I just purchased a Hotpoint WDL540, I had it installed on Saturday. On sunday I did the test cycle, which worked fine. When I put a regular load in, it wouldnt go through the entire cylce (wash, rince, spin and dry). It would stay stuck at the wash. Water would go in and then drain, but never make it to the spin. I had to enter all cycles seperately. After, I put a load of towels over night expecting to have dry towels in the morning and it just did the wash (water in and out) all night. What is the problem? thanks.
  • Anonymous Mar 30, 2014
  • Washing Mach... Master
  • 3,463 Answers
Ring Hotpoint help line, you should find number in your user manual, or follow the link.
Posted on Dec 03, 2008
  • 833 Answers
If I had to guess...I'm thinking that you may not have shut the door to the machine. The safety feature was engaged. This might let the timer run the cycles but would have prevented the agitation and spin functions from working. Not the problem...get the manufacturer on the phone
Posted on Dec 02, 2008
Moulinex masterchef 470
customer care department:
Monday - Friday at 9:00 am till 8:00 pm EST
Saturday and Sunday at 9:00 am till 5:00 pm EST
Monday - Friday at 9:00 am till 6:00 pm EST
Saturday and Sunday CLOSED
Phone: 1 (973) 287-5150
Jack LaLanne Power Juicer Official Website Exclusive Offer Buy 1 Get 1...
Aug 21, 2014 | Jack Lalanne Juicers
My hotpoint wdl540 stops after the rinse cycle and all the function lights flash along with the start/pause light how do we access the inside of the machine to chekc the motor./brushestec
Go to and enter wdl540. With luck, you will be presented with a list of common repair parts and may be able to view a generic Hotpoint disassembly video.
Aug 24, 2017 | Washing Machines
Hi, is there a fillter on the hotpoint WDL540 as the stuff is not coming out very clean i have check the pipe and there are all clear.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 30, 2011 | Hotpoint Aquarius WD640 Front Load...
Wdl540 clothes go through drying cycle but come
If there is no heat at all then the heater or the temp sensor or the thermal fuses are defective and need replacing.
Also check that the lint filter is clear of debris and lint. Rinse it if necessary in some mild washing up liquid in warm water and dry thoroughly. Check that the air outlet hose is clear if you have one fitted. Check that the condenser is empty of water and the case is free from dust and lint. Vacuum / brush or wash the outside of the collector in washing up liquid and warm water and dry.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
We have the hotpoint washer/dryer wdl540 but cannot get the dryer to work, all the clothes come out steamed! we'r not overloading the machine and have tried different combinations but still it wont dry -...
The first problem is that you, like myself, bought this piece of trash. The best way to resolve this problem is not sell it on ebay and never even think about buying Hotpoint again.
Oct 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wdl540, cant get the draw out
pull it out as far as it will go. Look inside you will see a clip at the top. depress this upwards and pull draw out
Sep 01, 2009 | Hotpoint Aquarius WD63 Front Load...
My washer keeps coming up with errors
You have a right mixture of errors,
F11 indicates that the pump is not working.
F05 indicates that the pressure switch is jammed on full.
F04 indicates that the pressure switch is jammed on empty.
I would start by checking the pump is working o/k.
Next locate and clean filter.
This can be found by removing the rear panel of washer.
Locate and remove large black hose onto tub, remove filter and clean, refit same, make sure hose is on properly.
Test for leaks.
If no improvement, then I think your only option is to call an engineer out as it could become quite involved.
Good luck.
Plz rate my solution.
Jan 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WDL540 Washer/Dryer The fabric conditioner remains in the drawer after the wash cycle. The machine was installed on Monday, the first wash on cycle 3 seemd to go ok. The next two washes appear...
Hotpoint WDL540 This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 08, 2008 | Washing Machines
Wf640 test
This has happend to me today! this is the fix
  1. Press and hold the Start/Cancel button until message clears
  2. Now press both Start/Cancel and On/Off buttons together until you get a dOFF message
  3. now your machine should work OK
Mar 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
