Question about Epson AcuLaser C3000 Printer
Printer error reads 'Paper Out MP CTM'
Have checked paper in machine but unsure of meaning of error messager - can you help?
  • Epson Master
  • 1,113 Answers
Sounds like the document that is being sent to the printer, or the one if pending prints are present, has a page size set to other than what the printer has its set to for the tray feed (or tray feed is set wrong), so it is defaulting to the Manual Feed for insertion of correct medium CTM (not sure if int. but thats maybe a country thing we use A4, ENV and B5 mainly
Posted on Dec 01, 2008
  • Soulvisitor
    Soulvisitor Feb 03, 2009
    clarification...Manual feed on a epson muz be called the Manual Pass (MP)
    New Friend:
I have a printer model EPSON AL-M300DN. Sometime is show PAPER OUT MP CTM. Actually it have paper on the buttom tray. Anyone have the ask how to fix it?
Printer error reads 'Paper Out MP CTM' - 0186be79-1bfb-4bc7-92e3-72f70835a528.jpg
Posted on Sep 20, 2014
Another solution that worked for me (with a Brother 8840D) is to go to the Printer and Faxes applet. Under printer properties set the MP Tray to "Not Available". For my printer this setting is in Properties, Device Settings, Form to Tray Assignment.
Posted on Jan 07, 2009
4 Suggested Answers
SOURCE: epson aculaser cx11nf MP E paper jam
open the mp tray
locate 2 white plastic egg shaped piece on the ends of the steel rod
gently push one or the other towards the back of the machine
if the paper jam error message is on then the roller will turn as soon as you give it a push
re load the paper
open and close door a or e
printing should resume
that white piece works with the paper lift to get the paper up to the in feed roller
Posted on Sep 16, 2008
doc_delphi
  • 11 Answers
SOURCE: CX11NF "Paper Jam" and Noise
Had the same problem, too. The grinding noise came from the gear of the loading mechanism, located (if looked on printer from behind) on the right side next to paper tray.
I had a problem with the paper loading, too.
That problem was due to a broken wire for the magnetic release of the loading mechanism, located on the right side, too.
My experience with this epson is, that most problems with it come from broken wires, e.g. the problems with the ADF I had, the problem with the magnetic release I had.....
If I hadn´t invested so much time and money in this printer, I´d rather scrap it immediately.
Posted on Sep 17, 2008
SOURCE: EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Posted on Apr 30, 2009
Tray1 Load LTR
Hope this helps. Please check the printer properties before clicking Ok at print menu command. Now check the available paper tray handler. Try bypass, tray1 or MP tray.
Check also the default paper on Printer Menu command by pressing appropriate setup button. You can try also placing the paper on bypass try if available. The load LTR message means the machine waits a short bond paper on MP tray or on bypass tray.
Jun 16, 2010 | Office Equipment & Supplies
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Jan 15, 2010 | Brother MFC-8640D Printer
Load mp feeder error optra t 642 printer
I received this message when I was trying to print a pdf file. I attempted messing with the positioning of green paper guide to no avail. My co-worker suggested I uncheck the Choose paper source by PDF page size box on the Print pop-up box. This did the trick.
Dec 08, 2009 | Lexmark T642 Laser Printer
Lexmark T630 error message: Change MP Feeder
use the right arrow go to paper menu scroll to the right to paper source select if it is set to mp tray reset it to tray one. if its set to tray 1. check the side of the paper drawer to make sure the paper size snap in plate is in place. if these things are good replace the paper size selection pcb located in behind the logic pack
Sep 15, 2009 | Lexmark T630 Laser Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Epson aculaser cx11nf MP E paper jam
open the mp tray
re load the paper
Sep 01, 2008 | Epson ACULASER CX11NF All-In-One Printer
Tray 1 - load ltr (WHAT DOES THIS MEAN!!!)
Best regards,
Rosener
Feb 08, 2008 | Tally T8006 Laser Printer
Epson AcuLaser C3000 Printer Logo
2,775 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
