Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Can't reprogram the remote controls.
By mistake I erased the codes. Now I'm following the instructions to reprogram the controls, but it doesn't work. My model is 139.53985DM
  • May 11, 2010
    What's happening when you try reprogramming? When you press the "learn" button on the opener, does the indicator come on like it's supposed to? If so, all you should need to do is press the large button on the remote, or enter a new code for the remote keypad.
The light indicator comes on but it never connects with the remote control & I have to reprogram the key pad when, I follow the directions on the unit.
Posted on Dec 01, 2008
Ok/select doesn't work with magnavox dvd player
Hi, make sure you Comcast remote is in the "DVD" mode before attempting to work the DVD features. If it is still not working. You need to reprogram your Comcast remote to a different Magnavox DVD code because the code it is currently set for not fully compatible. If you need the instructions to reprogram your Comcast remote go here. If you would like to purchase a new Magnavox DVD player remote you can also search on Replacement Remotes for your DVD player's model number located on the back of the unit. If they have it, it will show for purchase.
Sep 03, 2012 | Universal Remote Control Remote Control
I lost the papers that tells me how to set it up sony rm-v210 remote control
Here ya go. Heres some brief instructions and a link to sony for the codes and full instructions
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the SET button until the SET indicator lights up.
  3. Press the appropriate component select button for the component being set up.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENTER button.
  7. Point the remote control at the component and press the POWER button.
NOTES:
  • If none of the codes listed for the manufacturer work, it may be necessary to try codes listed for other manufacturers or perform a search for the correct code. Consult the Operating Instructions provided with the remote control for steps on searching for the correct code.
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • The operation of a combination deck of any kind is not guaranteed.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
  • If programming fails, it may be necessary to reset the remote control. To reset the remote control, remove the batteries and press each button on the remote control twice.
go here for more information http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV210
Oct 17, 2010 | Sony RMV210 Remote Control
Lost the instrucción of SONY RM-V310 how do I set the control remote to a Jensen TV ??
Code is 079
  2. On the remote control, press and hold the SET button.
  3. While holding the SET button, press and release the POWER button
  4. Release the SET button.
  5. Press the appropriate component button for the component being set up.
  6. Using the number pad, enter the component's manufacturer code. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  7. Press the ENT button.
  8. Point the remote control at the component.
  9. Press the POWER button to verify operation.
NOTES:
Jul 30, 2010 | Televison & Video
How do you set the TV code for the remote: RMT-B107A
How to Program the RMT-B107A Remote Control:
Follow these steps to program the remote control to operate a television.
1) Turn on the TV.
2) On the remote control, press and hold the TV I/O button.
3) While holding the TV I/O button, enter the manufacturer's code using the numeric buttons.
NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
4) Release the TV I/O button.
5) Point the remote control at the TV.
6) Press the TV I/O button to verify operation.
NOTES:
Mar 16, 2010 | Sony Televison & Video
The codes I have won't work for my Sylvania TV
Are you using these codes 011, 012, 003, 073,041......???? you can try and do it this way also,
Follow these steps to program the remote control. check out this link:
http://esupport.sony.com/perl/model-remote.pl?mdl=RMV302#instr
http://www.docs.sony.com/release/RMV302codes.pdf
NOTES:
Jun 20, 2009 | Sony RM-V302 Remote Control
I need code for my Tv
try one of these codes 003, 013, 012, 030, 046, 050, 051, 049 here are some instructions
NOTES:
here is a link for your remote controller http://esupport.sony.com/perl/model-remote.pl?mdl=RMV302#instr
Feb 18, 2009 | Sony RM-V302 Remote Control
Remote control programming
this rca should work on your rca tv , but here is the manualand how to clear a code for a device and reprogram it to the new device
scroll down to the second pdf file page ( thats where the instructions are for the reprogramming of selected device on remote ) http://www.remotes.com/remotes/documents/RCA/257003.pdf
Jan 01, 2009 | RCA 257003 Remote Control
Needcodes for yamaha receiver and steps to program for rm-302
102, 014, 030, 046 here are some directions Follow these steps to program the remote control.
NOTES:
try this link for any other codes you might need http://esupport.sony.com/perl/model-remote.pl?mdl=RMV302#instr
Dec 09, 2008 | Sony RM-V302 Remote Control
Codes
try the following codes until one of them work:
002, 003, 004, 005, 006, 007, 008, 044, 045, 046, 053
  2. On the remote control, press the SET button.
  3. Press the appropriate component button for the component being set up.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the POWER button to verify operation.
NOTES:
Nov 23, 2008 | Sony RM-V310 Remote Control
I need the codes to operate a sony HT-DDW660
001 is the only code listed for sony
here is a link for any code you might need in the future
NOTES:
Oct 25, 2008 | Sony RM-V302 Remote Control
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
283 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
