Question about HP Computers & Internet
Laptop will not boot up or hold a charge. - HP Computers & Internet
  • heckwithit62 Dec 01, 2008
    Adaptor has been replaced with a 90w power cord, laptop had been working with cord but stop working.
  • doomkinguk May 11, 2010
    Does the laptop boot from the mains adaptor? Please clarify more details.
    Sergeant:
    Champion:
  • 272 Answers
Sounds like you need a new battery.
Posted on Dec 02, 2008
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Battery not recognised/not charging
Turn the computer off, unplug it, take the battery out. Then hold the power button down for 10 - 15 seconds. Plug the ac adapter back in, but do not put the battery in yet. Boot the computer, then shut it back down. Put the battery back in then boot it again. It should recognize the system now.
Jul 31, 2014 | Sony VAIO VPCEA36FM/W Laptop
Battery won't hold charge
It most likely needs a new battery, but you could try giving the battery a full charge first:
1. Power off the laptop and disconnect the power adapter.
2. Re-seat the battery (remove/reinsert)
3. Reconnect the power adapter and let it charge overnight. (6 hr+)
4. Disconnect the power adapter.
5. Power on the laptop (run under battery power only)
If it doesn't boot up and shuts down immediately, it's probably time to see about a replacement battery.
2.
Jan 11, 2013 | Samsung Q430 Laptop
Laptop wont boot up
Hello,You must not have anythinghooked up to the computer not a printer telephone cord for modem nothing.
You must remove the battery and the poweradapter.
You hold the power button down for two minutesto purge out the residual memory and power.
Then you plug only the power adaper in and tryto boot up.Sometimes you have to hold the power button down a little longer toget it to boot.
If it does not boot then try unplugging the cordand hold it down another two minutes.
Try again with just the battery.
If neither work you may have a bad battery aswell as power cord or possibly just a bad power cord that is not charging thebattery.
Pleaselet me know if you have any further questions or concerns.Alsoplease rate it if you like the answer it helps alot.Thanks.
Apr 19, 2012 | Toshiba Computers & Internet
AC Adapter not charging
It is possible AVG has disrupted the settings, I would be tempted to run a system restore bringing the computer back before you installed the software, if this works! do not install AVG.
Apr 15, 2012 | Dell Inspiron 15 Laptop
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
My laptop switches on but screen blank i have charged my laptop up full too
Do you see the BIOS when the laptop boots up?
If you do not see anything at all when booting up then it sounds like it is a video problem.
Try holding down the H key when you turn on the computer. Do you hear any beeps or sounds?
Mar 21, 2011 | Computers & Internet
Display screen is not working
As the solution is to remove the power lead, remove the battery and hold down the power button it would seem to be an issue with the laptop retaining some residual charge which is preventing the laptop from booting. I've heard of other poeple who have managed to fix this by simply letting the battery run out and then leave it overnight, this will again dissipate any residual charge but is just a much slower way of doing it. Holding the power button down with no power sources attached will dissipate this charge and allow the laptop to boot when a power source is reattached.
May 29, 2010 | Sony VAIO 213GHz Intel Core i3 Notebook ...
My acer 5920 laptop will power up but screen will not come on
ry this for ur laptop.... unplug the power to the pc then take out the battery, then hold the start button on ur laptop for 8-10 seconds,,,once thats done, continue with installing the battery again and power lead.. then simply press start on ur laptop
Apr 20, 2010 | Acer Aspire 5920-6335 Laptop
Acer aod 250 netbook, screen dose not come at startup
Remove the power lead, remove the battery and hold down the power button it would seem to be an issue with the laptop retaining some residual charge which is preventing the laptop from booting. Holding the power button down with no power sources attached will dissipate this charge and allow the laptop to boot when a power source is reattached.
Thank you
Mar 21, 2010 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
