! 10.0 on Vista Home Premium SP1 and was advised to install Act! 10.03.  After the installation incurred problems the Installation process finished and I am now receiving the following message.
    ACT! by Sage has stopped working.  A problem caused the program to stop working correctly.  Windows will close the program and notify you if a solution is available.
    This is as far as I get!!!
  • Anonymous Mar 08, 2009
    Same 2 Error messages:
    Act.Outlook.Service has stopped working and
    This started after installing update
2 Suggested Answers
  • 8 Answers
SOURCE: Have ACT! 10.03 installed. Not working any more
Presumably you could roll-back to a restore point before the install. Just goes to show that Beta's are not a good idea - esp. from MS
Posted on Nov 29, 2008
I downloaded yahoo messenger 11 beta but I'm not able to open my email ...my computer is running window vista native 64 bit.
I would advice uninstalling 11 beta and just installing version 10: http://messenger.yahoo.com/download/
It should work just fine on Vista 64-bit. (32-bit applications are reverse compatible.)
Good luck.
Mar 01, 2011 | Yahoo Messenger
BIOS PROBLEM
The file you downloaded should have provided instructions for its use wither in a redme file or on the page it was downloaded from. There are several different ways for flashing the BIOS. Many still require booting from a DOS disk and using a DOS-based flash utility to perform the update. Others are Windows executable files that can flash the BIOS directly without having to start a reduced-functionality environment, but they require Administrative access to the computer to perform the update.
If what you downloaded was a Zip file, there should be instructions included with it.
You also want to make sure that it the the correct BIOS you are flashing. If it is not the correct version, you risk permanent damage to your computer.
May 26, 2009 | AMD Athlon 64bit -3000+ Multimedia...
Need an audio driver
Windows 7 is an beta version. you cant find drivers for that beta version yet
Good luck to you
Nic
Feb 13, 2009 | Compaq Audio card Sound Card
Nov 21, 2008 | Computers & Internet
Vista installed messenger logs in starts download of addresses and quits
you might want to download version 9 it's out now
might have fixed all those bugs that beta has
http://messenger.yahoo.com/download/win/
Oct 18, 2008 | Yahoo Messenger
I have a intel celeron dual-core microsoft windows vista home premium laptop with a sis mirage graphics card but i need a graphics card that has a t least 4mb of video ram can you tell me what card is...
  • CM9880/8CH Azalia Audio CODEC onboard (found on ASUS boards) - basic microsoft UAA function driver installed by Vista works but misses soundinput. Install latest ASUS/C-Media software (set compatibility mode to XP for the installer) > reboot > set multiple streams enabled > switch input from microphone to wave and back > reboot
  • Creative Audigy (standard) -- No built-in support, but it works with beta drivers from Creative's site.
  • Creative Audigy 2 ZS Platinum / Pro -- [http://us.creative.com/support/downloads/download.asp?sOSName=Windows+Vista+32-bit&region=1&Product_Name=Audigy+2+ZS+Platinum&Product_ID=9107&modelnumber=&driverlang=1033&OS=26&drivertype=0&Image4.x=38&Image4.y=15 * Creative SoundBlaster Live! Series. Works with special drivers found here http://www.ngohq.com/home.php?page=Files&go=cat&dwn_cat_id=20 (32 Bit)
  • Creative SounBlaster 2 Platinum Vista beta drivers found on www.creative.com
  • ECHO AUDIO - INDIGO DJ - OK but with strange routing in virtual outputs
  • Intel 8x0 AC97 (32 bit)
  • MSI Neo4 SLI Onboard Sound (CL 7.1) - Version: 5.12.1.506, (32 Bit)
  • nForce4 sound card - Version: 4.64, (32 Bit)
  • nForce3 (Realtek ALC850) - drivers obtained from windows update. (32 Bit)
  • Terratec 5.1 Fun PCI - sound works, controlpanel doesn´t work (32bit)
  • Terratec DMX 6Fire
  • SoundMAX Integrated Digital Audio (Tested with ASUS P4S800 Motherboard) - Needs latest drivers available to work correctly, otherwise install chipset drivers for AGP and IDE. Sound may skip and studder if not using the latest driver
  • anonymoose
    Oct 11, 2008 | Computers & Internet
    Yahoo messenger latest version(beta 9)
    yahoo messenger beta 9 doesn't work in vista...
    try another OS...
    try Xp SP2.....
    Sep 27, 2008 | Computers & Internet
    D-Link DWA-130 running Vista
    OK!! I figured it out!! Ok you need to go to the Dlink web site, cursor over to the tech support tab, on the drop down select DOWNLOADS, enter your Dlink wireless adaptor version(you'll need the box for these steps), ok now in the new window click downloads, choose and download the 130 one not the beta version, have a flash usb ready and save all downloaded files to ur usb flash, next insert your usb flash on ur laptop, open my computer select ur removable drive and double click the dlink software, after you do this it should bypass that prompt screen and you'll be able to continue your setup for your Dlink wireless adaptor.........hope it works for you cause it worked for me.....
    Aug 30, 2008 | Computers & Internet
    CD and Vista
    I suggest you create a dual boot situation with your computer, so it will run either XP or Vista. Most computer books will tell you how to set this up (not difficult). As for the software installation CD--check Ebay. People sell them often, whether originals or copies.
    Sep 13, 2007 | Sony CLIE PEG-T615C Handheld
    Computers & Internet Logo
    361 people viewed this question
    David Payne
    David Payne
