Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Dishwasher pumps out , then shows F7 and nothing more happens
The model is Fisher & Paykel Nautilus. I put a pot of water in. in case the pump was not working. I set it to 'normal' after the F7 came up and then pressed 'start/reset.' It did another another pump - out and returned to F7 and 'rinse.' I pressed 'start' again. It pumped out and showed 'finish'. Then it went back to 'time remaining' '0:10'. Nothing happens after that.
  • kaylp Feb 26, 2009
    I have previously had this problem when there was too much rinse aid (the F&P mechanic recommended not using any rinse aid). It is doing it again today, and I am just flushing the system with litres of water poured in and then letting the machine drain it out.
  • mail203 Mar 26, 2009
    Same problem here. We started getting the F7 error months ago. It seemed to be related to us using the taps in the house when the machine was running. That's no longer what we think: we put the machine on at night before we go to bed and it STILL comes up with F7.
    After getting the error I have to hold down reset for 5 seconds, let is do its thing, and then turn it off at the wall. Start again ... and sometimes ... just sometimes ... it'll get through a complete cycle. Funnily enough though I did just top up the rise aid the other day. Could it be as simple as that?
    By the way, my machine also seems to be increasing the time it takes to do a cycle. Our normal wash has increased from 1:18 a minut at a time and is now sitting at 1:30!!!
gittos73
  • 244 Answers
SOURCE: Fisher & Paykel "clog Problem"
the water comes through 2 vavle 1 for washing and the other for rinsing more than likely that the rinse valve is down it will need replacing thats the more common fault for washers not rinsing
Posted on Aug 12, 2007
  • 183 Answers
SOURCE: fisher & paykel GWL08 washer
faulty pcb Regards Advisor
Posted on Aug 22, 2007
JULIANFIX
  • 975 Answers
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Posted on May 20, 2008
SOURCE: the drain/circulation pump quit on my fisher paykel gwl11
Checked the control board for a fuse.  Found two fuses on the printed circut board.  Checked both for continuity, one had none a 6.3 amp fuse sodered into the board.  went to a local electronics store and purchased a similar and replaced fuse.  Everything works fine now.
Posted on Jan 17, 2009
  • 93 Answers
SOURCE: no power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Posted on Jul 10, 2009
Fisher and Paykel Nautilus Dishwasher wont advance to take water in .
The problem could be with flood switch at base of dishwasher. Press the float to check if it springs back. Otherwise switch under it is faulty.
Jan 19, 2013 | Fisher and Paykel Dishwashers
I get an F7 error when using my Fisher & Paykel Dishwater Nautilus Model DW691ED WH
F7 means there is a bad communication between the motor and the control board. Make sure none of the wires are broken and if not, then replace your control board in the front face of your dishwasher.
Sep 25, 2011 | Dishwashers
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
Hi
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Daniel
Aug 07, 2010 | Fisher and Paykel Dishwashers
I have a nautilus dishwasher by fisher and pykel can't find any user guides Flashing F1 and has drained ...do these dishwashers have a reset button?
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
http://www.appliancerepairlesson.com
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel nautilus. Cycle stalls with 15 mins to go. On any setting.
OK, when you say it sounds like a record skipping does that mean its washing then not washing? what cycle are you using ? sorry to ask these questions but sounds like an unusual fault.is the water hot? could be control module or pressure switch fault. please reply and we can hopefully track down this fault.
May 22, 2010 | Fisher and Paykel 24 in. DS603H SS...
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Washer will not drain water out properly
you may need to take the pump apart as it may be clogged.
Apr 09, 2009 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
271 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
