Question about Keurig Platinum B70 Coffee Maker
We have an older Keuric coffeemaker and it vibrates excessively
Sometimes the cup falls off and spills. It is on a granite counter. Any ideas?
  • 4 Answers
1. We were told by Keurig to place the unit on a MOUSE PAD (like for computer) for vibration and noise reduction. I haven't tried this yet! 2. Also, You need to or have someone to check inside the bottom of the Coffee Maker, sounds like the water tube may have come loose that lets water to the maker.
We just had the loud noise and big vibration problem.
When my husband took the bottom of maker off, he found the water tubing disconnected on the unit. Once he repaired this part and plugged it back up, it WORKED and was quieter and everything worked properly. I pray this helps!
Posted on Feb 14, 2009
Why is the coffee spilling/leaking everywhere during a brew cycle?
wrong filter possibly my Bunn does that with non bunn fliters
Apr 14, 2015 | Conair Cuisinart DTC-975 12-Cup...
Leaks water from bottom
Is it really from the BOTTOM, or is it spilling out the overflow holes in the back, then running down to the counter? If it's just spilling out the overflow holes, don't put quite so much water into it.
If it's really leaking from the bottom, and it happens even if you put only one or two cups of water into it, then the little hose running from the heating element inside up to the top filter has cracked or come off. You can fix that by opening the bottom of the coffeemaker (UNPLUGGED FROM THE WALL). You'll see where the rubber hose connects to the heating element and runs up along the rear tank. Check the connection where it attaches to the heating element.
Jul 31, 2014 | Gevalia CM-500 12 Cup Coffee Maker
Can i use linseed oil on my granite counters
you should not use linseed oil or any other oil on granite countertops unless the desired look is a darker stone. The oil may not penetrate depending on the color and density. Linseed oils are generally only for soapstone.
Apr 28, 2014 | Building Materials
Granite countertop
Granite needs to be color matched epoxied together at the seams. If they are sitting level and flush (and Solid) a home owner solution is to use matching silicone filling the seem then cleaning off with a good solvent. tape the top on both sides before starting. The second solution works to keep out food, but may not look great if they are not flush or have not been cut cleanly and the gap is not too wide. You will need suction cup turn buckles to pull them tight. Do not do any of the above if you are not comfortable with your skill level or feel it may damage your top. Granite can be stained using the wrong products.
Oct 12, 2013 | Dishwashers
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
I am upset that I did an etching project and I accidently got some etching cream on my black granite counter tops. It looks like it is just discolored. But it sticks out like a sore thumb because it is...
Is it a genuine GRANITE counter top??? I'm surprised an etching solution damaged it... what was the etching solution for, glass, metal??? to be honest I would try to find a spot of the counter top somewhere that is not showing and do some testing before addressing the visible spot, first replicate the issue with the etching solution at the hidden spot (or on some left over peace of counter), than try different cleaning solutions (ask an expert on granite counter tops) if it does not work try a polishing solution or even some acids could bring back the colour...
Mar 24, 2011 | Microwave Ovens
I am trying to buy a KIRD862 downdraft for my existing granite counter top. Since it requries cutting granite, I call around to look for a contractor but without any luck. All the people doing kitchen...
Any granite fabrication shop should be able to send a couple workers out to cut the existing granite for your new downdraft.
Feel free to contact me if you have any questions.
Brandon Wiese
Brandon@StoneRepairman.com
http://www.StoneRepairman.com
Nov 11, 2010 | KitchenAid KIRD862VSS Kitchen Hood
Keurig Platinum B70 Coffee Maker Logo
554 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
