Question about Rinnai Webstone The isolator EXP tankless water heater Service Valves WRIK
Blow off periodically releases small amt of water.
Hello, I have a brand new rannai 94 ls. all works fine,except when i shut off facuets.sometimes when I shut off water a small amt of water is realeased from the safetey blow off, it almost sounds like a water hammer. Do I need a exp tank ? or some air cushions?
  • toghog Dec 02, 2008
    water pressure is 105 psi I just checked it. 2 moro I will be installing a reducing regulator,or else my problems will get worse
    tnx for the reply.
  • 24 Answers
This may be the case. If you have a check valve installed on the heater to prevent the hot water from backing up into the inlet or cold water side this may happen. A hot water expansion tank at the heater or water hammer devices near the fixture itself should cure the problem.
One question, how high is you water pressure?
Posted on Dec 01, 2008
  • James Feragola
    James Feragola Dec 02, 2008
    I think you solved your own problem, just by reducing the pressure you should not overcome the spring on your safety relief valve and see any water squirt out. While I'm sure that 105 psi makes for some exhilarating showers, it can cause negative problems in fixtures not designed to handle pressures that high.
    Glad you found a solution.
Would high winds and rain cause pilot light on a rannai tankless water heater to go out?
Yes.
High winds can cause reversal of air flow down vent pipe causing pilot flame to blow out.
If situation happens frequently, then special roof cap has to be added.
Have plumber check natural draft up vent pipe.
Other things can cause same problem, for example if vent fan is located in same room as water heater, or house is tightly insulated, and vent fan is ON, then it will draw air down the water heater vent and blow out pilot.
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
Oct 29, 2012 | Water Heaters
No hot water
test the thermostat and the heating elements --also there are resets that can pop push and make sure they have reset
May 17, 2017 | Water Heaters
Have a Rannai R75LS and getting hot water everywhere except my sink in the bathroom. System doesn't come on with only bathroom sink running.
I think these have a water pressure s/w or water movement s/w id replace the aerator 1st to a non water saver one or if possible remove water flow reducer looks like a metal washer .. if this not help you may need to replace the pressure s/w...in tank..
May 01, 2011 | Rinnai Water Heaters
Unit periodically shuts off. LED flashes "13."
it sounds like a dirty flame sencer rub down with emrycloth or fine wool steel if that dosent work need new pilot assembly.
Jan 21, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Water leaking from the base of the tank
If you'r really lucky you may find a leaking fitting on top of the water heater thats draining down inside the shell and out the bottom, otherwise its time to replace a rusted out water heater.
Sorry
Nov 08, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Brand new unit model G6A-8E. when i first hit the switch it comes on fine and heats water. at a later point (and it seems to be intermittant), when it goes to re-ignite to reheat the water it will not...
Check and adjust igniter probe(s) so that they are in front of the flame good. When you say it goes to re-ignite, can you hear, or see spark happening at igniter, but burner just won't catch?
Nov 01, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
1992 Reliance electric water heater model 501 has two 4500 watt heating elements , there is no hot water.
Check the breaker and top thermostat and make sure they are not tripped. Move onto replacing elements if above is not the problem.
Turn water and power off to heater and attach a water hose to bottom of heater to drain down tank. May have to open hot side on a facuet to get it to drain.
Once drained remove elements with 1 1/2" found at local hardware stores. once elements removed and new ones in place. Turn water on and get the air out of the system. Once water is flowing from the hot side from all of facuet's in house.
Once all air is out now yaou are resady to turn power onto heater.
Oct 09, 2010 | RELIANCE ELECTRIC WATER HEATER
When water heater is off a strong gas odor is present. checked by closing or shutting valve control assembly to off positon, where no gas ordor is present.
You may have a leaking gas valve control. Make up a squirt bottle of soapy water (use dishwasher soap and water) and spray the On-Off-Pilot knob for leaks, as well as the pilot button. Look for bubbles forming. Also check all the gas line fittings and connectors hooked up to the water heater for leaks. If you are smelling gas, do not attempt to relight the water heater. Close the shut-off valve on the gas line and see if the gas smell goes away. If it does, you may have to replace your gas valve. Depending on the age and condition of your water heater, it may be more cost effective to replace the control or buy a new water heater. Reliance is a common brand sold at stores like Lowe's. Typically, parts like your gas valve will usually only have a 1 year warranty. Check the manufacturer decal on the tank to see what their actual warranty period is. If you find a leak on the gas line itself, you will have to turn the gas off at the natural gas meter before disassembling the line to fix it. Use a soft setting teflon based pipe dope for the pipe threads. If you are uncomfortable doing the work yourself or don't know how to proceed, then call your local gas supplier for help. Douglas
Sep 02, 2010 | Reliance Water Heater #6-50-GORT 50GAL...
Rinnai Webstone The isolator EXP  tankless water heater Service Valves WRIK Logo
322 people viewed this question
Top Rinnai Water Heaters Experts
gizmonix
Level 1 Expert
James Feragola
James Feragola
Level 1 Expert
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
