Question about Belkin F1DK102P 2-port KVM Switch
How much Ram can it takeTOSHIBA Satellite A200 AH 3
I would like to know if this laptop can run on 4 gigs of Ram ?
  • Belkin Master
  • 19,396 Answers
Your laptop supports 4 GB.
4 Gigs of RAM is the maximum allowed on this particular model.
Read specs here.
Posted on Dec 01, 2008
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
I want to add more RAM. Is it possible?? Worth it??
It Depends On How much ram you are running now. More ram is Always A good Thing.
However, The Amount of Installable Ram Depends On the Operating System you are running.
Windows XP, Vista, and 7 32 bit (x86) systems only except up to 4 gigs of ram. (Sometimes 3 1/2)
Windows XP, Vista, and 7 64 bit (x64) Systems will except up to 16 gigs of ram. (Some Beyond that)
If you are Unsure which System you are running,
1. Click on the Start Menu
2.Right Click on my Computer
3.Doube Left Click on Properties
On the Main Properties Page it should display
1. Which operating System you are running and Which bit it is (eiter 32 or 64)
2. How Much Memory (RAM) you are currently Running
3 and What Proccessor is Installed in your computer
Jan 18, 2011 | Gateway 3522GZ Notebook
I dont know wat sort of ram to choose for this board because i am wanting to put in x6 4 gig ram ddr3 memory modules
running triple channel memory with more than 3 DDR3 1600 sticks installed (4-6) cuts the memory speed in half. you have to run with 3 sticks at a time in triple channel mode or you will see a reduction in ram speeds.
OCZ is making some good 4 gig ram sticks. they have a 12 gig triple channel memory kit with 3x4gig sticks. you could get 2 of these kits and have your 6 sticks- 24 gigs total, but your memory frequencies will be lower- your ram access will be slower.
Oct 28, 2010 | ASUS P6X58DE Desktop Board Intel Chipset...
If I upgrade from 2 gig to 4 gig RAM for my ASUS 1201n, will my 32 bit system benefit?
Any 32-Bit Operating System can use at the max of 3 to 3.2 GB of RAM. Hence, when running a 32-Bit Operating System in a computer, then it's advisable to have only 3 GB RAM installed.
Jun 23, 2010 | ASUS Eee 1201NPU17BK Netbook
Toshiba Satellite Pro A200 BIOS Password Request
for removing the password,
you have to open the memory cover and remove the two RAM s,
after that remove a black or whit plastic film depending on your model, you will loacte for B500 marqued ( XXX ) or J1 you have at least short
the two point with a flat screwdriver and put the upper memory and power on the laptop will holding the screew driver till you see the toshiba screen, if it doen't work just try again. it works 100%
Jun 15, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba laptop wont start up
change the ram (Random Access Memory) on your laptop your ram is not working
Regards
manish
Mar 24, 2010 | Toshiba Satellite A200-0ET00X Notebook
I need a guide in order to upgrade the memory of my Toshiba Satellite P205D-S7438. I'm not an expert at all but I already did so on another laptop (another brand too) and I know it is possible for me as...
This is real easy underneath you will see a large flap undo the screws hold it, and remove, you will see the RAM slotted into the socket,simply obtain the correct RAM for your laptop, and slot it in besides, or instead of, replace cover, and reboot, it will automatically be detected and used. If you have done it before then you are on your way to being an expert.. Oh we always say and "X" is an unknown quantity, and a "Spurt" is "Drip" under pressure...Xpert... < Joke.
Mar 08, 2010 | Toshiba Satellite P205D-S7438 Notebook
Belkin F1DK102P 2-port KVM Switch Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
