Question about Samsung SF-340 Plain Paper Inkjet Fax
Self test test says Line test:Check telephone line cord Rings when you ring fax line. Whats wrong
  • 30 Answers
Not sure but if when you lift the handset do you get a dialing tone? if not usually cheaper to buy a new fax maybe the modem is faulty
Posted on Dec 02, 2008
Cannot receive a FAX but can send FAX on a HP Photosmart C7180 All-in-One
are you using the same line for fax and phone???
are you using a Telephone Answeing machine or a Voice Mail??
However you can follow the following steps
1. Press the power button to turn off the HP fax product.
2. Wait for 20 seconds, and then press the power button to turn on the HP fax product, and then connect one end of a two-wire telephone cord to the telephone jack and the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
3. Make sure that there is plain white paper in the input tray.
4. Press the Setup button on the product Control Panel.
5. Press the down arrow to select Tools, and then press OK.
6. On the Tools menu, press the down arrow to select "Run Fax Test", and then press OK. The Fax diagnostic test prints.
7. Review the report.
If the test lists faxing issues and solutions, the fax test failed.
Try the steps on the printout to troubleshoot the issue as the report is specific to your product and faxing environment.
Repeat the fax test after fixing the listed faxing issues to make sure the test passes. Try to receive a fax.
Okay, next, we need to make sure that the Auto Answer feature is turned on by following the steps below:
When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls.
1. Press the Setup button on the product Control Panel.
2. Press the down arrow to select Basic Fax Setup, and then press OK.
3. On the Basic Fax Setup menu, press the down arrow to select Auto Answer, and then press OK.
4. Press the down arrow to select On, and then press OK.
5. Try to receive a fax.
Since the issue persists, the problem could be due to some conflicting telephone services.
The following telephone company services might block or interfere with incoming faxes:
Distinctive Ring Service: A distinctive ring service, if it is available from the telephone service provider, often resolves this issue.
* Voice mail: It is possible to use the fax in manual receive mode while using a voice mail service. For manual receive mode, turn off auto answer and press "Start Fax Black" or "Start Fax Color" on the control panel before the voice mail picks up the line to start receiving the fax.
* Call waiting: Do not use a call waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
* Privacy block
* Security screen
* Anonymous call rejection
* Privacy manager
* Any other service that screens or intercepts incoming calls
If any of these services are on the telephone line connected to the HP fax product, contact the telephone service provider for its recommended solution.
After addressing any existing conflicting telephone services, try to receive a fax.
Try contacting telephone people
try changing the settings below
2. Press the down arrow to select Advanced Fax Setup, and then press OK.
3. Use the down arrow to select Fax Speed, and then press OK.
4. Use the down arrow to select Medium, and then press OK.
5. Try to receive a fax again. If the HP fax still cannot receive a fax, try lowering the fax speed even further
Next, change the "Rings to Answer" setting on the HP fax by following the steps below:
2. Press the right arrow key to select Basic Fax Setup, and then press the OK button.
3. Press the down arrow to select Rings to Answer, and then press OK.
4. Use down arrow to select the desired number of rings, and then press OK. you cn change the rings to answer to 6 if your telephone answering machine picks up the call after 4 rings.
If the HP fax still cannot receive a fax, change the following steps
2. Use the down arrow to select Advanced Fax Setup, and then press OK.
3. Use the down arrow to select Error Correction Mode, and then press OK.
4. Use the down arrow key to select Off, and then press OK.
1. Plug the telephone cord directly into the telephone jack and not through any other device.
2. If present, remove any splitters or other devices attached to the line, except for a DSL filter.
3. If the telephone cord is over 3 m (10 ft) long, move the fax closer to the telephone jack, and then use a cord 3 m (10 ft) long or shorter.
4. Connect the other end of the telephone cord directly to the back of the HP fax product into the port labeled 1-Line.
5. If other devices such as, telephone answering machines or computer modems, are attached to the telephone line, remove them. If devices attached to other extensions of the same telephone line are present, remove them for this test.
6. Try to receive a fax.
If removing telephone devices and connections allows the HP fax product to receive faxes, this indicates interference from one or more of the removed devices. Interference can be caused by incompatibility or by using too many other telephone devices at once. Telephone devices can be added back but test after adding each to make sure that they do not start to interfere again.
If the HP fax product still cannot receive a fax after removing other devices, continue with the following steps:
7. If a DSL filter is needed on the telephone line, change the DSL filter and then try to receive a fax. If the HP fax product still cannot receive a fax, proceed to step 8.
8. If a new telephone cord has not been tried, change the telephone cord to a new two-wire telephone cord, and then try to receive a fax again.
if it does not resolve then perform the following steps
1. Disconnect the power cord from the back of the product.
2. Wait for 20 seconds, and then press and hold # and 6 on the product Control Panel.
3. Connect the power cord to the back of the product and then release the buttons when the product turns on.
4. The product resets to factory defaults.
As a last step, test in another location by following the steps below:
If possible, move the HP fax product to another location with a separate telephone line (another house for instance).
Try to receive a fax at that location, and if you are able to receive faxes from the changed location, then your telephone line should be tested.
If it resolves well and good if it does not then service the printer
Dec 12, 2012 | HP Photosmart C7180 All-In-One InkJet...
I can send faxes but cannot receive them fax test tells me there is no dial tone detection
* Privacy block
* Security screen
* Privacy manager
Oct 28, 2012 | HP Photosmart C7180 All-In-One InkJet...
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
FAX LINE NOT RINGING TO TELEPHONE
This is what is called a ring trip.
unplug your fax machine and plug in a normal phone. call the fax line. let it ring a few times. if the phone rings, but not the fax machine, check the cord of the fax machine and replace it. if the fax machine still does it, there is a short circuit somewhere in the machine. it is most likely in or around the jack that connects it to the phone cord, check for corrosion or bent contact pins.
if it rings only once or not at all, then check the phone jack for corrosion. trace it all the way back to where your phone line connects to your house. if it is still not ringing, call your telco to get them to check thier equipment.
Jan 15, 2009 | HP LaserJet 3055 All-In-One Printer
K80 OfficeJet has trouble distinguishing fax and phone ring tones
I would suggest getting a new one, but BE SURE you check to see if it will work with VoIP. I have the HP 6210 and it has problems with VoIP as well. Go to a place where you can test it at home and be sure you can return it if it has issues. Best Buy, or Staples are pretty good with returns, but SAVE the receipt! LOL... Sorry I couldn't offer better news! //Don
Apr 24, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Same fax and phone number
check the setting in the receive mode button. set it to fax
Mar 29, 2008 | Canon FAX-JX200
Canon Fax phone L80
If it is a dedicated fax line it is probabaly best set to fax only mode. Fewer rings (No more than two) FaxTel mode will ring for longer to allow you to pick it up if its a phone call.
Check if the machine has dial tone by onhook button or handset to check. If you have none try testing with another phone to rule out the machine.
Try a manual reception. Pick up the phone when it rings and press the start button.
Jan 31, 2008 | Canon FAXPHONE L80 Laser
Can't fax
You probably have the telephone cord patched into the wrong jack. Make sure it is plugged into the jack marked "line." If the problem persists, try doing this: 1. Unplug the power cord and the telephone line cord. Then wait for 30 sec or so before 1st plugging in the powercord. Wait until the display reads the currently set time, then plug the telephone line cord into the jack marked "line."
Nov 28, 2007 | Brother IntelliFAX 2800 Laser Fax
Samsung SF-340 Plain Paper Inkjet Fax Logo
95 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
