I don't have the remote for this tv, Am using a philips universal and it will do everything else but won't give me the display options.
Before you do the following, make sure you know the code that is programmed currently in the remote since everything else works,
Try reprogramming your universal remote with one of these codes 10178, 11265, 10016, 11911, 10145, 10092, 10030, 10000, 11365, 11909, 10047, 10146, 10160, 10463, 11904, 10451
...One of these may allow you to access your display options. OR do you have a menu button on the front of your tv? you could possibly access the display options from there instead.
SOURCE: Zenith Concierge hotel tv wont work with my xbox 360
There may be a door in the front of the ste that is locked. You could take off the back and see if there are any circuit boards attached to the front of the ste and then that would show you where the door would be. Sometimes they losck the door with tabs on the inside and has to be pryed off.
SOURCE: my tv wont let me auto program the channels
if you can get to menu to unlock the channels type in 0000 or 1234 or 9999 or 0001 orif this doesnt work you could take back off tv and remove the little battery that looks like a coin out. becareful, this is high voltage in there.........
